Welcome to the North American Subaru Impreza Owners Club Tuesday July 27, 2021
Old 01-13-2020, 01:39 PM   #1
Disfigured
Member#: 506169
Default Timing Belt Replacement Check List, am I missing anything?
Hey guys,
I just bought a 2011 WRX Hatback with 154k miles. I have been trying to reach out to get the service history but no luck.. So seeing as the timing belt may be WELL overdue I decided to go and do this while im installing some other mods.
Can anyone let me know if i'm missing anything or if theres something I should add while im getting it done anyways I would really appreciate it.
Heres the list:
-GDT Cylinder 4 cooling mod
-IAG Air Oil Separator install
-Gates Timing Belt kit with Water Pump
-Gates super strong alternator and powersteering belt
-OEM Thermostat w/ Gasket
-Valve cover gaskets replaced
-Cam Seal x2?
I have read other posts where people have recommended replacing the Crank Seal, I just had my rear main seal replaced when I did the clutch job 1k miles ago, Is this the same seal?
Thanks to all
Disfigured is offline   Reply With Quote
Old 01-13-2020, 02:07 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
If the cam/crank seals aren't leaking, there's no reason to change them. Does that kit come with new idler pulleys?
Old 01-13-2020, 04:15 PM   #3
Disfigured
Member#: 506169
Yeah the kit comes with idler pulleys, Hydraulic Tensioner, Racing timing belt, water pump w/ gaskets
Old 01-20-2020, 12:31 PM   #4
ADSubaru
Member#: 510909
Should be good to go
ADSubaru is offline   Reply With Quote
Old 01-20-2020, 01:03 PM   #5
Jersey Man10
Member#: 427632
2011 Impreza WRX
Satin White Pearl
I probably wouldn't have gone with the racing Gates Timing Belt just the regular one. I would recommend an OEM water pump also.
Just did mine last month. No issues so far.
Jersey Man10 is offline   Reply With Quote
Old 01-25-2020, 12:01 AM   #6
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Yup, skip the racing timing belt. And make sure you get the Japanese kit not the Chinese kit. And so much yes to OE water pump, although I wouldn't balk too much at a japanese manufactured one.
I've seen more cheap aftermarket water pumps fail at 30-40k miles than OE water pumps failing at 200k.
CosmoTheCat is offline   Reply With Quote
Old 01-25-2020, 06:20 PM   #7
hrbutler52
Member#: 295691
2011 WRX
Blue Mica
Don't see an A/C belt in the list. Is it in the Gates kit? If not replace it unless you are doing without A/C.
hrbutler52 is offline   Reply With Quote
Old 01-26-2020, 10:10 AM   #8
Beaverpound
Member#: 373289
2004 WRX
ASPEN WHITE
Yeah looks good to go
Beaverpound is offline   Reply With Quote
Old 09-19-2020, 03:06 PM   #9
Hallucidini
Member#: 516887
2004 Wrx
Any experience with Aisin water pumps?
Hallucidini is offline   Reply With Quote
Old 07-19-2021, 06:48 PM   #10
Imprezzr
Member#: 525638
2006 Impreza WRX
crystal grey metallic
When I did my timing belt I used all oem. I spent around $700 in parts. The aftermaket parts are made in China. I read online post about the water pumps failing prematurely. Remember you get what you pay for, you dont want any of these parts failing.
Imprezzr is offline   Reply With Quote
Old 07-21-2021, 11:34 PM   #11
ilovedemhotrides
Member#: 326147
2004 STI
wrb
Itís not 700 in parts you can get the timing belt and kit with water pump for 350- 400. Oem.
ilovedemhotrides is offline   Reply With Quote
