Welcome to the North American Subaru Impreza Owners Club Monday November 28, 2022
Old 11-20-2022, 02:00 PM   #1
rjahr01
Member#: 451282
Default MAF, 02, EGR connectors
While installing a replacement engine my installer smashed the harness on these following connectors- the cost of connectors is not cheap and seems like a harness (used) might be equal to the cost w/ o having to repin or solder connectors together-
2008 impreza 2.5 non turbo- would an auto harness be the same as that from a manual 5spd???
rjahr01 is offline   Reply With Quote
Old 11-24-2022, 01:07 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
If you have a you-pull-it sort of autorecycler in your area, I'd head on out and get however much of the harness you need from a compatible vehicle, then either replace the connector body, or chop off the old connector and solder on the "new" pigtail. (some connectors come apart/depin pretty easily, but for an older connector I'd just solder in the pigtail.
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
