Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 05-06-2003, 11:08 PM   #1
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default Trans-Species Transplants
This thread is about transplanting Subaru engines into non-Subaru cars.
I was browsing the CARB website when I was stunned to find that a company, Kennedy Engineered Products, has received CARB Executive Order #D-428-1 for a product called "The VW Vanagon Engine Change Kit" which involved a Subaru engine.
The VW Vanagon Engine Change Kit is designed to provide all the necessary parts to replace the stock 1980-91 VW Vanagon engine with a 1990-95 2.2 liter Subaru engine. The kit includes the following parts: Adaptor plates and hardware to mount the Subaru engine to the VW transmission and motor mounts, necessary intake air ducting and closed element air filter box, electrical schematic on adapting the Subaru's sensors and ECU to the Vanagon body, and an exhaust system which includes a set of manifolds, one muffler, and one TRI-D Industries, Inc. TD-5000 catalytic converter. On Vanagons that are not equipped with a check engine light on the dash, a light must be installed and wired to the Subaru ECU. The following trouble codes may be logged by the Subaru ECU: #33, speed sensor, #51, neutral switch, and # 52, emergency brake. The Vanagon hardware does not support these electrical functions. Kennedy Engineered Products' VW Vanagon Engine Change Kit is only applicable on a complete Subaru 2.2L engine. These engines must be installed according to the Air Resources Board's "Engine Change Policy" which requires the engine to be of the same model-year as the vehicle it is being installed in or newer. A complete engine includes the following: A stock 1990-95 Subaru 2.2L long block equipped with the stock air intake components, closed element air filter box (either original or aftermarket), ECU, associated wiring, and all engine sensors. The new engine must interface with the stock Vanagon's evaporative emissions control system. Diesel Vanagon conversions must upgrade their evaporative emissions control system to that of a gasoline Vanagon.
Whew! Anyhow, it occured to me that this company might have some expertise in mating Subaru engines to non-Subaru transmissions, especially if anyone is wanting to use a Subaru EJ engine in a rear-engine configuration (VW, Porsche, etc.). Alternatively, they might be able to offer advice about dropping a Porsche engine into a Subaru (probably - Don't Do It).
Jon [in CT] is offline   Reply With Quote
Old 05-07-2003, 01:21 AM   #2
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Yes, they do a lot of cool things with vanagons
Here is the link to more info:
http://smallcar.com/
chris
Crawford/I-Speed is offline   Reply With Quote
Old 05-07-2003, 11:02 AM   #3
smallcar
Member#: 29704
89 Vanagon
chris
Our latest project (Her's, first phase completed):
http://www.smallcar.com/vanagon/vanagonwrx.jpg
2002 WRX motor in a 1991 Carat automatic. Now has a custom header and single 2 1/4" cat/muffler, Audi turbo transmission internals, 16X7" wheels.
Soon to have larger vented front discs and 10.4" vented rear discs.
Next project (His): 1989 Syncro Westfalia, 2002 WRX with A/W intercooler, four wheel discs, custom springs, wheels etc.
smallcar is offline   Reply With Quote
Old 05-07-2003, 03:10 PM   #4
Aspen
Member#: 145
Banned to
Housework for Summer
Chris,
Check your pm.
Aspen is offline   Reply With Quote
Old 05-08-2003, 02:28 AM   #5
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
answered it
Old 05-08-2003, 03:16 AM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Smallcar: Its always cool to see someone like you performing these types of modification, but I have a question.
You obviously like the subaru engine design, why not the rest of the vehicle?! I can understand the vanagon swaps but why these other vehicles.
Are you interested in doing something that hasnt been done or? The 1993 impreza with WRX engine is very nice.
Old 05-11-2003, 04:49 PM   #7
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
I have always wanted to go the other way. Put a 1800cc VW bug motor into a '84 subaru GL wagon
ChrisW is offline   Reply With Quote
Old 05-12-2003, 08:11 PM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Ok. That is just wrong. But I like it It's kind of sick like the Dodge Caravan out here that runs low 14's with an uncorked 2.4L Datona turbo motor.
-Jon
Old 05-19-2003, 02:19 PM   #9
Realbigstauf
Member#: 6361
02 WRX
Rally Blue
Default Swaps
Hey Jon,
I know that you are thinking about a stronger tranny for the WRX but I'd like to turn that around.
How about the B3 and B4 VWs with all the bum trannys. I wonder what the process looks like to put a WRX AWD drivetrain into a 97 VR6 Passat. We could call it the VWRX. Got outbid this morning on an 02 roll-over. What do you think a fair price for a 02 WRX parts car is? This one went for $3K without a single good body panel and blown airbags through-out with 50K miles on it. I guess the easiest way would be to drop the complete engine, drivetrain & harness mated to a 4Motion rear.
Anyone have some thoughts on converting a B4 VW to a VWRX?
Brian
Realbigstauf is offline   Reply With Quote
Old 05-19-2003, 02:33 PM   #10
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
A typical wreck will go for about $5k, depending upon how many good panels are left. I have heard prices as low as $2k, but most people I talked to have said that you would be lucky to find one for $5k.
-Jon
Old 06-07-2003, 01:58 AM   #11
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
I think my dream conversions would be:
1. WRX 6 cylinder with a turbo into a reconditioned Porsche. I know a guy that put a DSM 4G63 into one - looks awsome.
2. WRX engine/drivetrain into a Miata mega fun factor!
AntiochCali is offline   Reply With Quote
Old 06-09-2003, 03:26 PM   #12
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I'll take a Lotus Elise with an ITR engine in it thank you very much.
-Jon
Old 06-09-2003, 04:07 PM   #13
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
how about a lotus elise with an ITR engine with a jackson racing supercharger on it..
Old 06-09-2003, 05:09 PM   #14
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Well that was implied, of course.
-Jon
Old 06-10-2003, 05:34 PM   #15
iceweazel
Member#: 6816
01 yeller wrx
05 triumph tiger
If all you are looking for is a better tranny setup:
Find a link to Manhattan Eurosport rally shop. call and talk to them. They have a WRX they run on Audi gear. never breaks gears or trannys. They are an old Audi shop from way back.
Having been an Audi guy myself it looks like a strong match.
Ed
iceweazel is offline   Reply With Quote
Old 03-31-2007, 08:49 PM   #16
PRODRIVEN
Member#: 111
1999 Impreza 2.5 RS
EJtwentyfied -> '04 STi
Anyone know where those pics of the Porsche 550 with an STi motor is. Car was black and in Australia/NZ?
PRODRIVEN is offline   Reply With Quote
Old 04-02-2007, 11:27 AM   #17
steve_d
Member#: 315
Kennedy has been making adapter plates for VW and porsche transmissions for YEARS...like nearly 40. there's a couple of SVX vanagon synchros out there with some pretty funny stories.
I've used their product in my EJ powered 912. it pulls hard all the way to redline in all the gears.
Vintage spyders did a turbo subaru powered 550. the owner said that is was still pulling hard at an indicated 130 mph, and that's when he chickened out.
steve_d is offline   Reply With Quote
Only one species of human? Reciprocity Off-Topic 50 04-23-2004 05:28 PM
Environmental Law endangered species. brunetmj Off-Topic 8 02-20-2004 01:07 AM
Warming May Threaten 37% of Species by 2050 mr_disco Political Playground 14 01-13-2004 08:06 PM
new fish species in venezuela 'biodiversity hotspot' touch Off-Topic 2 08-30-2003 02:59 PM
Apparently the missus has been calling on someone outside her species... Sean New England Impreza Club Forum -- NESIC 9 04-15-2002 11:16 AM
