05-10-2003, 03:29 AM | #1 |
Member#: 36409
Vehicle:05 STi Crystal Gray Metallic |
Will a catless WRX pass MA emissions?
Will a catless scoobydoo pass emissions with a stage-4 TXS system? And if not, can one create a Utec profile to use when testing which will lean it out or whatever to pass?
05-10-2003, 11:16 AM | #2 |
Guest
Member#:
Not sure how they are doing the testing there. Out here in Phoenix they hook up to the OBD port and the systems all have to pass. This means we can't jsut reset and get there before a check engine. The systems have to have run x-amount of miles witout reflash or we fail and have to go drive around and come back. We do however get 5 yrs. exemption on a new car. If they just sniff test out there then there is prolly a tuning solution. Good Luck.
Mike PS With ECUTEK you can actually set the perameters of the CEL's so they won't be triggered. This is another way around emmisions issues. |
05-13-2003, 12:34 PM | #3 | |
Member#: 442
NESIC
Vehicle:17 Imp Spurt 00 S2k |
Re: Will a catless WRX pass MA emissions?
We only have the sniffer test to worry about with the AWD, no dyno tuning. Just go up and try it and see what happens. However, there is a 'criteria' that you can fail if your car is 'louder than stock' in MA. Just go someplace and try. |
Passing MA emissions with a trackpipe? HFC? | Aegean93L | New England Impreza Club Forum -- NESIC | 7 | 09-13-2008 11:06 PM |
Will this exhaust setup pass California Emissions | ShawnRS | Normally Aspirated Powertrain | 10 | 10-03-2007 10:50 PM |
Will A Catless DP pass emissions? | wricereaterx12 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 12-01-2006 05:09 PM |
Catless DP and EVO2 exhaust passes MA emissions? | alexcd | New England Impreza Club Forum -- NESIC | 7 | 03-24-2005 01:04 PM |
