Welcome to the North American Subaru Impreza Owners Club Saturday June 22, 2024
Old 06-06-2024, 02:52 PM   #1
coryb03
Member#: 228493
Default Car Cabin Smells like Exhaust
Hi All,
Wondering if anyone has experienced any issues with the cabin of their car smelling like exhaust - mechanic did a check and said theres no exhaust leaks. im not sure what else it could be?
coryb03 is offline   Reply With Quote
Old 06-06-2024, 02:57 PM   #2
AlexL
Member#: 192988
2005 WRX
Is it stock? There is no other answer except an exhaust leak. Smelling like gas, or oil, or coolant could be something else. But exhaust smell is exhaust leak.
AlexL is offline   Reply With Quote
Old 06-06-2024, 02:59 PM   #3
coryb03
Member#: 228493
previous owner had a full invidia system on it but it was too loud so i bought a catback stock exhaust from junkyard and put that on. i am pretty sure the smell is exhaust
Old 06-06-2024, 03:17 PM   #4
lokanaft
Member#: 538217
2021 WRX STI
K7X, WR BLUE PEARL
If you have an oil separator, then it may not be closed back to the engine intake, but vented into the atmosphere and you feel this smell.
lokanaft is offline   Reply With Quote
Old 06-07-2024, 11:51 AM   #5
TurboRev
Member#: 463945
It might be worth checking the cabin air filter or the ventilation system. Sometimes a dirty or clogged filter can let in unwanted fumes. Also, ensure your HVAC system isn't set to draw in air from outside.
TurboRev is offline   Reply With Quote
Old 06-11-2024, 12:51 AM   #6
GoFrogs
Member#: 507317
2019 WRX
Pure Red
Originally Posted by coryb03 View Post
Hi All,
Wondering if anyone has experienced any issues with the cabin of their car smelling like exhaust - mechanic did a check and said there's no exhaust leaks. i'm not sure what else it could be?
Didn't see the year of the car...
depending on where you start your vehicle, it is possible that the exhaust is being blown to the front of the car and is then sucked in by the hvac fan IF you have the recirc-air button "off", i.e. draws in outside air.
I get this on occasion when the air is cold and heavy and exhaust lingers around the car (mostly late fall and winter).
As mentioned above, turn recirc on and/or turn your fan speed to as low as possible or off and see if he smell persists
another possibility is the cabin vents located behind the rear bumper cover, on the lower quarter panels below and back from the tail lights. These cabin vents are what allow you to shut the doors and the vents only open with positive cabin pressure. However, if some of the plastic vanes on these vents gets stuck open, they can let in smells.
I assume you got all of the gaskets for the stock system you put on in place of the invidia system...yes?
GoFrogs is offline   Reply With Quote
Old 06-11-2024, 11:23 AM   #7
Gixhost
Member#: 180111
* 2004.114.3 STi
If you purchased a stock cat-back exhaust and installed it I would check again for a leak as everyone else is suggesting...you may need to tighten the bolts at the donut gasket more...also if you didn't install a fresh donut gasket you may want to replace it. If you aren't using a donut gasket and factory spring bolts with the factory cat-back that could be the issue as well. What kind of downpipe are you running? If it isn't factory you may get some exhaust smell depending on whether its catted or not and whether you're missing a cat. Even with a single high flow cat setup when you come to a stop with you windows down you'll get some exhaust smell. If its just exhaust filling up the cabin all the time something is wrong and as everyone has said there is a leak somewhere.
Gixhost is offline   Reply With Quote
Old 06-11-2024, 04:17 PM   #8
Jedi03
Member#: 491095
2009 STi Blue
lift car and look for soot on all parts of the exhaust, headers, up pipe, down pipe, etc. sounds like there could be a leak somewhere
Jedi03 is offline   Reply With Quote
Old 06-13-2024, 09:11 AM   #9
bo2o
Member#: 167238
One thing to check is the condition of the exhaust system itself. Even though there are no leaks, there could be a problem with the exhaust routing or a component of the exhaust system that is allowing exhaust gases to enter the cabin in some way. Maybe the exhaust pipe is damaged.
bo2o is offline   Reply With Quote
Old 06-13-2024, 10:22 AM   #10
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
A leak is most likely, burning off oil/grease, etc. is second, stuck open rear fender area vents are next.
Only way to get smells without a leak but new exhaust is a hot pipe is against body undercoating, rubber, etc. which is burning/melting.
