Welcome to the North American Subaru Impreza Owners Club Friday April 10, 2020
Old 03-23-2020, 03:35 AM   #1
12wrx1
Member#: 386873
Default Motorweek S209 test with video....
12wrx1 is offline   Reply With Quote
Old 03-23-2020, 06:38 AM   #2
Brahmzy
Member#: 3293
'20 Ascent
'15 XTerra P4X
Release.. The ShillBot!
Old 03-23-2020, 06:44 AM   #3
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
Ibtl.
murrdogg24 is online now   Reply With Quote
Old 03-23-2020, 07:27 AM   #4
RealDealTarheel
Member#: 142447
2019 Audi S3
I'm reminded of the pep talk Duke gives in Rocky VI: "To beat this guy you need speed. You don't have it".
RealDealTarheel is offline   Reply With Quote
Old 03-23-2020, 08:07 AM   #5
JP Chestnut
Member#: 504432
Maybe this particular car had Coronavirus.
JP Chestnut is online now   Reply With Quote
Old 03-23-2020, 08:10 AM   #6
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
Maybe the 2015-2016 STI's were just better with less decoration and simplicity.
Even the refresh models are showing slower acceleration times than the earlier STI's..
oichan is offline   Reply With Quote
Old 03-23-2020, 10:00 AM   #7
Pre
Member#: 139693
Old 03-23-2020, 10:52 AM   #8
Sid03SVT
Member#: 183032
RWD Camry
Pull me over red
other odd trends in recent memory that have (mostly) died off:
duck calls on BOV or exhaust
truck nuts
bosozoku and other JDM trends, but roughly 5 years after they happened in Japan
Sid03SVT is offline   Reply With Quote
Old 03-23-2020, 11:17 AM   #9
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
LOL'ed. Mudflaps are also useless ugly dekoreations I see often on our street driven cars.
Old 03-23-2020, 11:48 AM   #10
RealDealTarheel
Member#: 142447
2019 Audi S3
???? They don't use rocks to treat the roads where you're from?
Old 03-23-2020, 12:52 PM   #11
Pre
Member#: 139693
They are used for paint protection.
Old 03-23-2020, 01:37 PM   #12
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
No only salt and spray. I suppose if one is in CO they do use rocks. That could make sense to have. But still ugly.
Old 03-23-2020, 01:43 PM   #13
JP Chestnut
Member#: 504432
The low quality salt they use in NY state is most definitely adulterated with rocks and ****.
Old 03-23-2020, 02:39 PM   #14
heavyD
Member#: 194216
2020 X3M Competition
The additional weight of the larger wheels likely play a role in the slower times as the EJ257 isn't really a strong engine by today's standards.
heavyD is offline   Reply With Quote
Old 03-23-2020, 03:41 PM   #15
Sid03SVT
Member#: 183032
RWD Camry
Pull me over red
Me and an average of a windshield every other year would disagree with you. No I'm not following to close, our roads are just crappy & riddled with debris, and people love ride height.
Mudflaps should be mandated on anything with ground clearance or 5.9" or greater.
Old 03-24-2020, 08:24 AM   #16
chanomatik
Member#: 159474
2017 Impreza Sport
Lithium Red - OLDKID
This is one of the oddest hot takes. I'm intrigued.
chanomatik is online now   Reply With Quote
Old 03-24-2020, 11:17 AM   #17
mcarb002
Member#: 324784
2019 Forester Sport
Wrong
Old 03-25-2020, 08:33 AM   #18
Scooby921
Merci Buckets
Member#: 88606
2018 Grand Cherokee
Velvet Red Pearl
Originally Posted by mcarb002 View Post
Wrong
Correct. If you drive on dirt roads they can be useful. Still ugly though.
Scooby921 is offline   Reply With Quote
Old 03-25-2020, 08:47 AM   #19
JustyWRC
Member#: 153088
2005 Baja Turbo
06 Forester 18 Imp Sport
I agree they are not "useless"; but, I'll spend more money for other options.....maybe clear bra the whole side.....before putting those ugly things on a "tarmac" set up. Now, If I got crazy and set my car up like a gravel rally car setup, then duh....
JustyWRC is online now   Reply With Quote
Old 03-25-2020, 09:49 AM   #20
RealDealTarheel
Member#: 142447
2019 Audi S3
One of those options is significantly cheaper than the other. Some places you can get away with neither, others it's a good idea to have one or the other.
Old 03-25-2020, 10:24 AM   #21
JustyWRC
Member#: 153088
2005 Baja Turbo
nevermind. I finally understood what I read
Old 03-25-2020, 01:27 PM   #22
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
Cobb announced tuning support for the S209 today. They're only offering a Stage 1 OTS 93 octane map.
https://www.cobbtuning.com/2019-suba...uning-support/
The COBB OTS Map availability for the S209 is a bit different than our typical WRX or STI assortment. With a limited number of cars available to be used for testing, and based on our findings, the only performance map offered at this time is a Stage 1 OTS map for 93 octane fuel. During investigation and development of this map, our calibration team noted that even utilizing the factory calibration with 93 octane fuel, the S209 exhibited an inconsistent and undesirable amount of knock. As you can see in the graph below, power sometimes suffered significantly on the factory calibration, so we were forced to end pulls early, prior to hitting the factory rev limiter. We were able to mitigate most of the undesirable activity in the Stage 1 93 map file and carry power out much more consistently up top, but did not attempt to achieve similar results using 91 octane fuel.
The Red (Run 1) and Green (Run 2) pulls represent power utilizing the factory calibration on two separate days. The temperature difference was about 40 degrees Fahrenheit (40F vs 80F) between the two days and that difference made a significant impact in overall power. Power gains as tested were 7-15% for both horsepower and torque.
I'd hate to own a S209 in a warmer climate with only 91 octane fuel available. I can only imagine how it would perform on a 100+ degree, hot summer day here in California on 91 ACN. They couldn't even take it to redline on the stock tune without experiencing power loss due to knock.. even in 40 degree weather.
WRXnick16 is offline   Reply With Quote
Old 03-25-2020, 01:46 PM   #23
neg_matnik
Member#: 132389
2006 WRX Wagon SGM
2003 SV1000S, 2014 DL650
[URL unfurl="true"]https://www.cobbtuning.com/2019-subaru-wrx-sti-s209-tuning-support/[/url]
Yup. Unfortunately, EJ257s have been knocking on 91 ACN from day one. It just got worse over time as Subaru made changes to try and meet emissions requirements.
Basically, for us on 91 ACN, on the streets, we have to use flex fuel setups or water/meth injection setups just to make the *rated* power.
At the track, it's easier, fill up with half a tank of 100 or 110 AKI unleaded and knock should go away.
EDIT: but, then again, my opinion is that, if I have to spend $40+K OTD on a brand new car, I shouldn't need to jeopardize my factory powertrain warranty just to make the engine run right.
That makes no sense.
A used and older vehicle? Sure, why not.
neg_matnik is offline   Reply With Quote
Old 03-25-2020, 02:04 PM   #24
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
Exactly. And now it even knocks on 93 in their $65k halo car.
But we already knew that Subaru has issues with their stock tunes I guess the S209 is no different.
Old 03-25-2020, 02:07 PM   #25
JP Chestnut
Member#: 504432
It's tough to look at those curves and not get a bad taste in your mouth. The general reason why aftermarket tuning makes more power than stock is because OEMs tune their cars with excess safety - so that a car will run decently under the worst real world conditions that it could possibly face.
It's not clear that S209 could survive even a single summer HPDE event at Willow Springs on its stock tune. Subaru did such a half assed job on this "racecar for the street."
