Welcome to the North American Subaru Impreza Owners Club Tuesday July 15, 2025
Old 07-05-2025, 06:42 PM   #1
carsebuco
Member#: 482289
Default STI Caliper: no thread for bolt. What do?
Decided to change my brakes on my own. Bad idea. Bottom bolt of front caliper that connects to the knuckle does not go back in anymore (or rather, goes in too easily); bolt won't thread in. I can just push the entire bolt in without resistance. I even tried swapping it with the bolt from the other side, but no bite.
Is this fixable, or do I need a whole new caliper? I'm not gonna try to fix it myself, but I'd rather know if I should expect to pay for new threads to be drilled or for a whole new caliper.
Car is a 2004 fSTI with the gold calipers.
carsebuco is offline   Reply With Quote
Old 07-06-2025, 08:43 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
If enough metal, use a helicoil or timsert.
Old 07-06-2025, 09:49 AM   #3
carsebuco
Member#: 482289
pardon my ignorance, but won't remaking the threads require a thicker bolt afterwards? or are these actual inserts?
Old 07-07-2025, 12:19 AM   #4
lukethedork
Member#: 326146
You drill the hole larger and then the insert goes in to make the same size as the original hole.
lukethedork is offline   Reply With Quote
Old 07-07-2025, 10:33 AM   #5
cboggess
Member#: 30804
87 Yugo
Red
Take to a Subaru shop in your area. Have them install a timesert. Get new bolts from Subaru go on your way.
cboggess is offline   Reply With Quote
