#1 |
Member#: 515683
NWIC
Vehicle:2013 STI Hatch Satin White Pearl |
![]() Finally making a post about my car. Car has been tuned since 4/20/22
Car: 2013 STI Hatch Dyno: Mainline AWD1200 Location: Infront Automotive, Auburn WA Tuner: John Ambient Temp: 50° Weather: Cloudy Elevation: 80' Stock 2021 STi results on this dyno: 200 WHP 200 WTQ Fuel: 92 Octane and e77 Peak HP (92): 320WHP at 5684 RPM Peak TQ (92): 324WTQ at 4528 RPM Peak HP (e77): 371WHP @ 5790 RPM Peak TQ (e77): 401WTQ @ 4400 RPM Target boost: 24 PSI Gear used for tuning: 3rd Engine management: COBB Accessport V3, Hybrid Speed Density The non-embedded link shows the e77 touch up tune where I got 401WTQ https://imgur.com/a/8J1MZ8G ![]() Power IAG Stage 2.5 Closed Deck Blouch Dom 1.5xtr 2.4" inlet, 8cm^2 hotside PTP lava blanket VA STI TMIC OEM BPV Radium FPR Cobb (ID) 1300x injectors Aem 340 Cobb rails Cobb FlexFuel kit Radium Surge Tank TGV deletes Killer B inlet COBB SF intake and airbox with factory snorkel COBB Turbo Back PLM EWG up pipe (Ceramic Coated) TiaL 38mm EWG at 13.01 psi Grimmspeed EBCS Grimmspeed heat-shield AEM intake air temp sensor IAG AOS Koyo radiator GDT Cylinder 4 Cooling mod Killer B Swain Tech coated Holy headers Killer B pickup Suspension Tein Flex Z coilovers Whiteline 22mm front and rear swaybar kit w/ rear sway bar brace Whiteline endlinks Whiteline anti lift kit Drivetrain Fluidampr Group N Pitch stop Group N Transmission Mount Group N Engine Mounts TiC Tranny crossmember mounts Kartboy short shifter and bushings Mach V Wicked Awesome Wheels 18x9.5 Bronze Continental DW06+ 265-35 Anything I didn't list is stock/OEM (or I forgot). There are a few cosmetic mods I didn't include. Originally, I planning on only adding bracing and a few more cosmetic mods after getting tuned but it looks like I'll be spending at least a little more on power mods very soon. I picked up my STI Hatch in August 2021, my previous car was a Stg2+ 2002 WRX wagon. My original plan was to build up my bugeye with an STI trans and an ej257 but I a '13 hatch for sale locally that already had a IAG block in it so sold my wagon and picked up the hatch. My hatch was originally going to stay on pump gas but I got talked into going flex fuel and things spiraled out from there. The car is amazing to drive, there is just so much more power everywhere, always a giant smile on my face whenever I drive it. For the most part, it's very well behaved on the street but the throttle in S# is a little touchy but that's an easy enough fix. Now for some bad news. On 5/21/22, I was driving back from riding Tiger mountain and filling up on e85 when I started to struggle to get into boost. Boost didn't start to come on until around 4500 rpm and was peaking ~13 psi. I didn't think much of it at the time but when I was coasting down hwy 18, there was a metallic rattle/pinging sound (not knock) that went away after a few minutes, not sure if this is related to not being able to build boost but it most likely is. AFR and fuel trims are fine and I'm not seeing any misfires. Most likely something went on the turbo (which was brand new and had less than 1000 miles on it). I currently have Covid so haven't torn the car down yet but planning on checking my oil for metal and sending a sample off, taking the dp off to inspect the turbine, and then most likely taking the turbo off and inspecting it. So this leaves me with a conundrum, if it is the turbo, do I get a exact replacement, do I get a dom 1.5 with the 3" inlet and a 10cm^2 hotside, or do I get a completely different turbo. I saw a post from an Australian tuner that had a new gen 2.5xtr that Blouch hasn't released yet, that could be fun. I was hoping I'd be done spending money on the STI so I could start saving for a new DH bike but oh well.
#2 |
Member#: 130990
NWIC
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
![]() You have nearly an identical setup to mine. Nearly, as I do have the 10cm Dom 1.5, plus built heads with Kelford 199-b cams. I have read that the 10cm makes a difference -- my buddy Kermit can chime in regarding the 10cm 20g-xtr he has on his 2-liter build. With the Killer B headers you should definitely go for 10cm. Here's my graph from the same shop:
#3 |
Member#: 508105
NWIC
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
![]() Quote:
But that Dom 2.5 G2 looks mighty fine... That's where my vote goes ![]() Rip your Dom 1.5 Dave, IIRC I sent you this dyno sheet a while back when it was generated to discuss the difference the built heads and 10cm makes. Your car also weighs less with no brembos, R160 and if course being a GD vs GR. OP is also a friend of mine hence why I had access to the dyno sheet hot off the presses haha ![]() Last edited by K3rm1tth3fr0g; 05-28-2022 at 01:53 PM. |
#4 |
Member#: 515683
NWIC
![]() Quote:
Only reason I ended up with the smaller hotside was because I got in BNIB with a coated hotside for a really good price from someone on here. If I bought it directly from Blouch, definitely would've gotten the 10cm^2. I've actually been talking with Kermit for awhile, he was trying to get me to trade him my 1.5 for his 20g so I would have the 10cm hotside and he'd have the 8cm for his 2 liter ![]() |
#5 | |
Member#: 508105
NWIC
![]() Quote:
Though a 10cm would definitely be a benefit your build imo. Last edited by K3rm1tth3fr0g; 05-28-2022 at 02:56 PM. |
#6 | |
Member#: 515683
NWIC
![]() Quote:
#7 |
Member#: 508105
NWIC
#8 | ||
Member#: 130990
NWIC
![]() Quote:
Electrin's motor makes 360+ from 5000rpm to 6000rpm, a much narrower peak powerband. The torque curves are similarly affected. To me it has to be mostly the cams. Quote:
#9 | |
Member#: 508105
NWIC
![]() Quote:
Here's the link to the post about the new Dom 2.5. https://www.facebook.com/25730308770...iuQl/?sfnsn=mo |
#10 | |
Member#: 515683
NWIC
![]() Quote:
![]() The new dom 2.5 looks sweet but it would most likely require a full on retune while the dom 1.5 with the larger inlet and hotside would only be some touch up tuning. What I end up going with will depend on what I find when I start to take the car apart. |
#11 |
Member#: 515683
NWIC
![]() Well, finally got around a to draining the oil and say A LOT of glitter in it. First time I've seen any glitter and I only have a little over 1000 miles since the tune.
![]() Going to send a sample off to Blackstone but I'm not hopeful. It's weird though, I don't have a rough or noisy idle and everything else seems to be fine. I wonder if my turbo bearings ate themselves, dumped metal into the pan, and then the rest of the engine is fine. Not likely but very very wishful thinking ![]() |
#12 |
Member#: 508105
NWIC
![]() Truly it is a sad day
#13 |
Member#: 130990
NWIC
![]() That's really a shame. I wonder if there's any way for you to find out the exact history of that block that came with the car.
#14 |
Member#: 515683
NWIC
![]() All I know is the mileage. Rest I just have to go off the previous owners word that he broke it in correctly and did oil changes every 3000 miles.
#15 |
Member#: 130990
NWIC
![]() You just never know when you buy a used built motor. The good news is in buying the Sti you have an excellent platform and certainly if the motor itself is not useable you already have many of the parts so as not to start a new build from scratch. Best of luck!
#16 | |
Member#: 422118
![]() Quote:
#17 | |
Member#: 515683
NWIC
![]() Quote:
C'est La Vie |
#18 |
Member#: 515683
NWIC
![]() I was hoping I'd be good since the shortblock came directly from IAG. I verified it was actually a stage 2.5 closed deck and the guy I bought it from showed me the receipt. But as you said, you never fully know with used purchases.
#19 |
Member#: 515683
NWIC
![]() Finally got my UOA back from Blackstone today. Oil used was Motul 8100 5w-40 and had just a tik over 1000 miles on it. Report showed high levels of 4 elements (first number will be what was in my oil and 2nd will be the universal avg. Al (5 vs 4), Fe (13 vs 9), Pb (4 vs 2), and Si (68 vs 10). The oil itself looked good with no fuel dilution or coolant.
The high level of silicon is most likely due to using silicone grease when installing the new fuel system (injectors, lines, rails, etc.) The aluminum is sort of confusing since I'd assume if it came from the piston, there would also be high levels of copper, magnesium, and nickel since my pistons are 2618 but I could be wrong about that. There is a higher amount copper and magnesium in 2618 than iron or silicon so I don't think those elevated numbers are from the pistons. Since my turbo is bb and not journal, I don't think the elevated levels of lead are from the turbo bearings since ball bearings typical don't have lead alloyed in them so the lead is most likely either from the main, rod, or camshaft bearings with the elevated level of iron being from either the crank or the cams. The car has always made low oil pressure on 5w-40 and would hot idle 12-18 psi, cold start around 80, and cruise around 60-70. Based on this and what (little) knowledge I have about the oil path on EJs, I think it would make the most since if the lead and iron came from the heads since I believe they would see the affects of lower oil pressure the most, besides the turbo. This is obviously just speculation at this point and won't be able to confirm anything unless the engine is torn down. I've since put in Motul 6100 10W-40 and am seeing much better pressure now. Hot idle is 18-24, cold start high 95-100, and cruising is 70-80. I've driven around 100 miles on the new oil (and filter) and there aren't any weird noises or hesitations while driving. I'm going to take another sample at 1000 miles on the heavier oil (if it makes it that far) and see what the results are. The not building boost issue ended up being very simple, my iwg bracket ended up vibrating loose so the iwg was no longer sealed shut. The Cobb kit didn't come with a jam nut, a quick trip to ACE fixed that. I'm now building full boost again. I guess only time will tell at this point if my engine will explode soon or not. One things for sure, definitely not taking it anywhere thats further than 50 miles from my house |
#20 |
Member#: 130990
NWIC
![]() Yes, I'd say 5w-40 is a bit thin for a built motor. I run 15w-40 in mine. Glad it was just an iwg issue.
I do the same with my car -- no long trips anymore. For that it's my trusty well-maintained 2008 Jeep or my wife's 2015 Crosstrek. |
#21 |
Member#: 515683
NWIC
![]() IAG recommends Motul 5w-40 for pump and 10w-40 for e85 on their Stage 2.5. Honestly might bump up to a 5w-50 but we will see how this current oil change goes.
Unfortunately I'm doing what you shouldn't and dailying the project since it's my only car but I'm young and dumb, or at least thats my excuse. Also don't have the space for two cars currently. |
#22 |
Member#: 515683
NWIC
![]() I probably should've immediately switched to 10w-40 when I firt saw that 5w-40 was a little low on pressure instead of waiting to see metal in the oil but can't do anything about the past
#23 |
Member#: 130990
NWIC
![]() You might just want to check on your oil pump. A failing pump could both lower your pressure and put metal into the oil.
#24 | |
Member#: 515683
NWIC
![]() Quote:
Cheaper to do it now as insurance just in case that's what it is. And if it turns out to not be the issue, I can just save the new oil pump for when the engine does go. An oil pump would 100% have iron, lead, and aluminum in it. I wish there was an easier way to check an oil pump other than taking the timing belt and all that off. Guess it's back to infront. Since I'll be taking it down, maybe I should try and track down a 10cm hotside since John said it'd only be an hour or two of touch up tuning for the larger hotside. |
