05-02-2003, 11:40 PM | #1 |
Member#: 9407
South East
Vehicle:02 WRX platinum silver |
Utec boost map ???'s
I had a VF22 and was using CLB controller with alot of luck, but have since swapped to a VF30. I had a really nice map for my 22 and modded it a little to work with the 30, peaked at ~17 lbs. and tapered to ~15 lbs. at redline. I haven't been able to duplicate anything like that with the 30, should I worry about tapering boost off or just run 17 lbs to redline?
05-05-2003, 11:31 AM | #2 |
Member#: 31555
I use the same boost map (clb) setting to redline and let the turbo taper at its own rate.
Bob |
05-05-2003, 01:47 PM | #3 |
Member#: 9407
South East
I have my map at a slow decline and maybe tapers a lb. or 2, if I left the values equal it would hold 17 psi at redline.......
05-05-2003, 05:40 PM | #4 |
Member#: 31555
Mine (vf30) tapers 1-2 psi from peak to redline.
Utec Boost map 5 for N20 | mycal | Engine Management & Tuning | 24 | 12-27-2005 07:48 AM |
utec boost map question | bstoehr83 | Engine Management & Tuning | 1 | 05-04-2004 11:41 PM |
How much boost? and UTEC maps ?'s | HorsepowerFreaks | Proven Power Bragging | 4 | 04-05-2004 11:44 PM |
Utec Boost Map??? | infulleffect | Engine Management & Tuning | 8 | 02-23-2004 11:01 PM |
Open Loop vs Closed Loop UTEC boost map. Example? | mav1c | Engine Management & Tuning | 3 | 02-01-2003 10:58 PM |
