Welcome to the North American Subaru Impreza Owners Club Friday November 27, 2020
Old 11-21-2020, 10:18 AM   #1
Bcpierce86
Member#: 517478
Default Not impressed with cobb stage 2+ map (03 wrx)
I have all the supporting mods cobb has said I needed to run the stage 2 map on my 03 wrx. I flashed to stage 2+ebcs 93 octane a few weeks ago. I baby my car all the time and have put maybe 200 miles on the car since going stage 2. I finally floored it to redline in 2nd and 3rd gear merging onto the interstate and wasnít impressed. My question is, is babying my car (never more that 1/2 throttle and not going over 4K rpm) making my car run slower and not learning the tune fully? Do I need to get on it more often for my computer to learn the tune and adjust to get its full potential?
Bcpierce86 is offline   Reply With Quote
Old 11-21-2020, 10:33 AM   #2
Zak6182
Member#: 481754
2017 STi Base
If you have an STi did you have it in Sport Sharp? How much boost are you seeing?
Its been a while since I went stage 2 but I remember it being fairly noticeable increase in power. IIRC I was hitting around 18psi in sport sharp (STi).
Things like crappy fuel can also be holding you back. If not already, you should be watching DAM, feedback knock and fine knock learning.
To kind of answer your question though. Personally when I went stage 2 (and again at stage 3) I drove it to operating temp and pushed it a little (12-15 psi), parked to check everything over and then went for a few wot pulls. I remember going stock to Cobb 2 being more noticeable then going stage 2 to stage 3, but that was expected.
Zak6182 is offline   Reply With Quote
Old 11-21-2020, 10:40 AM   #3
Bcpierce86
Member#: 517478
Iím sorry. I forgot to post itís a 03 wrx.
Old 11-21-2020, 12:16 PM   #4
snow_bound26
Member#: 395793
2005 92x Aero
Blue(retired�ȸ
Have you done all necessary maintenance items such as:
-Replacing all vacuum lines
-Replace turbo inlet
-Replace or at least clean the MAF
-Replace air filter
-Replace spark plugs and make sure they are gapped properly
-Check for exhaust leaks pre-turbo
-check for intake/TMIC hose leaks
You have an 03, it's old and will need all of these things done. If it's a high mileage engine and compression is on the lower end of acceptable than you may not feel as much difference as you had hoped. Without knowing what kind of maintenance has been done it could be any number of things. If all of the mentioned maintenance has been done, it wouldn't hurt to have a compression and leak down test done just verify the health of your engine.
As for the ECU itself, yes it does take time to adjust to your driving habits. It's good to be aggressive with the throttle a few times a week to keep the ECU in a learned condition. Honestly it's also healthy for the engine in general. Obviously, beating on it relentlessly is bad, but taking it to within 200-300 from redline a few times a week is healthy for performance engines.
snow_bound26 is online now   Reply With Quote
Old 11-21-2020, 01:34 PM   #5
oichan
Member#: 492327
19 WRX 16 STI
17Golf-R 16FiST 20Supra
I had a modded 02 WRX long time ago (new) with U-Tech (it was a piggyback). The car's weakness is the gearing. You really have to launch the car from a standstill potentially shattering your glass tranny to squeeze out any level of real acceleration. The car sucked at rolling starts and pulls from 2 or 3rd.
It was fast for its time but that was near 20yrs ago.
oichan is offline   Reply With Quote
Old 11-21-2020, 02:27 PM   #6
Bcpierce86
Member#: 517478
-Replace air filter
All the maintenance you stated has been done as soon as I got the car home.
I boost leak tested it to 20psi and the only leak (if itís even a leak) I hear comes from the turbo compressor housing itself but I cannot find a leak, no bubbles with soapy water.
Current mods are
Cobb sf intake, cobb 3 port ebcs, stock fuel system. Unknown name unmarried downpipe, bpm exhaust from there back. Mitsumoto intercooler hoses. Cobb AP v3. Stock headers and stock uppipe.
just logged a 3rd gear pull. I just have to figure out how to post the log
Old 11-21-2020, 05:06 PM   #7
Winterhawk
Member#: 463763
2002 WRX Sedan
Blaze Yellow
My '02 is a stage 2+ with a K&N filter in stock housing, Cobb catted up and down pipes, Cobb 3 port ebcs, and Invidia Q300 exhaust. It's a noticeable difference from stock and pulls great in 2nd and 3rd when rolling. I rarely launch fast in first, but when I do it's very quick. Couldn't be happier with it so far as DD tune. Not sure what to tell you other than double check everything that could possibly be suspect. Sounds like you bought the car this way, or did you do the upgrade?
Winterhawk is offline   Reply With Quote
Old 11-24-2020, 08:57 PM   #8
Bcpierce86
Member#: 517478
I bought the car with the turbo back exhaust. And then I was told I needed the stage 2 tune for it to run right, so I bought a AP v3 and flashed to stage 2 right away. The car was acting up bad like shuddering and wouldnít rev over 3. I thought it was a boost least so I tested it and then just bought the intercooler pipeing to see if that would fix it. No go, so I bought the intake because it had an injen cai and I thought that would be the problem. Long story short... dirty maf. It was running strong and felt faster before I got the AP and flashed it to stage 2. Car didnít act up from the dirty maf until after the stage 2 map was flashed.
Old 11-24-2020, 10:37 PM   #9
snow_bound26
Member#: 395793
2005 92x Aero
Blue(retired�ȸ
As you add mods to your car the ECU becomes more sensitive. Just part of the process
Old 11-25-2020, 12:54 AM   #10
Bluestreak03
Member#: 125887
2001 EJ207 RSTi, Blo
Mica Blue
Clearly stated 03 WRX... Anywho do you have the Cobb to read gauges on? And which? Or do you have gauges? What you have to remember Cobb tunes are blanket tunes, one size fits all but may need to be washed and ironed out afterwards... Hit me up
Bluestreak03 is offline   Reply With Quote
Old 11-25-2020, 11:56 AM   #11
cknowlen
Member#: 189077
2011 STI limited
take note of when the OP was edited, and the post immediately after the one you are calling attention to.
cknowlen is offline   Reply With Quote
Old 11-25-2020, 01:44 PM   #12
Bluestreak03
Member#: 125887
Mica Blue
Noted... But at the same time both were edited on the same day, irrelevant... Regardless still need to know what the car is doing from a computer/mechanical standpoint... Give us more info
Old 11-25-2020, 04:00 PM   #13
rtv900
Member#: 428511
2016 STI
Mine is much newer and I didn't do mechanical mods, just a tune, but I've flashed it a few times now.
My experience is that Yes, the tune starts off conservative and it takes quite a while to "learn" up to full potential, and Yes you do need to get on it hard a bunch of times in a few conditions to get that.
I actually just flashed mine from 91 octane to 93 just the other week and the 93 tune felt worse at first and it took a solid week or two before it came up to power.
Now it is slightly better than the 91, which is kind of what I expected.
But think about it, the ECU can't really learn its way to max power if you don't give it full load conditions otherwise it wouldn't be learning, it would just be like an old school mechanical setup where it comes right out of the box tuned at it's max, defeating the whole purpose of ECU learning.
rtv900 is offline   Reply With Quote
Old 11-25-2020, 05:24 PM   #14
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
Current mods are
Is bolded above a typo perhaps? Stock, 2003 WRX, uppipe...with the cat converter in it still? A 17 yo cat? If not a typo...there's your performance killer.
Does the UP have a fat section up top and a wire coming out of it and going to a 3 or 4 wire engine harness on the passgr sidewall near the strut tower? If yes, remove that bastard ASAP.
oaklandish_WRX is offline   Reply With Quote
Old 11-25-2020, 08:03 PM   #15
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
You have not replaced your OEM Boost Control Solenoid. Do so with an OEM from Subaru unit.
You have not replaced your OEM Mass Air Flow Sensor. Do so with an OEM from Subaru unit or a legit Denso unit, not some knock off for $39.95 from ebay.
If you have not done these two things, you will never see the full power from the tune. There could be other issues, but these are paramount.
Old Yesterday, 12:42 AM   #16
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Best advice in this thread so far. At that age those items are likely badly degraded.
Edit- another possible item that may need replacing is the coil packs, they do go bad eventually. If you are running on 3 cylinders the power will be a lot down.
speedyHAM is offline   Reply With Quote
Old Yesterday, 12:39 PM   #17
samb
Member#: 177235
2016 Focus RS
2002 WRX Wagon
Theres mine for reference. Cobb Stage 2 off the shelf tune. Dont know if that helps but I went out and took that just for you.
samb is offline   Reply With Quote
