Welcome to the North American Subaru Impreza Owners Club Wednesday March 26, 2025
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.4L Turbo Powertrain
Old 09-05-2023, 10:20 AM   #1
uglywrx
Member#: 534505
Default Radium PCV catch can hose adaptor failure
Last week I got a CEL, which eventually lead me to call Radium and they said check the hose adapter under the IC. Checked there and found this:
It looks like it got too hot and yielded. I am currently waiting to hear back from them on the fitting size so I can replace it with a metal one. I just wanted to let people know this is apparently a common enough failure the vendor tells people to check for it. They said it happens due to incorrect routing but I routed it like the steps said. This failure took roughly 700 miles to popup. I believe this is just a simple material choice issue and not a product issue. The adapter is made with non glass fiber reinforced plastic that is very soft to a razor blade. Once I get the size I will update the thread.
uglywrx is offline   Reply With Quote
Old 09-05-2023, 03:18 PM   #2
uglywrx
Member#: 534505
The size is 12AN to 13AN and they are sending me one made of aluminum. I guess I am not the first with this issue.
Old 09-05-2023, 03:59 PM   #3
azul89
Member#: 123491
2022 WRX
WR BLUE
Dang. Made quick work of the plastic.
azul89 is offline   Reply With Quote
Old 09-05-2023, 07:31 PM   #4
uglywrx
Member#: 534505
Radium is actually sending me 2 replacements made out of aluminum. I'm guessing they figured this out already. Now I need to inspect my brz's catch cans before I attempt to take it to STPR
