Tire & Wheel Forum sponsored by The Tire Rack |
05-08-2003, 07:43 PM | #1 |
Member#: 15543
Vehicle:555 Having a Subaru shop means too many cars |
Looking for generic 15x6 wheels, 35mm offset? and cheap
Id like to get a set of wheels for use on a strictly off road subaru project I have. Im looking for lower offset to help reduce and chance the larger tires would interfear with the spring perch or inner fender.
Steelies are fine, I just dont know what vehicles to look at. It needs to be the standard 5x100 subaru pattern. Im thinking of using 215/75R15
05-09-2003, 10:29 AM | #2 |
Member#: 20442
NESIC
Vehicle:2022 WRX Limited WRB |
Don't know what your budget is, but the Borbet Type S that Tire Rack sells is 15x7 with 35mm offset and 5x100mm bolt pattern. It's probably a little fancier than you were looking for, but they're pretty reasonably priced ($95 each).
05-09-2003, 11:36 AM | #3 |
Member#: 3887
Vehicle:08 Taco, 98 M3/4/5 '00 RC51, '08 KTM |
Hammers! Your ride will look totally trick! Almost as mint as mine!
05-13-2003, 09:00 PM | #4 |
Member#: 15543
Chuck H: Thanks for the suggestion, those arent so bad but I think they are too wide, I was thinking of thestock wheels used from another vehicle, which would most likely be 15x6
05-14-2003, 06:17 PM | #5 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
FWD Mopar wheels are your answer. K-cars up to 95 and even 'vert Sebrings and neons.
Some FWD GM wheels will work too. Jay Storm www.sourcemotorsports.com |
05-15-2003, 06:09 PM | #6 |
Member#: 20442
NESIC
Most FWD Mopars had wheels with 40mm offset. If you don't mind running 1/4 inch spacers, then they might be a good option because you can pick them up pretty cheap.
05-15-2003, 07:42 PM | #7 | |
Member#: 5218
No spacers required....
Might want hubcentric spacers and/or better studs if you're going to mount some big meat.... |
05-15-2003, 11:36 PM | #8 |
Member#: 15543
Thanks for all the help guys! Didnt even think about using spacers to clean up any small clearance issues.
The vehicle only weighed 2800 pounds to start but had the same basic hub components as the first generation legacy. I plan to tear alot of stuff out of the car too so it should be lighter when Im done. Im not too woried about breaking things. Im also buying a small welder on ebay so that when I do break it I can just slap it back on |
SoCal: 18x8 Kyowa Wheels +35 offset and Stance Coilovers | onesiiickfc | Wheels/Tires | 3 | 12-30-2009 12:07 AM |
looking for a good wheel/tire mounting and balencing shop in Rockville, MD area | 280hp_REX | Mid Atlantic Impreza Club -- MAIC | 7 | 08-24-2009 03:31 PM |
Looking for stock wrx wheel and tire weight | Dave6265 | Newbies & FAQs | 5 | 02-17-2006 01:19 AM |
Looking for oem WRX wheels and tires | Dangerdave | Private 'Wanted' Classifieds | 2 | 11-14-2004 10:33 AM |
Looking for stock WRX wheels or RS Wheels | ChrisV-FL | South East Region Forum | 4 | 09-20-2002 07:05 AM |
