#1 |
Member#: 67004
SCIC
Vehicle:02 vf30 pnp wagon silver and cf |
![]() I found that there are questions as to what diff is what ratio and year. As well as oem diff type.
I found a r180 for cheap when I looked it up some stupid person put 08+ was 3.9. It's not it actually 3.54. So now I have a diff I can't use for my project.
#2 |
Member#: 395793
Vehicle:2005 92x Aero Beige |
![]() +1
Sucks that people don't know that final drive and diff gearing can be different. |
#3 |
👏 Big Ron 👏
Moderator Member#: 18062
![]() Love to have one but we'd all have to contribute, here's what I have. I just researched all the WRX drive ratios and these are 99% legit from 2002 to present. Everything else is suspect.
![]() ![]() Found this info on legacygt.com regarding the markings on the diff carrier, as it relates to final drive and the type of differential installed. Unless the carrier has rusted over too much, you will find one of the following codes (2 uppercase letters) painted in white on the diff carrier. Code---Reduction gear ratio---LSD CD --- 4.444 --- Viscous CF --- 4.444 --- Viscous EW --- 3.900 --- Viscous HY --- 3.545 --- Torsen JE --- 4.111 --- Viscous T1 --- 3.900 --- None T2 --- 4.111 --- None TP --- 4.444 --- None XJ --- 4.111 --- None XU --- 3.272 --- Viscous XZ --- 3.083 --- Viscous WRX transmission (2002-2005) WRX FD 3.90 (Front 3.9 center 1.1 rear 3.545) WRX transmission (2005-2006) WRX FD 3.70 (Front 3.70 center 1.0 rear 3.70) WRX transmission (2007-2014) WRX FD 3.90 (Front 3.9 center 1.1 rear 3.545) WRX transmission (2015+) WRX FD 4.11 (Front 4.11 center 1.0 rear 4.11) FXT transmission FXT FD 4.444 (Front 4.44 center 1.0 rear 4.44) Legacy GT transmission Legacy GT FD 4.11 (Front 4.11 center 1.0 rear 4.11) Outback XT XT FD 4.444 (Front 4.44 center 1.0 rear 4.44) STi transmission STi (USDM) FD 3.90 (Front 3.90 center 1.0 rear 3.90) Please use the above as a copy/paste then change as you find info! Last edited by Unabomber; 12-21-2020 at 12:45 PM. |
#4 |
Member#: 175624
Vehicle:0304 WRX WRX SY WRB |
![]() The Rallispec list is pretty comprehensive if you can get the part number off of the transmission you're buying. It tells you final drive and transfer ratio.
https://www.rallispec.com/downloads/...art_Public.pdf edit: but it only goes up to ~2011 it seems |
#5 | |
Member#: 138994
Vehicle:2006 WRX, 6MT, 5x114 |
![]() Quote:
(2004-2005) STi (USDM) FD 3.900 (Front 3.900 *center 1.00 rear 3.900) (2006-2007) STi (USDM) FD 3.900 (Front 3.900 *center 1.10 rear 3.545) (2008-2009) STi (USDM) FD 3.900 (Front 3.900 *center 1.10 rear 3.545) - I am pretty sure the Ralispec chart having the TR at 1.103 is a typo (2010+) STi (USDM) - I am less familiar with the newer MYs but from what I understand they are have same specs as 2008-2009. At least of the specs we are outlining here. *"center" is actually the transfer gears ratio, not the Cdiff itself Last edited by JarHarms; 12-22-2020 at 08:40 AM. |
