Welcome to the North American Subaru Impreza Owners Club Thursday October 28, 2021
Go Back   NASIOC > NASIOC Technical > FB Series Normally Aspirated Powertrain
Old 06-23-2020, 02:03 PM   #1
ellorno
Member#: 515765
Default 2014 Impreza 2.0i base, newer model FB20
how the heck does the timing chain cover come off without breaking stuff.. I've been using 2 pry bars where I can, and wedging something in to be able to use a knife to cut away at the silicon, but making minimal progress. and with minimal spots to pry at, i'm at a point where I may end up breaking the darn thing with the leverage i'm putting at spots.
any advice?
ellorno is offline   Reply With Quote
Old 06-23-2020, 03:26 PM   #2
Aristocrat Autosport
NASIOC Storefront Vendor
Member#: 384404
MANY WRX, STI, 997TT
wrb
have you removed all bolts around the timing cover as well as the 3-4 that run through the middle from of the cover?, is the crank pulley pulled off?
Aristocrat Autosport is offline   Reply With Quote
Old 06-24-2020, 10:51 PM   #3
ellorno
Member#: 515765
omg, feel free to come punch me in the face, i missed the two in the middle.. not sure how, just exhaustion i suppose?
i'll write more on the issue after i get the cams out and inspect the springs, etc. but what i do know is that the compression across the board is 165psi, and the loud ticking is coming from #4 cyl. area.
Old 06-18-2021, 05:04 PM   #4
oddnimbus
Member#: 525008
Smile good for you man
it can be so easy to go insane because u missed something that was in your face
oddnimbus is offline   Reply With Quote
