Welcome to the North American Subaru Impreza Owners Club Sunday January 21, 2018
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds
Old 04-28-2003, 02:20 AM   #1
WRXTuner
Vendor
Vendor Sales Rating: (0)
Member#: 17778
WR Bluw
Default 16G direct bolt-on for WRX $875 shipped!
We have the 16G turbo upgrade available for your WRX for a mind blowing $850.
This turbo is good to 400+ HP and is a direct replacement for the TD04, characteristics of this turbo include a smooth fast spool and lots of mid and top end power.
You can PayPal us or call us at 1-866-WRXTuner to place your order.
We are also offering TD04 level 2 and Level 3 upgrades.
The upgrade is not the conventional cliping or just a port and polish. You will get a completely rebuilt to better then factory specs turbo which is ported polished, the internal housing is machined and a larger impeller is added to give you phenominal power.
The level 2 upgrade has produced 12.77 in the quarter mile with only an up-pipe and a boost controller!
I look forward to hearing from everyone!
Nick
www.WRXTuner.com
__________________
Paypal:
Contact:
WRXTuner is offline
Old 04-28-2003, 04:34 AM   #2
clamdip
Member Sales Rating: (1)
Member#: 18709
pm'd ya!
clamdip is offline
Old 04-28-2003, 07:20 AM   #3
SonicWRX
Member Sales Rating: (23)
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Default Re: 16G direct bolt-on for WRX $800 shipped!
Originally posted by WRXTuner
We have the 16G turbo upgrade available for your WRX for a mind blowing $800.
Can you please post:
Compressor maps for each stage you are offering
The type of exhaust housing each stage is built on
Compressor maps
Dyno charts
A picture
Thanks!
Mitch
Edit: Spelling
SonicWRX is offline
Old 04-28-2003, 09:34 AM   #4
jblaine
Member Sales Rating: (36)
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I can't find anything on your website with full detail on these products.
jblaine is offline
Old 04-28-2003, 01:14 PM   #5
QA Guy
Member#: 6739
Is this the same turbo that Turbo Specialties is offering?
QA Guy is offline
Old 04-28-2003, 02:01 PM   #6
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Quite simply...
Yes this is the same turbo we are going to be the exlusive reseller of the product.
Nick
P.S. I will have more info in the next day or so we are still getting all the info together for everyone
www.WRXTuner.com
__________________
Paypal:
Contact:
WRXTuner is offline
Old 04-28-2003, 02:17 PM   #7
modvp
Member#: 25215
Default Re: Quite simply...
Nick
www.WRXTuner.com
Is this w/o core? New turbo...no core right?
modvp is offline
Old 04-28-2003, 02:22 PM   #8
dman918
Member Sales Rating: (16)
Member#: 11202
2009 Infiniti G37X
Prev: 2006 STi with stuff
I can't wait to see some proven numbers on the turbo to show if it is better than the vf series, etc.
Can you get the big 16g and 18g as well?
dman918 is offline
Old 04-28-2003, 02:39 PM   #9
b00st3d
Member Sales Rating: (12)
Member#: 9891
2015 RC-F
Ultra White
i would like some more info on the 16g...ecu requirements/fuel requirements/any other requirements!
b00st3d is offline
Old 04-28-2003, 04:24 PM   #10
M3toWRXin3seconds
Guest
Member#:
Default where are the dyno numbers?
requirements....etc for the 16g bolt on...you'd have $800 in your pocket if you could provide these...and im sure from others too.
how difficult of an install is this? do you need a different intercooler?
thanks
Old 04-28-2003, 05:45 PM   #11
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Full description of the 16G
The Subaru TDO5 HS 16G turbocharger upgrade is now available. This is a fully developed upgrade for the US market Subaru, not a reworked European or Japan issue upgrade. We have pulled all of the strongest features from several turbochargers together to create a very well balanced combination of boost response, efficiency and power. Over the past two years we have tried may different turbochargers and carefully analyized their performance on the US market car. We found fast responding units, unbelievable top end power and great torque, but never all of these characteristics in one package. Our turbo utilizes the following features: MHI 16G cartridge, using the standard turbine wheel to give us maximum drive area, a properly machined IHI #20 exhaust housing for the perfect balance between exhaust flow and velocity, Garrett .60 A/R compressor housing with custom CNC machined adapter, perfectly matched inlet and outlet dimensions for a trouble free fitment, and last an adjustable wastegate actuator to allow custom tailored boost for your combination. We back all of this with a full two year warranty.
The most power so far out of this turbo has been 327WHP and full boost is around 2900 RPM. The car with these #'s has the following mods:
1. Up-pipe
2. Turbo Back
3. UTEC (dyno tuned)
4. STi 550 injectors
5. Walboro fuel pump
6. Top mount intercooler (TXS)
7. Cold air intake
8. 17lbs of boost
Bone stock we had a car make 264WHP with just an up-pipe and a K&N drop in filter. No after market boost control of anykind. Without any tuning the car will get usable boost around 3400 RMP and full boost around 3800 with a good boost controller and and a turbo back exhaust you should see full boost around 3400 RPM or less.
There are 4 left and we will have more in about 3 weeks.
Nick
__________________
Paypal:
Contact:
WRXTuner is offline
Old 04-28-2003, 06:18 PM   #12
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Re: Re: Quite simply...
Correct no core with a new turbo
Nick
www.WRXTuner.com
__________________
Paypal:
Contact:
WRXTuner is offline
Old 04-28-2003, 06:29 PM   #13
dman918
Member#: 11202
2009 Infiniti G37X
I will be interested once I see some more guinnea pigs buy and use it.
Again, are you going to offer the big 16g and 18g as well?
dman918 is offline
Old 04-28-2003, 06:57 PM   #14
b00st3d
Member#: 9891
2015 RC-F
Ultra White
i wonder if this 16g is better than the vf30 im currently using...i've seen roughly the same hp #s from the vf30 and similar mods.
b00st3d is offline
Old 04-28-2003, 07:00 PM   #15
M3toWRXin3seconds
Guest
Member#:
Default since your mailbox is full....
couple questions...
I have a drop in filter and an up pipe...
if i run stock boost will i be too lean?
(yes i plan on upgrading the other fuel parts as well as exhaust and computer)
Does it come with instructions?
just want to make sure i dont kill my car...
i need it to last, it only has 4000 miles on it, and i was thinking of trading it in for a lancer evo or something else. This upgrade would make me keep it.
thanks
Old 04-28-2003, 07:13 PM   #16
pfhlipwrx
Member#: 19319
I would like to go for the Turbo from TurboSpecialties. I was just reading about that the other day on their site. They didn't give a whole lot of detail...sounds very nice and from the price they quoted a liitle more acheivable for the average guy.....
Bumpppppyyyy...............
pfhlipwrx is offline
Old 04-28-2003, 07:55 PM   #17
jaxscuby
Sammo Hung
Member Sales Rating: (24)
Member#: 10613
2002 USDM WRX
Talking bad Nick..
Bad...Bad..Nick..you're such a bad influence..
selling these parts that I must have!
Bad..Bad..Nick...terrible..now i have sell
myself on the streets..to make extra money..
PS..Nick is a great guy and outstand individual..
did I actual say that?..I must have been brain washed..
what did you put in my beer last time we went drinking?!
Ben
Jax Mod Squad
jaxscuby is offline
Old 04-28-2003, 08:43 PM   #18
is2scooby
Member#: 19851
02 WRX
Aspen White/[email protected]
VERY interesting...
is2scooby is offline
Old 04-28-2003, 08:51 PM   #19
zronin
Member#: 16026
Shouldn't this turbo be called a hybrid TDO5 16G, since it really is a Frankenstein turbo. Just want everyone to realize that this turbo isn't a genuine 16G as those used in the Ver ll overseas.
zronin is offline
Old 04-28-2003, 09:53 PM   #20
M3toWRXin3seconds
Guest
Member#:
Default so for a newbie like me...
in easy terms...what is the difference between a real 16g and this? quality? how long do they last when used properly?
Old 04-28-2003, 10:32 PM   #21
modvp
Member#: 25215
Default Re: Full description of the 16G
1. Up-pipe
2. Turbo Back
7. Cold air intake
8. 17lbs of boost
Nick
I am very interested. However, your dyno #'s does not make too much sense to me unless i know how much a stock WRX pushes on that dyno.
modvp is offline
Old 04-28-2003, 10:34 PM   #22
palaban
Member#: 16691
When will you have pricing and availabilty info on the stage 2 and stage 3 TD04 upgrades? Can you run this safely on stock fuel?
palaban is offline
Old 04-28-2003, 11:39 PM   #23
sicminded
Member#: 21250
2002 Impreza WRX
www.WRXTuner.com
just wanting to verify this. 12.77 in the quarter mile with just an upipe and a TD04 upgrade and boost controller, thats it?
if this setup is reliable and ideal for a daily driven car, drop me a pm with more info. or just reply here, heh.
thanks
sicminded is offline
Old 04-28-2003, 11:45 PM   #24
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Re: Re: Full description of the 16G
The same car that made 264WHP was 192WHP before the turbo
Nick
__________________
Paypal:
Contact:
WRXTuner is offline
Old 04-28-2003, 11:52 PM   #25
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Re: Re: 16G direct bolt-on for WRX $800 shipped!
thanks
This setup is very reliable as a daily driver or a track car. There are 337 of these turbo's out there and only 1 has ever come back
Talk to you soon,
Nick
www.WRXTuner.com
__________________
Paypal:
Contact:
WRXTuner is offline
:::PROOF::: that a V8 STI Intercooler is a DIRECT BOLT ON on to 04-05 WRX!!! shinsain Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 82 11-26-2010 01:30 PM
04 STI steering rack-direct bolt on for 02-04s, new Whiteline ball joint extender kit fastwrx25 Suspension/Brakes/Handling 17 04-05-2008 12:28 PM
Progress Adjustible Rear Sways are a direct Bolt-on for the FXT! BrysImpreza Forester Forum 22 04-16-2004 09:56 AM
16G direct bolt-on nicd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-02-2004 05:13 PM
Does anyone know if this is a direct bolt-on to a USDM 2002 WRX? MK2TMR2 Brakes, Steering & Suspension 1 04-26-2003 10:35 AM
