Welcome to the North American Subaru Impreza Owners Club Wednesday October 18, 2017
Old 04-10-2003, 02:07 PM   #1
Aaron Hoag
Member#: 34926
2002 wrx wagon
black
Question sti 6spd tranny in an 00 rs2.5?
I know that subaru prides itself on it reverse engineered parts, and good percentage of overall "compatibility". But, has anyone swapped a tranny only into an rs? Preferably an upgrade from the stock one
a-
Aaron Hoag is offline   Reply With Quote
Old 04-10-2003, 02:24 PM   #2
peepshow
Member#: 1777
2005 LGT
#92 FZippy
The transmission tunnel in the new body style is bigger than on teh GC/GF/GM chassis cars. I'm sure you could make it fit, but I'm equally sure it will require cutting some of the transmission tunnel. Not worth the cost/effort, IMO. Custom work like that is sure to be $$$$$$$$.
- Trent
peepshow is offline   Reply With Quote
Old 04-10-2003, 06:17 PM   #3
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
I have one in my 99RS . You don't have to cut out the tunnel. Just a little "tapping" to clear the shift mechanism.
Only major modification is either shortened the stock RS prop shaft or get the 6-speed one. I opted for the first, it cost me $150 Cdn. to shortened and re-balanced.
Ver.III is offline   Reply With Quote
Old 04-10-2003, 07:13 PM   #4
Aaron Hoag
Member#: 34926
2002 wrx wagon
black
very cool verIII.
did you get a used tranny or a newer one?
jdm or soa?
worth the effort to install?
thanks
a-
Old 04-11-2003, 12:34 AM   #5
Ver.III
Member#: 1185
I flap my gums
I came across a one-time deal for a new JDM 6-speed. I had it planned for a while but the funds were low. I love the 6-speed, considering I had a Sti RA 5-speed before. Its not fun sitting at 4200rpms doing 100km/h on a long 5 hour trip !
Old 04-11-2003, 01:17 AM   #6
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
If you had the whole drivetrain including the diff and driveshaft, it should be pretty much a drop in, exept the shift linkage clearance maybe, and perhaps a spot the put the DCCD switch if you had one with DCCD
Old 04-11-2003, 11:55 PM   #7
grnlantern1
Member#: 2589
1998 GC8 Do-Luck
Acadia Green Metallic
Question
Hey Ver III what RPM are you driving at now with 6th gear I have the Version IV with the 4.44 final drive and I know what you mean high rev's doing 80MPH but it's nice when someone want's to play with ya..... Give it the Gas and GOOOOO....Ron
grnlantern1 is offline   Reply With Quote
Old 04-12-2003, 11:54 AM   #8
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
how about axles...??? i know i asked this before... hehe forgot...
HOK is offline   Reply With Quote
Old 04-13-2003, 01:35 AM   #9
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
I dont know about the axles... Depends on if they are a different length or not. I know they are beefier though...
Old 04-13-2003, 03:15 AM   #10
kidatari
Member#: 10441
Ah-ha! Just the thread I was looking for. So, mating the 6MT to the EJ25 is just plug and play, or what? I need to ditch this 4EAT, and I'd like to swap over to a 6MT with the SureTrac. Also, for whoever did this, did you just use a WRX clutch and flywheel, or what?
-Josh
kidatari is offline   Reply With Quote
Old 04-13-2003, 08:32 PM   #11
Ver.III
Member#: 1185
I flap my gums
There are 2 different 5th/6th ratios. The JDM has the shorter ones , 5th(1.062) / 6th(.842) . So at 120kmph , I'm buzzing around 3500rpm.
Shafts , I used back my stock RS front shafts. The splines are the same. Problem with the Wrx ones is that they are longer. It may be okay, but I am not sure about the plunge distance if it would bottom out in the inner joint.
Clutch, I am actually using a stock Wrx pressure plate with a Helix 4-puck disc, center-sprung.
I NEED JDM taillights for an 01 RS2.5 coupe stallion91 Private 'Wanted' Classifieds 7 01-15-2010 08:37 AM
WTB ASAP! Clutch fork 00 RS2.5 KONKILR Mid Atlantic Impreza Club -- MAIC 25 03-19-2005 09:36 AM
verion 8 STI engine & 6spd tranny in GC8? STI808 Subaru Conversions 35 07-13-2004 08:46 PM
Has anyone installed an sti 6spd tranny? Benjamin Tang Transmission (AT/MT) & Driveline 20 06-24-2002 09:43 PM
