Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2020
Old 03-15-2020, 09:22 PM   #1
Vooduru
Member#: 485649
Default Dyno tune:2.5L + G25-660 makes 517whp on e80
Event: Dyno tune.
Ambient Temp: 52 deg.
Elevation: 1,000 feet
Weather: Dry
Car: 2009 WRX in 1973 VW Super Beetle.
Tuner: Paul Leung
Dyno Info: Mustang Dynanometer
Transmission: 5MT, Subargears, PPG 1-4 helical dog engagement,
Gear: 4th, 1.050:1
Peak HP: 517 @ 6,631 rpm Corr Type SAEJ1349 Corr Factor: 1.006/0.994
Peak Torque: 470 @ 3,985 RPM Corr type: same
Baseline HP and TQ. Will have to get back to you on this.
Target Boost: 32 psi.
Target AFR: Will have to get back to you on this.
Fuel: E80
Engine power modifications: IAG stage 2.5 closed deck, SoCal ported D25 heads, .5mm over-sized valves, 2.5i n/a intake, custom awic using Bell core, ID 1,700 injectors, -6 fuel line, twin in-tank 340 lph fuel pumps, low mount G25-660 w/.92 A/R turbo, 3.5 MAP, custom EL 321 ss header, iwire using '07 cpu, Mocal scavenge pump and STOCK '09 WRX cams.
Car weight: 2,400 lbs. with driver.
Vooduru is offline   Reply With Quote
Old 03-15-2020, 09:30 PM   #2
Vooduru
Member#: 485649
The car is a VW bug sleeper. It will look very close to stock unless you look underneath where you will see 275/15 drag radials hidden under stock fenders. Could not keep the tires from spinning hence the weird sudden drops on graph.
Old 03-15-2020, 11:03 PM   #3
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
That is AWESOME!!!!! Would be a handful
CEEBEE is offline   Reply With Quote
Old 03-15-2020, 11:22 PM   #4
Vooduru
Member#: 485649
Yeah, 1st is useless. Rolling on the power in 2nd, 3rd still breaks traction.
A stock Super Beetle puts down 32 whp. This thing is 16 times that power level.
When you lay into the throttle, you absolutely have to mean it.
Old 03-20-2020, 04:46 PM   #5
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
When did Yimi get a Mustang dyno?
Awesome Setup.
Zee Biker is offline   Reply With Quote
Old 03-20-2020, 04:52 PM   #6
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Dusty
Awesome Setup.
Yeah, I saw the title and kind of blew it off since they're old dyno always read way high. A proper calibration mustang is different though, and those are some good numbers.
subydude is offline   Reply With Quote
Old 03-23-2020, 08:33 PM   #7
Vooduru
Member#: 485649
Yimi changed location a couple years ago. Maybe that was when they made the change. Of course, it's a 4 wheel dyno and has small rollers. What I really needed was a dyno with bigger rollers (2wd) as traction on the small rollers was difficult.
Old 03-23-2020, 08:48 PM   #8
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
S.I.C.K. I've never driven a beetle without the craptastic transmission and weaksauce engine, can only imagine how much better it would drive with a subaru transmission and metric crapton of power!
2slofouru is offline   Reply With Quote
Old 03-23-2020, 09:59 PM   #9
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
That is bitchin.
Old 03-24-2020, 01:12 AM   #10
Vooduru
Member#: 485649
Thanks, the body is off for body and paint to bring it back to it's original 1973 Marina blue.
Since there isn't a reverse R&P option for the stronger 6mt, I'm stuck with a 2009 5mt. As mentioned, PPG 1-4 helical dog engagement gears were used. To help the trans survive, larger SAE case through bolts were used to help keep it clamped together. Finally, to keep a friendly conversation going on between the R&P, I made a chromolly girdle which also incorporates load bolts that hold the carrier bearing adjusters from deflecting.
Old 03-26-2020, 05:46 PM   #11
Homemade WRX
Member#: 33782
96 3MI Racing
Is that r&p Pentagon plate beefy? Any reason you didn't rib/gusset it?
Old 03-27-2020, 09:34 AM   #12
vicious_fishes
Member#: 158864
2003 SOHC destroker
amazing. why the funny drop at 4000rpm?
vicious_fishes is offline   Reply With Quote
Old 03-27-2020, 09:41 AM   #13
Stretch18
Member#: 239822
2010 WRX
pandiculation
Probably lost traction...
Stretch18 is offline   Reply With Quote
Old 03-27-2020, 11:02 AM   #14
kos
Member#: 118334
2006 Red GDA-F
2005 Aspen White GDA-E
Badass!
kos is offline   Reply With Quote
Old 04-01-2020, 03:14 PM   #15
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Wow epic!
robbieshonda is offline   Reply With Quote
Old 04-06-2020, 02:49 AM   #16
Vooduru
Member#: 485649
I was able to get (inside) webs on one side but there wasn't enough room between the frame horns on a VW for ribs on the other. What you see is all that would fit. Being that everything is like one big dimensional sandwich and made from 4130 plate, even the flat plate with no webs helps, IMO. The plate is .190" thick.
Old 04-06-2020, 02:50 AM   #17
Vooduru
Member#: 485649
Yeah, we couldn't keep traction. There was a tire rubber all over the dyno room.
Old 04-06-2020, 03:13 AM   #18
vicious_fishes
Member#: 158864
2003 SOHC destroker
time for hub dyno then
Old 04-06-2020, 04:04 PM   #19
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
Dave D. is offline   Reply With Quote
Old 04-06-2020, 08:41 PM   #20
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Insane. I didn't expect to see it going into a bug.
JDMJNKY is offline   Reply With Quote
Old 04-07-2020, 01:00 AM   #21
Vooduru
Member#: 485649
I'm part of the VW 2.0 crowd. Had a hopped-up bug as a teen and now again at 60. Only this one is a little different. Just couldn't come around to dumping thousands into a VW motor to get a meager 200 hp.
Yes I saw the Love Bug in the theater
Old 05-03-2020, 01:43 AM   #22
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Nice! Full spool in the upper 3K's. EWG?
Fierysun is offline   Reply With Quote
Old 05-18-2020, 10:09 PM   #23
Vooduru
Member#: 485649
^ ^Yeah, 44mm. I think it's in one of the pics.
Old 05-18-2020, 10:44 PM   #24
silversurfer05
Member#: 366241
2009 09 wrx delivery
Dgm
What boost level on the 91 tune boss?
silversurfer05 is offline   Reply With Quote
Old 05-18-2020, 11:04 PM   #25
Fierysun
Member#: 82745
2005 Subaru STI
Why is there a dip around 4K?
