Welcome to the North American Subaru Impreza Owners Club Wednesday March 26, 2025
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.4L Turbo Powertrain
Old 08-04-2024, 03:37 AM   #1
spectacles81
Member#: 444011
Default 2022+ WRX CVT rear brake pad replacement help
Hello,
I have been reading forums and watching YouTube videos. This is what I gathered so far. Please let me know if this is correct process for changing rear brakes for the CVT without using a scan tool as there are conflicting and possible extra unnecessary steps on some of the videos. I want to make sure this is the right way to do this.
1. Release electronic parking brake
2. unplug connector for caliper motor
3. Remove plastic caps for caliper pins and remove bolts for caliper, then remove caliper.
4. Use a piston wind back tool and wind back piston as far as you can. It looks like it won't sit completely flush but has enough room for new pads. Removing the motor is not necessary. Using a piston push back tool after winding is also not necessary.
5. Reinstall and engage/disengage parking brake 5 times.
spectacles81 is offline   Reply With Quote
Old 08-05-2024, 07:20 AM   #2
Elbert Bass
Member#: 283429
2016 Crosstrek
If you don't have a scan tool that will do brake maintenance functions, yeah. Be patient if your rotors are grooved or dished. pump the pedal to get a firm pedal before cycling the park brake.
Elbert Bass is offline   Reply With Quote
