Welcome to the North American Subaru Impreza Owners Club Friday November 27, 2020
Old 11-20-2020, 04:21 PM   #1
Conster102
Member#: 519178
Unhappy Reverted to stock airbox and AFR's are trash
2003 usdm wrx 5mt hatchback. It was running a garbage plastic k&n air intake with no tune when I bought it so I went back to stock airbox so my AFR's would go back to normal but this was not the case.
My only MOD is a grimmspeed decatted uppipe. Got a smoke test no vacuum leaks nor exhaust leaks nor CEL's. I have 2 logs one of me chilling under 3k rpms and one of me flooring it in 2nd gear. People tell me you can have a decatted uppipe with no tune so I do not understand what is going on.
I have recently changed oil, replaced AFR sensor in the exhaust manifold, cleaned my MAF, replaced both front cv's and it was recent adding the grimmspeed uppipe.
Do I need to tune it? If so what would you recommend? There is less backpressure so that would make me run rich anyway right? But my AFR correction is positive 25 meaning its running lean so I am confused. Also I do NOT have a wideband is that a necessity when looking at AFR's even with a mostly stock car.
Logs: https://drive.google.com/file/d/1nA8...ew?usp=sharing -cruisin
https://drive.google.com/file/d/1Va2...ew?usp=sharing - WOT
Also I am a noob so feel free to correct me on anything I assumed here
Last edited by Conster102; 11-20-2020 at 04:27 PM. Reason: I don't have a wideband
Conster102 is offline   Reply With Quote
Old 11-20-2020, 04:26 PM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
Did you reset the ECU and give it a chance to relearn? Also be sure you didn't cut the MAF o-ring or otherwise damage it when you cleaned it off, even a small cut in it will lead to weird behavior on throttle.
supermarkus is offline   Reply With Quote
Old 11-20-2020, 04:32 PM   #3
Conster102
Member#: 519178
O-ring like the thing that seals the MAF to the airbox? I honestly don't remember seeing one but wouldn't that be easy to detect with the smoke test? I did reset it and gave it a chance to learn and I was still regularly getting knock correction if I got into boost at all which prompted me to reset it this most recent time. How long does the learning process take? I guess the first time I only gave it a few days to learn but my IAM was at 4/16 so I decided to reset it.
Old 11-20-2020, 04:39 PM   #4
Conster102
Member#: 519178
So should I just baby it for like a month or two and check again?
Last edited by Conster102; 11-20-2020 at 04:43 PM. Reason: I found IAM on romraider. IAM an idiot
Old 11-20-2020, 04:47 PM   #5
supermarkus
Member#: 6971
2008 WRX STi
SSM
No, i don't use ROM raider. Don't own a WRX anymore. You can remove the maf and take the o-ring off and gently pinch and roll it around in your fingers. If there are cracks or nicks in it, those can be a source of error in your MAF readings. I had one little pacman bite out of my o-ring after pinching it during a cleaning and that made my car stutter and stumble on tip-in.
There's a technique to resetting your IAM and forcing it to 16 but I forget how it was done in those cars. something like left foot braking to hold rpm at 2500 in 2nd or 3rd gear for a number of seconds.
Old 11-20-2020, 05:16 PM   #6
Conster102
Member#: 519178
Oh yea I saw that somewhere on here before just need to find it again. I will check my O-ring. But my car doesn't like stumble or anything I just logged with IAM with romraider and I am at 8 which is an improvement but still not great. It just bothers me that with all OEM parts, save for the up pipe, the car would be struggling so hard to get correct AFRs and have to cut the ignition timing in half to run correctly.
Old 11-20-2020, 05:20 PM   #7
Zak6182
Member#: 481754
2017 STi Base
What did you clean your MAF with?
Zak6182 is offline   Reply With Quote
Old 11-20-2020, 05:31 PM   #8
Conster102
Member#: 519178
Inspected my O-ring and it was fine. Cleaned my MAF with this https://www.googleadservices.com/pag...gQIAxBa&adurl=
Old 11-20-2020, 06:01 PM   #9
Conster102
Member#: 519178
Unhappy
Found the trick https://forums.nasioc.com/forums/sho...d.php?t=302047 and I did the trick exactly as instructed but my IAM is still at 8. Is the air/fuel reading drawn exclusively from the o2 sensor in my exhaust manifold? I might try to return it and get another one. If the Subie dealer says I have no exhaust leaks nor vacuum leaks and my MAF is seated correctly there is no reason my IAM shouldn't be 16 right?
Old 11-20-2020, 07:58 PM   #10
Zak6182
Member#: 481754
2017 STi Base
Can you try swapping out the maf with a good one? I had weird issues with mine running rich and lean when the maf was going bad. Cleaning helped for little while but eventually I was cleaning it almost everyday
Old 11-20-2020, 09:52 PM   #11
Conster102
Member#: 519178
Yea that is prolly gonna be my last resort is getting a new MAF. The cleaner **** did not change anything so I donít feel like the MAF is going bad but I am going to return the afr sensor I got from NAPA and buy one straight from Subaru. If that doesnít work then I might try cleaning my fuel injectors with some of that gas additive (before I do that is that stuff baloney or does it actually work has anyone had success with it?) then I might cave and go for the MAF. Does anyone have any cheaper solutions or more simple solutions I could have potentially overlooked?
Old 11-21-2020, 02:50 AM   #12
tabrad
Member#: 157229
2006 STi
Wrapped Blue
A cheap option that many people do, is find someone with a similar suby that will let you borrow their MAF for an hour and take the car for a spin and see if the problem is solved.
tabrad is offline   Reply With Quote
Old 11-21-2020, 05:03 PM   #13
Conster102
Member#: 519178
Yea changed out the AFR sensor and nothing changed still trash Iím currently looking for someone to borrow their MAF
Old 11-22-2020, 10:29 AM   #14
benflynn
Member#: 515308
I can send u a known good MAF, I have half a dozen around here. Iíll throw a spare in my forester to make sure itís still legit and then send it on to ya.
benflynn is online now   Reply With Quote
Old 11-22-2020, 06:49 PM   #15
Conster102
Member#: 519178
Forreal? That would be super dope thank you so much man. A forester MAF will work?
