01-08-2025, 11:03 PM | #1 |
Member#: 506873
Vehicle:2001 WRX Sedona Pearl Red |
2010 STI rougher than I'd like
Hey everyone !
Recently bought a 2010 STI A Line (auto JDM) and have been looking at it for a while. I used to have a 350z but a recent back injury (slight bulging disc) made the 350z FAR too uncomfortable to drive. I thought I was going to have to give up sports cars but the 2010 STI Auto looked comfy and had a nice adjustable seat. I test drove a few and it was comfy, lots of headroom etc so I thought it was a good compromise. Anyway, a beautiful one with gorgeous mods came up and I ended up buying it. However, I never test drove it long distance and I do a little bit of travelling. It is sitting on TSD coilovers and has a set of Workmesister S1P1s on stretched tyres. (https://boostedkiwi.co.nz/products/s...D5x9Li4HMTK5N9) https://www.fitmentindustries.com/br...r-S1-3P/18x9.5 Anyway, I bought the car, did a longer trip and it seemed great. However, I had to get the car raised a bit as it was far too low couldn't get in in driveway. Coilovers were sitting between soft and firm and I changed it to fully soft. Anyway, did a 1.5 hr each way trip yesterday, and the car felt harsh. EVery little bump I hit I felt like the car bounced aggressively and it did it in a way where the car felt like it weighed 10 tonnes and landed and "left my body behind" and I ended up slamming down into my seat if that makes sense. It is kinda hard to explain but you imagine a plush car bounces and you kind of go up and down gently. This felt like the car would drop immediately and harshly and would jar my neck, back and head. I am now in a bit of a conundrum. Car is stunningly beautiful and has very nice mods but I really want to make it more comfy. Will returning to OEM struts/springs be enough? Or is is always going to be inherently too rough because it is an STI. Is it a combination of stretched tyres, cheap coilovers and low profile tyres causing this? ANy other advice? I don't need/want it to be aggressive as I just want a sporty car for daily that sounds and looks good
01-08-2025, 11:18 PM | #2 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
I don't know those struts. Can you adjust jounce and/or rebound? Those would likely help you out.
What are your tire (or is it tyre?...LOL) pressure? I usually recommend 80-85% of max inflation based on the molded max on the sidewall, NOT what the owners manual states since tires may have been replaced. |
01-09-2025, 12:42 AM | #3 | |
Member#: 506873
01-09-2025, 01:29 AM | #4 |
Member#: 30669
Book values for tire pressure is for the OEM installed tires.
Example, on my 1998 Legacy GT with the RE-092's, max inflation was 46PSI, book pressure was 38? I switched to Conti extreme contact M&S with a max inflation of 55, I would run 44-46PSI, the book of 38 was a poor ride. |
01-09-2025, 02:23 AM | #5 | |
Member#: 506873
WIll that make it a lot more comfortable? |
01-09-2025, 09:11 AM | #6 |
Member#: 30669
Sidewall is some of a hard ride. Partly due to less sidewall give, partly due to higher pressure to avoid killing tires.
Your tire size means you have some sidewall which helps. Here's a thought, is there another Subaru around you with the same bolt pattern? Ask to do a tire swap for a couple days. Theirs should be close to OEM size. It could be their winter tires if they have them. Last edited by Charlie-III; 01-10-2025 at 10:31 PM. Reason: Fix typo |
01-10-2025, 06:53 PM | #7 |
Member#: 538662
What spring rates are you running? If you are running really stiff auto-x springs, the ride would probably be pretty tough and I would consider swapping to something softer.
