Welcome to the North American Subaru Impreza Owners Club Thursday March 27, 2025
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.4L Turbo Powertrain
Old 09-06-2023, 02:38 PM   #1
azul89
Member#: 123491
2022 WRX
WR BLUE
Default HPFP or LPFP issue
I have 13k miles on my VB. Under WOT i lose fuel pressure, but if I gradually accellerate no issues. If I never floored the car I wouldn't even notice it. I have a log of the fuel pressure drop. How can I figure out if its LPFP or HPFP related?
azul89 is offline   Reply With Quote
Old 09-06-2023, 04:51 PM   #2
uglywrx
Member#: 534505
HPFP is mechanically driven off a cam, there isn't really much to go just a little bit wrong. The low pressure pump has more things that can go wrong with it, and is a cheaper and easier fix. It could be as easy as just having a clogged filter honestly. You could also take the cover off the head and see if there is any glitter or debris in there.
Also I'm guessing you voided your warranty?
uglywrx is offline   Reply With Quote
Old 09-06-2023, 04:51 PM   #3
uglywrx
Member#: 534505
Old 09-06-2023, 07:32 PM   #4
Apb_pools
Member#: 534487
22 WRX
Lower ethanol content et voilá. I havent had a hiccup since going e50-60 exclusively. Hope it works out.
Apb_pools is offline   Reply With Quote
Old 09-07-2023, 09:32 AM   #5
Elbert Bass
Member#: 283429
2016 Crosstrek
The truth is that the HPFP has a bleed valve controlled by the ECM to modulate high fuel pressure to the injectors. Compare the target fuel pressure to the fuel pressure sensor reading. Any difference could indicate a faulty pump or sensor. A lean condition with lower actual pressure would indicate a HP pump fault.
As far as diagnosing LPFP - install a fuel pressure gauge on the LP fuel line and monitor while driving. If you see the pressure drop below 45-49 PSI (WRX) you have have a LP issue. A flow volume test result of less that 39 gal/hour could also confirm an issue with the LP pump/filter. LP fuel pressure/flow test values at minimum 12 volts.
Elbert Bass is offline   Reply With Quote
Old 09-07-2023, 12:19 PM   #6
azul89
Member#: 123491
2022 WRX
WR BLUE
Thank you. I went ahead and ordered the Fuel-it LPFP because I wanted to upgrade that anyways. If there was a performance HPFP available I would go a head and switch to that as well. Just because, but I am not about to drop $600 on oem unless I have to. Thank you for the tip. It hasn't happened again since I reflashed the car. It might have something to do with the fuel pressure sensor...Thank you I have a better perspective now.
Old 03-06-2025, 12:09 PM   #7
richilg1
Member#: 540409
2016 WRX
So you were running high ethanol content?
richilg1 is offline   Reply With Quote
