Welcome to the North American Subaru Impreza Owners Club Friday October 22, 2021
Old 10-10-2021, 02:51 PM   #1
jeff6666p
Member#: 400078
1998 2.5rs06wrx swap
black
Default Battery voltage drop
How accurate is the cobb accessports battery voltage? When the higher the revs in see the voltage drop. I see 13.2 above 4.5-5k.
jeff6666p is offline   Reply With Quote
Old 10-11-2021, 05:52 PM   #2
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
With a similar swap
I would just get volt gauge
The AP might show accurate readings
AliBenn is offline   Reply With Quote
Old 10-12-2021, 07:12 PM   #3
jeff6666p
Member#: 400078
black
Originally Posted by AliBenn View Post
With a similar swap
Do these cars shut the alternator off at higher loads? I put in the other alternator and Iím still dropping voltage to 13.12 under higher rpms
Old 10-12-2021, 10:15 PM   #4
Marvick08GT
Member#: 469091
Fairly typical with subarus. You can trick the Alternator into running higher voltage if desired.
"Alternator Diode mod"
Good luck!
Marvick08GT is offline   Reply With Quote
Old 10-13-2021, 08:14 AM   #5
rtv900
Member#: 428511
2016 STI
this is exactly why you don't monitor nonsense data with no context
why would you worry and consider doing some work to something because your alternator outputs a lower voltage in a certain rpm range?
If it is right when the car idles that means it is working perfectly
rtv900 is offline   Reply With Quote
Old 10-13-2021, 06:07 PM   #6
jeff6666p
Member#: 400078
black
I have a shorai lithium battery and the lower voltage could damage it. Also I was having issues with the car jerking when giving more then half throttle and low voltage can cause issues like that. After I put the 90 amp one in it was much better.
Old 10-13-2021, 08:53 PM   #7
Marvick08GT
Member#: 469091
Search the mod, it is necessary for racing batteries.
