Welcome to the North American Subaru Impreza Owners Club Sunday August 7, 2022
Old 07-23-2022, 03:17 AM   #1
subieboiii04
Member#: 521634
Question Shifter Linkage Questions for 2004 WRX Sti
So, currently I have a shifter that has a lot of play when in gears and as I was doing some research into learning how to fix the issue. I noticed that there is a linkage that can be replaced on 5MTs. I tried to see if I could buy a new linkage for a 6MT since thats what my sti has and I think I found out that apparently the 6 speed linkage cannot be serviced. I wanted someone to help confirm that it cant be serviced and possibly guide me to other solutions that I can do to reduce the play.
For the 04 sti's do they require the whole assembly to be bought just to reduce the play?
I plan on buying the Kart boy bushings that I have listed below but, I am not sure how much the play will reduce with just that. Lookin for some crisp gear changes
https://www.kartboy.com/collections/...6spd-bushcombo
Thanks!
subieboiii04 is offline   Reply With Quote
Old 07-23-2022, 01:39 PM   #2
WR Blue
Member#: 451536
07 WRX
WR Blue
that'll take care of the play. nothing else required.
WR Blue is offline   Reply With Quote
Old 07-23-2022, 02:24 PM   #3
ether947
Member#: 297799
2003 WRX
EJ207 version 8
Unless your shifter linkage is rusted out or damaged, you shouldn't need to replace it. You can replace the bushings in the kit you posted. That is a common starting point.
If your u-joint bushings are bad, you can replace those with these.
https://www.iagperformance.com/tic-s...05-subaru-sti/
The shifter itself has pivot bushings that may be worn out too.
https://www.iagperformance.com/tic-6...ivot-bushings/
And here is the shifter linkage if you need it.
https://parts.subaru.com/p/Subaru_20...5041FE070.html
ether947 is online now   Reply With Quote
Old 07-23-2022, 02:32 PM   #4
subieboiii04
Member#: 521634
Awesome, thanks!
Old 07-25-2022, 05:46 PM   #5
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
complete short shifter assembly is another option
(lil more expensive bc you get the SS)
https://throtl.com/products/tqs-short-shifters-tqsts-ss-001c?cq_src=google_ads&cq_cmp=17684619527&cq_term= &cq_med=pla_with_promotion&cq_plt=gp&nbt=nb%3Aadwo rds%3Ax%3A17684619527%3A%3A&nb_adtype=pla_with_pro motion&nb_kwd=&nb_ti=&nb_mi=113964941&nb_pc=online &nb_pi=45af0377-6d7e-4ddb-89d7-3d291e2c8787&nb_ppi=&nb_placement=&nb_si={sourceid }&nb_li_ms=&nb_lp_ms=&nb_fii=&nb_ap=&nb_mt=&gclid= EAIaIQobChMIzPas_YCV-QIVUP7jBx3JlAdqEAQYCyABEgIAmfD_BwE
AliBenn is offline   Reply With Quote
Old 07-25-2022, 05:46 PM   #6
AliBenn
Member#: 487
Acadia Green RS-T
Old Yesterday, 02:44 AM   #7
subieboiii04
Member#: 521634
Okay so update,
I bought the KB Bushings for front and rear shifter but I still have play (as I suspected) but the play in my shifter decreased a little. Still when I am in gear my shifter moves around as if it were in neutral. I took a video after I installed the bushings to see what may have been causing the play to still occur and it looks like its the linkage I was refering to before. It attaches to the fork within the transmission I believe.
https://photos.app.goo.gl/swscxFkPBQyepdoX9
Does anyone know where I can buy this bushing at (Not sure if its one of the links already posted)?
Old Yesterday, 02:44 AM   #8
subieboiii04
Member#: 521634
Okay so update,
Old Yesterday, 07:36 AM   #9
ether947
Member#: 297799
2003 WRX
EJ207 version 8
Those are your shifter linkage u-joint bushings.
http://turninconcepts.com/tic-04-05-...-bushings.html
Old Yesterday, 12:36 PM   #10
subieboiii04
Member#: 521634
Okay great, much thanks!!!
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
