Welcome to the North American Subaru Impreza Owners Club Sunday November 29, 2020
Old 11-04-2020, 05:35 PM   #1
luigi000
Member#: 514266
Default Neutral to 1st gear problem
Hey guys. Today at a red light I attempted to put car from neutral to first and had to go back and forth 3 times and push the clutch in and out before it went into gear.
Can someone inform me if this is something to be worried about or is a normal occurrence. Keep in mind it has happened a couple times before.
If it is a problem what would that problem originate from (synchros, tyranny etc)
The car is 2020 wrx with almost 6k miles. Stage 2.
It has a perrin shifter bushing and shift stop.
Thanks!
luigi000 is offline   Reply With Quote
Old 11-04-2020, 05:51 PM   #2
Vancouver98STi
Member#: 459287
1998 JDM Impreza STi
V4 GF8 White
Question
If it was an older car, I'd suspect that the clutch hydraulics needed to be bled... but with only 6000 miles, I dunno.
When you're experiencing the issue (and you're not in traffic), turn the engine off and see if it'll go into 1st gear easily. If it does, then it sounds like the clutch isn't disengaging enough (and bleeding may be required). If it still doesn't want to go into gear, then I'd suspect the shifter needs adjustment.
Vancouver98STi is offline   Reply With Quote
Old 11-04-2020, 06:58 PM   #3
Mr. Boost
Member#: 520001
2018 WRX
My guess is that your shifter stop is too tight. I initially set mine up with almost zero play in the 1-2 gate, but it was too hard to get into 1st sometimes so I had to adjust it.
Mr. Boost is offline   Reply With Quote
Old 11-05-2020, 04:58 AM   #4
TheClutchRider
Member#: 519866
2017 WRX Premium
WRB, what else
shifter stop too tight. i had that happen right after i installed mine
TheClutchRider is offline   Reply With Quote
Old 11-05-2020, 05:44 PM   #5
Blak-
Member#: 427432
2015 WRX
Agree with the others... check your shift stop. Also, I've found that if you can't get into first, you can throw the gear into second and then into first. That seems to help line things up and is more reliable than trying to go back and forth between first and neutral.
Blak- is offline   Reply With Quote
Old 11-22-2020, 01:36 AM   #6
John1218360
Member#: 520372
2015 Wrx
Thanks!
Had the same thing happen to my 2015 wrx 44k miles next time that happens put it into 2nd and then back into 1st should work good luck
John1218360 is offline   Reply With Quote
