Welcome to the North American Subaru Impreza Owners Club Tuesday May 11, 2021
Old 09-19-2020, 10:43 PM   #1
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
Default Easy 10% power gain: wastegate as exhaust bypass
Solid lines = hp and tq with cutout
Dotted lines = hp and tq before cutout
+80whp! XONA Rotor 8269S 0.82 AR @40psi both runs
Running IAG Stage 4 extreme with stock crank + IAG stage 5 heads with Kelford 272s
I chose the PTE 66mm wastegate over a traditional cutout because it is made of materials that can stand up to exhaust gas heat and offer optimum seal. No failing electric motors or metal valves that don't seal causing exhaust leaks. The wastegate opens at 15psi boost pressure
Everyone should definitely do this mod if you want a quiet exhaust without sacrificing power when you get on it
user1029 is offline   Reply With Quote
Old 09-19-2020, 11:00 PM   #2
can250
Member#: 452601
great results why the difference in spool though
can250 is offline   Reply With Quote
Old 09-19-2020, 11:34 PM   #3
user1029
Member#: 57064
2008 STi IAG built
Less back pressure = quicker spool
Old 09-20-2020, 12:36 AM   #4
GalaxyWide
Member#: 383291
2004 Forester XT
Cayenne Red
No, the graph shows no cutout = faster spool. Therefore more back pressure = quicker spool.
GalaxyWide is offline   Reply With Quote
Old 09-20-2020, 01:00 AM   #5
user1029
Member#: 57064
2008 STi IAG built
Oops mislabeled by me
Dotted line is no cutout
Solid line is with cutout
I'll upload another graph
Old 09-20-2020, 11:14 AM   #6
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
your turbo and exhaust housing is to small for your power goals
Bariga is offline   Reply With Quote
Old 09-20-2020, 11:30 AM   #7
user1029
Member#: 57064
2008 STi IAG built
Honestly my power goal was 700whp and then I said what the hell and added the cutout, here I am at 800whp
Old 09-20-2020, 02:53 PM   #8
NighthawkSTI
Member#: 495630
??? there is more torque where the graph starts over approx. 800-1000 RPM ramp up from 3000 to 4000 WITH the cutout. Then they merge without the cutout and then with the cut out really takes off.
NighthawkSTI is offline   Reply With Quote
Old 09-20-2020, 02:58 PM   #9
NighthawkSTI
Member#: 495630
and it is a much quicker less expensive power gain than choosing another turbo. Nice job.
Old 09-20-2020, 03:31 PM   #10
user1029
Member#: 57064
2008 STi IAG built
My first dyno graph was labeled wrong lol
Old 09-20-2020, 03:32 PM   #11
user1029
Member#: 57064
2008 STi IAG built
Plus it sounds like a V8 when it opens
Old 09-20-2020, 10:22 PM   #12
user1029
Member#: 57064
2008 STi IAG built
You can get even earlier spool by running a wastegate spring that opens even earlier I didn't want to terrorize my local school zone just leisurely driving through it
Old 09-21-2020, 02:42 PM   #13
NighthawkSTI
Member#: 495630
a win win!
Old 09-21-2020, 03:19 PM   #14
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Most important thing is pre-turbo back pressure if you doing 40 psi and your back pressure is 60psi then your motor wont be happy camper
Old 09-21-2020, 03:32 PM   #15
Stretch18
Member#: 239822
2010 WRX
pandiculation
This should alleviate back pressure under boost. It might cause some turbulence at low boost, but even then can't be enough to even add as a footnote.
Honestly, I'm filing this in the 'great idea, but mad at OP that I didn't think about it myself' folder...
Stretch18 is offline   Reply With Quote
Old 09-21-2020, 05:51 PM   #16
user1029
Member#: 57064
2008 STi IAG built
Prior to doing this mod, I scoured every google result but nothing tangible. Hopefully I set a precedent with this solid test and hopefully nothing bad happens in the coming months
Old 09-22-2020, 11:12 PM   #17
user1029
Member#: 57064
2008 STi IAG built
Old 09-23-2020, 02:10 AM   #18
Gally316
Member#: 494541
2009 wxr
wrb
Is a tune required fore this mod?
Gally316 is offline   Reply With Quote
Old 09-23-2020, 06:26 AM   #19
user1029
Member#: 57064
2008 STi IAG built
Yup definitely, you will instantly run lean otherwise
Old 09-23-2020, 08:31 AM   #20
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No 2 ways about it, if your exhaust is a bottleneck you either need a cutout or a custom exhaust. This is the far more economical route as getting a larger diameter custom exhaust it big $... and it's still going to sap some power over a cut-out.
On a +700whp setup here's a 3" to 3.5" megaphone at the turbine outlet that transitions to 4" oval under the car, and back to 3.5" round at the muffler. VERY expensive. I don't recall what we lost over the dual side-pipe setup that was just deafening (even with a helmet on), I want to say ~30whp, but the full cat-back would allow you to hear a passenger without having to scream directly into their ear, lol.
KillerBMotorsport is offline   Reply With Quote
Old 09-23-2020, 09:40 PM   #21
scotte30m3
Member#: 409636
2015 WRX
I have a cutout like this on my 15 WRX. Been running it for years. Itís boost activated but also on a switch so I can use it when I want to and keep it quit when I need to. Itís mounted as a 3Ē dump at the end of the y-pipe just before the stock mufflers.
scotte30m3 is offline   Reply With Quote
Old 09-24-2020, 09:47 AM   #22
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Genius. So no vacuum lines or anything, just opens up on spring pressure? I have an old 38mm Tial I can use. Not as big but even little is better than none I'd imagine.
TyranosaurusWRX is offline   Reply With Quote
Old 09-24-2020, 04:53 PM   #23
user1029
Member#: 57064
2008 STi IAG built
Give it 15psi of boost and it'll open or whatever spring you choose. No need for any fancy solenoids
Old 09-28-2020, 12:58 PM   #24
subbi7
Member#: 241967
02 wrx
the spring pressure without any boost hose to the wastegate will keep 15psi pressure in youre exhoust system...
subbi7 is offline   Reply With Quote
Old 10-04-2020, 08:49 PM   #25
Xerxeys
Member#: 519125
Nice!
Xerxeys is offline   Reply With Quote
