Welcome to the North American Subaru Impreza Owners Club Tuesday June 27, 2017
Old 02-11-2003, 10:10 PM   #1
WRXImprezYa
Member#: 32657
2001 Corolla S
Question StopTech rotors and breaks on WRX in CAR AND DRIVER
Hey Guys,
Was checking out an article in Car and Driver a couple days ago, and saw a article on the WRX and brakes. It seems that in their test the StopTech ones preformed the best overall and were the cheapest of the break kits. They were up against others such as Brembo. Any of you know anything about these brakes>>>??
WRXImprezYa is offline   Reply With Quote
Old 02-11-2003, 10:44 PM   #2
BillJC
Member#: 31002
Very high quality. They actually make their calipers in house. They don't buy another company's caliper and put their name on it. great customer service. I've seen them quite a bit at the race track and on quite a few WRX's. Cobb tuning actually uses StopTech Brake kits and put their name on it.
BillJC is offline   Reply With Quote
Old 02-11-2003, 11:18 PM   #3
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
boat, dirt bikes, bobcat
StopTechs are outstanding from what Ive heard. I'll write a review on them as soon as they go on. I cant wait.
STR8OUT is offline   Reply With Quote
Old 02-11-2003, 11:33 PM   #4
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
What? Have you been living under a rock?
There is SO much info on Stoptechs here in this Forum, I suggest you use the Search feature. In my opinion, for the money they are the best brake kit out for the WRX.
Old 02-11-2003, 11:39 PM   #5
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
2 piece true floating rotor, 4 pot caliper. Very nice set up. I like them. The only problem I didn't like is the maintenance issue example cost replace rotor if you get a hot spot or crack. No dust cover in caliper.
Performance numbers are good, but other companies come out being almost the same.
jdmimpreza is offline   Reply With Quote
Old 02-12-2003, 01:28 AM   #6
WRXImprezYa
Member#: 32657
2001 Corolla S
If you weren't normally racing would you say it would be worth your while to do a brake upgrade??
Old 02-12-2003, 02:24 AM   #7
SIN801
Member#: 32315
WHITE
JDMImpreza-the StopTech calipers do comes with dust cover boot in caliper.
WRXImprezya-if you are happy with stock brakes, then don't do it. Maybe you should test drive a Subaru with bigger brakes and see if you like it.
SIN801 is offline   Reply With Quote
Old 02-12-2003, 10:01 AM   #8
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
yeah, no need to upgrade if you don't track, unless you just want the look. The stock system will stop your car just fine in almost any situation... the only advantage to bigger brakes is heat capacity which shouldn't be reached for the stock setup on the street... if it is, you need to keep your foot off the brake while you're accellerating and cruising...
mrbell is offline   Reply With Quote
Old 02-12-2003, 04:31 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
after quite a bit of research this is the kit i would by .. but it won't clear my wheels .. (rota formals)
New Legacy and Outback on sale in Australia and New Zealand rsholland News & Rumors 1 09-03-2009 03:39 PM
WRX TR review in Car and Driver May issue BlackPearlX General Community 9 04-12-2007 08:51 PM
Full WRX review in Car and Driver>> JVT General Forum Archive 0 03-09-2001 09:38 PM
