Go Back   NASIOC > NASIOC Subaru Models > Crosstrek Forum
Old 03-01-2021, 10:46 AM   #1
DRNWAGN
Member#: 44255
2021 Cross Trek
Cool Gray Kaki
Default Suspension Questions
Figured I'd take a shot here though it doesn't look like there is much CrossTrek love on this board.
Anyone know if the WRX/STI suspension crosses over to the CrossTrek? I mean could I pull the struts/coils out of one and put on the other? I know I was able to do that in my old FXT back in the day just curious if they share a similar chassis.
Obviously, if they can be then it opens up a lot more options with regard to what is available for a suspension upgrade for the car. My plan is to install some coilovers on it within the next year. Not to lift it but to lower it!
Thanks in advance. Yes I searched and didn't really find anything on this
DRNWAGN is offline   Reply With Quote
Old 03-08-2021, 02:47 PM   #2
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
If you find out, please post what you find here. I've been looking for a way to lower my Crosstrek and know it can be done (have seen some in person). What I've found out so far is that the front is completely different from an Impreza, which lots of people have been surprised about, then have been stuck with Impreza set ups that they assumed would work.
I'd sure like to find spring/shock set ups that'll work.
Old 04-10-2021, 01:19 PM   #3
iLaw
Member#: 275836
2020 Crosstrek
Sunshine Orange
I would be really surprised if the WRX/STI suspension fit the Crosstrek. The 2018+ Crosstrek brought the product line to the Subaru Global Platform. A move that the WRX/STI has yet to make. In addition to that, starting in 2015, Subaru started making the WRX/STI distinctively different than the Impreza, which meant that the shared parts between the two platforms are even more limited now.
I'm no authority in these things, but from my limited knowledge of the Subaru platforms, I don't think you will find many common parts between WRX's and Crosstreks.
iLaw is offline   Reply With Quote
