Welcome to the North American Subaru Impreza Owners Club Sunday November 29, 2020
Old 11-21-2020, 10:52 PM   #1
GK1707
Member#: 373868
'04 STi
Default 04 STi - Blouch 20G-XTR, ID1050X
Wanted to share my setup/dyno sheet here as I think its a great street setup. It spools great and makes IMO, perfect power for city/highway driving.
This was tuned last summer at EFI Logics by Calvin Dotson. Since then I've got about 6k miles on this setup.
It made 325WHP - 323WTQ with Pump 93 on their mustang dyno @20psi
- All home installed by me and tuned at EFI Logics
MODS:
- Built EJ257 (Cosworth pistons, King bearings, OEM STi Rods+ARP rod bolts, KillerB Pickup, 11mm Oil pump)
- Stock B25 heads and stock head Bolts/ HG
- Blouch 20G XTR 8CM Stock inlet size
- BNM External gate up pipe
- Precision 46mm EWG
- ID1050X, ID Fuel Rails and ID Lines(top feed conversion)
- TGV Deletes and EVAP deleted
- Spearco TMIC
- IAG Big Maf Intake
- APS Hard aluminum inlet
- GS 3port EBCS
- AEM 340 FP
- NGK 1 step colders
- TiAL Q BOV
- SRS Bellmouth Catless DP
- SRS Type 2 RE 3in catback
- S2 Industries AOS
- OEM 4th Cyl cooling mod
- 255/35/18 Achilles atr sport 2 (if that matters to anyone)
GK1707 is online now   Reply With Quote
Old 11-22-2020, 12:24 AM   #2
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Midnight Black Pearl
That looks like some pretty EPIC spool.
How does it feel to drive?
K3rm1tth3fr0g is offline   Reply With Quote
Old 11-22-2020, 01:13 AM   #3
GK1707
Member#: 373868
'04 STi
It brings a smile to my face every time. The ball bearing turbo was a good call. I hit full boost 20psi at around 3500 it takes off like a rocket and it holds it all the way to redline.
Old 11-22-2020, 04:25 PM   #4
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
The 20g-xtr is a great match for that STI tranny. The gear ratios are perfect. And you have a perfect setup to go flex fuel as well, which will really push you back in the seat. Those are strong numbers on a Mustang dyno!
Dave D. is offline   Reply With Quote
Old 11-22-2020, 05:46 PM   #5
tabrad
Member#: 157229
2006 STi
Wrapped Blue
Wow that spools surprisingly quick. XTR's are great!
tabrad is offline   Reply With Quote
Old 11-23-2020, 03:12 PM   #6
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
I wonder if he would need slightly larger injectors to go flex fuel on that beefy of a setup. Maybe not tho
@GK1707 What duty cycle are your injectors @ under full boost on pump gas?
Old 11-23-2020, 03:31 PM   #7
GK1707
Member#: 373868
'04 STi
That I haven't actually logged (I need to take a WOT log some time soon so I will post it when I do).
Based on Fuel Injector Clinic and Injector Dynamics fuel calculators this setup with these injectors on flex would be around 75-85% IDC (I'll need to take an actual log to be certain how much duty I'm running) but that seems a bit much for my liking.
So I've been certain 1300 or 1700s would be safer for flex. When it comes to that point I may just bump up in turbo size also and move to an ELH.
Old 11-23-2020, 03:54 PM   #8
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Yeah that 100% makes sense. I am switching from 1050s to 1300s when going flex fuel on a 2.1 stroker.
Old 11-23-2020, 06:06 PM   #9
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
That has always been one of my favorites for a daily street driven setup. 20g xtr, id1k's and ewg. I was easy to make a safe but very quick car in the 400hp/400tq area. and pulled great.
Nice set up
robbieshonda is offline   Reply With Quote
Old 11-23-2020, 07:28 PM   #10
GK1707
Member#: 373868
'04 STi
Yeah having more headroom would be much better. Im sure I would have had no issues with IDC tuning flex fuel on these ID1050x (could have probably turned it up to 23-24PSI on E85) but I figured I'd save the flex tune for when I decide to go bigger turbo, injector and make some other upgrades.
Nice set up
Id for sure recommend this setup for anyone dailying their STi. Awesome usable power throughout the rpm band. On flex fuel, this setup is absolutely capable of 400/400... probably more on a dynojet.
Old 11-25-2020, 11:25 PM   #11
Jonathankogel
Member#: 519837
Good numbers for sure.
Jonathankogel is offline   Reply With Quote
Old 11-27-2020, 06:53 PM   #12
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
I did that. When I bumped my injectors to 1300 for flex fuel, I also went to a Dom 1.5xtr. Just had ELH headers installed, as my UELs had cracked. Very pleased with the results overall.
