Welcome to the North American Subaru Impreza Owners Club Monday April 12, 2021
Old 04-05-2021, 09:29 AM   #1
jjpaul
Member#: 474355
Default Clutch Advice
I had a bad throw out bearing at 100k and because of the labor cost decided to replace the clutch and pressure plate at the same time by a local transmission shop. I didn't know it was the TOB at the time but I had heard a noise for quite a while and was able to drive it to the shop when the noise got really bad. Now 165k on car.
2 days ago i began hearing a noise when pushing in the clutch in, in the am. In the PM I took the car out and didn't hear the noise. Yesterday morning heard it again and drove out and back maybe 15 miles. Started making a lot of noise a mile from home when pushing in the clutch and petal didn't feel right and car would stall at stop signs. Made it home and the petal feels almost no resistance and will stay depressed but can bring it back with my toe.
Fluid is clean and in reservoir, no leaks seen at slave cyl, master cyl or hose or line. There is slight tacky substance at bottom of boot on slave cyl. I pulled boot back and didn't notice any fluid inside of boot.
My questions:
Is there any was to diagnose what the problem is and if not opinion on what it might most likely be?
What pressure bleeder would you recommend to bleed slave cyl?
Car is not driveable and I plan on repairing myself car is a 2010.
Thank you for any help.
jjpaul is offline   Reply With Quote
Old 04-07-2021, 11:16 PM   #2
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
Clutch Master Cylinder
$50 part
Maybe 2 bolts and 2 fluid lines
Will need to bleed thou
100 times easier than bleeding brakes
Long time ago but think was only 5-7 presses on clutch pedal to bleed bc of such small
system
Now I dont know if u have intercooler bc no profile but IC would need to be removed if u have
GL
AliBenn is offline   Reply With Quote
