Welcome to the North American Subaru Impreza Owners Club Thursday June 24, 2021
Old 05-06-2021, 08:40 PM   #1
Subie_3143
Member#: 523449
Default 02 Impreza wrx manual swap
How do I make the speed sensor work for my manual swap from a 05 legacy gt to 02 Impreza wrx ? And also if anyone knows how to wire everything else that would be a plus thanks in advance .
Subie_3143 is offline   Reply With Quote
Old 05-06-2021, 09:03 PM   #2
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Legacy measured speed at the hub. Your WRX measured speed in the trans. You have to open up the trans and add everything for the speed sensor to use one from a Legacy.
snow_bound26 is online now   Reply With Quote
Old 05-07-2021, 10:37 PM   #3
Subie_3143
Member#: 523449
Aaah ok makes sense but also another question what do I do about the axles since the lgt axles are shorter ?
Old 05-07-2021, 10:49 PM   #4
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Legacy was almost identical width as the WRX. How much shorter are they?
If they don't work just get 05 WRX CV axles. They will have the correct male input shaft.
Old 05-11-2021, 08:48 AM   #5
Subie_3143
Member#: 523449
My bad for the late response got a new phone but their like half an inch shorter I believe I can add a picture if need and will 05 wrx ones work then ? With the legacy trans and length?
Old 05-11-2021, 10:11 AM   #6
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Car dimensions change, not the transmission size unless you're talking about 5 vs 6 speed trans. And that's only in terms of length since the 6 speed is a little longer than 5 speed. 05 WRX cv axles will work
Old 05-11-2021, 11:36 AM   #7
Subie_3143
Member#: 523449
Oh ok and so the 05 are male?
Old 06-10-2021, 05:19 PM   #8
Ebradley
Member#: 524800
Good to know
Ebradley is offline   Reply With Quote
