Welcome to the North American Subaru Impreza Owners Club Tuesday July 27, 2021
Old 07-17-2021, 12:04 PM   #1
TY-TAR
Member#: 524842
Default new to Subaru and having trouble
i picked up an 2004 STI recently and when driving it home it broke down i took it to a shop and they said it was the clutch (the guy i bought it from said he just replaced it but had no proof so i had it replaced ) then they said it was a bad transmission and i didn't believe that so i took it somewhere else and it needed up being the axle so 3,000$ + the price of the car i got it home and i drove it another 10 miles and it started having idle issues and running lean and there is smoke coming out of the oil cap area and turbo area and now there is a cylinder 2 misfire it sounds like i'm going to need a new engine am i wrong ?
TY-TAR is offline   Reply With Quote
Old 07-17-2021, 07:36 PM   #2
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Ya, sorry for the bad news but you'll probably need a new eng. Sounds like ringland failure. Do a compression test and a leak down test.
What do you mean "it died"? Like how? Is it stock?
BlackFighter is online now   Reply With Quote
Old 07-19-2021, 02:53 PM   #3
aidanmurphy
Member#: 512054
2009 WRX Hatchback
Default Sad
Very unfortunate. Sounds like previous owner knew the car was a ticking time bomb. Leak-down and compressions test to assess the extent of the damage, might be looking at a new engine
aidanmurphy is offline   Reply With Quote
Old 07-21-2021, 11:42 PM   #4
ilovedemhotrides
Member#: 326147
2004 STI
wrb
As others have said. Doesn’t sound great. Ringlamds. Do a leak down test to confirm
ilovedemhotrides is online now   Reply With Quote
Old 07-22-2021, 12:06 AM   #5
BlueSTI4Me
Member#: 34361
04.7 STI
WRB IG @got2boostit2
Wow, feel bad for you.
BlueSTI4Me is offline   Reply With Quote
Old 07-22-2021, 10:23 AM   #6
Jp925
Member#: 510046
Can you give anymore info on the cars history? Miles? Did the car have any paperwork such as maintenance records? Mods?
Your first order of business needs to be a leakdown test. This tells you if you have air leaking out of rings or valves. This will tell you really what you’re up against. I would also highly suggest you dump the oil, see what color it looks like, smells like, is it low? And stick your finger in the oil plug hole and feel for debris. Lastly budget accordingly because you might be in for a good build.
Jp925 is offline   Reply With Quote
