05-15-2003, 06:52 PM | #1 |
Member#: 35528
Vehicle:2003 Impreza WRX World Rally Blue Pearl |
Double-Clutch + Rev-Matching
I am very new to stick shifting. My WRX is the car I'm learning on. I'm doing pretty well so far but I'm having trouble with the rev-matching portion of double-clutching. I have experienced an inability to shift to first gear and so I would like to double-clutch to shift into it. My problem is I do not know what to rev the RPMs to to match the car speed (gear and output shaft speed). Is there any trick to this, or is it just a practice type of thing? I did manage to double-clutch once while moving slowly (about 10mph) by revving to about 3000 and then pushing the clutch in and holding the stick against first gear gate while letting the RPMs fall into it slid in to gear. I'd rather not have to over rev the engine and wait for the RPMs to fall to double-clutch.
Thanks a lot! Dan
05-15-2003, 07:59 PM | #2 |
Member#: 33915
Vehicle:2003 Impreza 2.5RS silver |
i suggest practicing double clutch-downshifting at 4th to 3rd gears because it's probably easier, and those gears are a bit more forgiving if you screw up.
as a rule of thumb though, when i double clutch and blip thr throttle, i raise the rpm's by approximately 800-11,000rpm for every gear dropped. of course i'm not sitting there counting the marks on the tachometer...it goes by the "vrooom" sound that the engine makes. after a while i think you get to "hear" if you've revved high enough or not. |
05-15-2003, 09:32 PM | #3 |
Top Scoob 002
Member#: 32771
BAIC
Vehicle:03 Black WRX 04 White M3 |
wow 11,000 thats alot j/k. Yea say your in 4th gear at 3,000 rpm and want to get into 3rd, just simply rev up to 4,000. You always go 1,000rpm more if your are going to one gear lower. 2,000 rpm higher for 2 gears lower, etc.... 10mph is pretty slow so you can pretty much get into first without double clutching. I also have the first gear grinding and so far the highest speed i've been able to get into it was 15mph. Today i double clutched and i still got the grinding while going 25mph. I was in 2nd, clutched in then put in nuetral, cluthed out then revved to 3500 then clutched in quikly and tried to slide into first. Just got the grinding... anyone have ideas?
05-15-2003, 10:48 PM | #4 |
Member#: 25179
Vehicle:2002 Impreza WRX Aspen White |
Pushing too hard?
I don't usually need to down shift into first since its such a short gear but when i downshift into it at 15 to 20 mph i clutch in, bring the rev's up 1k over last reading, put the shifter in the first slot and when i feel contact i try to push it in gently and if it doesn't go at the force level i'm used to using i don't try soo hard that it grinds. I've had the grinding before and now i always associate that with pushing too hard.
I've found what they say at http://www.spdusa.com/new_page_5.htm to be quite enlighting... |
05-15-2003, 11:04 PM | #5 |
Member#: 7374
BAIC
Vehicle:2023 MAGA Hat Model3 grey, or is it gray? |
Practice...I've been practicing on this particular car for a little over two years and I'm still not able to perfectly match revs. I usually do what you are doing, over rev a couple hundred and wait for the gear to snick in when the revs drop to the appropriate level. The times I have done it perfectly have been so sweet, though. When you perfectly rev match you can just dump the clutch and you get no jerkiness at all because your right foot is already where it needs to be.
05-16-2003, 01:41 AM | #6 | |
Member#: 35528
Thanks for all the replies, Dan |
05-16-2003, 08:00 AM | #7 |
Member#: 4203
South East
Vehicle:2009 WRX 5spd hatch Platinum Silver Metallic |
It just takes practice. Soon, you'll have a feel for where the rpms need to be. There is not set rule such as 1k rpms per gear. Sometimes it's more, sometimes it's less. The higher the rpms are in the current gear, the greater the difference will be when you downshift. For example, downshifting from 4th gear at 2k rpms may only necessite 2.5k in 3rd gear (difference of 500 rpms), but downshifting from 4th at 4k may need 6k in 3rd (difference of 2000 rpms).
These numbers are just an example - you have to do it a lot to get the feel of it. |
05-16-2003, 01:06 PM | #8 |
Member#: 12619
Vehicle:02 WRX Wagon #47 SM w/RA gears |
There a big difference in 1st and 2nd gear. The rev match from 4th to 3rd is like Vrooom. The rev match from 2nd to 1st is like Vrrroooooom.
Also, find an empty parking lot and drive around in 1st gear making notes of rpms at 5mph, 10mph, 15 mph, etc. My old Nissan, i could tell you cold what rpm my car was at at a given speen and gear, I'm still learning the WRX gears. Also, always better to overestimate and have the engine spinning faster than the driveshaft this way you don't buck the car in a turn. |
05-16-2003, 02:03 PM | #9 |
Member#: 24472
Vehicle:2001 Miata White |
When going into 1st from a higher gear, you need more revs when you blip the throttle than going into 2nd, 3rd or 4th.
Remember to put the shifter into neutral, clutch out, then blip the throttle. Then clutch in, and gently press on the shifter. Don't try to force it into first. Hopefully, you're pressing the shifter as the revs are coming down to match transmission speed. As they match up, the shifter will practically get sucked into first. If your rolling 20 mph, rev to about 4500 rpm. Your speed will be around 15 when it goes into gear. |
05-17-2003, 04:58 AM | #10 |
Member#: 7677
Vehicle:2005 WRX Blue |
I have found that it does help to rev match when down shifting but as far a double clutching I can't see why you would want to do it. The stock transmision has syncros there for a reason so unless you have upgraded to a syncroless gear set there is really no benifit from double clutching.
05-17-2003, 09:10 AM | #11 | |
Member#: 4203
South East
Also, double clutching as a habit will prevent wear on your synchros. |
05-17-2003, 11:03 PM | #12 |
Member#: 12619
Your synchros will last longer, but even better is that the shifter will almost get sucked into the gear when you double clutch rev match. There's absolutely no notchiness this way and you can shift faster.
05-18-2003, 10:13 PM | #13 |
Member#: 26374
Vehicle:2004 WRX Sedan San Remo Red |
From what I have heard, there are no sychros for 1st gear or reverse...
05-20-2003, 01:57 AM | #14 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Yes, there is a synchronizer on first gear.
05-20-2003, 11:35 PM | #15 |
Member#: 36117
Vehicle:2003 WRX Wagon WRB |
I just recently bought a new '03 WRX and I'm really curious as to everyone's experience on double-clutching in this car. I mean, that flywheel has got to be enormous. How long does it take you guys to double-clutch or rev-match with the stock flywheel? The engine seems to rev extremely slowly for such a sporty car. I owned a Miata before the WRX and it just revved so much quicker with the stock flywheel. Granted, the Miata is naturally aspirated, but is that a factor?
05-21-2003, 02:57 PM | #16 | |
Member#: 15106
hahahaha, AWD... needs more momentum to
get the drivetrain going. i have a protege5 as my commuter and i know wat you mean, the flywheel spins up/dwn really fast vs my wrx. for street, the factory flywheel on the wrx is pretty good, it takes a while to spin, but once you get the rhythm its nothing...actually i feel the wrx is easier to drive than the protege5 because you dont have to slide the lever anywhere as fast. you can take your time shifting and relax while you dust pretty much everyone around you....without you even trying. Quote:
05-22-2003, 11:48 PM | #17 |
Member#: 21857
Vehicle:1987 Barbie Corvette Yeah Baby |
sorry to ask, but what the hell is double clutching? i can asume most of it from the name, but when it comes to my car, i try not to assume very much. so what is it and why? thanks.
05-23-2003, 01:22 AM | #18 |
Member#: 37024
Vehicle:2003 wrx midnight black |
doubble clutch and rev match when you downshift! i just let my friend drive my wrx today (i just got it out of the body shop last night) and he downshifted pretty hard.. my tranny i ****ed up now. hard as hell to get into 1st to 2nd, 2nd to 3rd gets stuck. cars going back to the dealer tomrmow to get it checked out. i only have 960miles on the car!! 3 weeks old 1 1/2 weeks in a body shop. not sure if this has to do much about the topic but the tranny wont take abuse. downshift to help prevent a broken tranny
05-23-2003, 06:25 AM | #19 | |
Member#: 4229
Vehicle:2003 S2000 Did someone say track day |
05-23-2003, 08:32 AM | #20 |
Member#: 5349
Double clutching with Rev matching when downshifting you:
1. You push in the clutch 2. As you are moving the lever through neutral on its way to the lower gear you lift the clutch partway to get rotating assemblies in motion again in the transimission at the same time you want to raise the RPMs to match the lower gear (higher) 3. Then depress the clutch full again as you enter the shift gate of the lower gear and then you should be able to release the clutch with little to no lurch from the downshift. If you combine this with heal/toe downshifting, you can really help the car stay stable entering corners at speed because you can keep even braking pressure throughout the shift. (And all this from an automagic guy Don't worry my swapped Honduh is a manual.) |
05-23-2003, 09:10 AM | #21 |
Member#: 12619
I guess you could release part-way, but I do a full release in neutral. I don't think it matters much and I guess when you get really good and fast, it ends up being a part release anyway.
ellisnc: I totally agree, our cars shift like Hondas when you dbl clutch! |
05-23-2003, 03:57 PM | #22 |
Member#: 33915
wow! this week i've been double-clutching down into 1st when traffic crawls. I always double clutched into all my downward gears, except first because it seemed like after i blip the throttle, the shifter wouldn't suck right in so i'd just give up. I discovered this week that downshifting into first is a bit different than the other gears, in that it takes a second for the gear to get sucked in naturally. All the other gears, it's: vroom>immediately stick it into the next lower gear, but for first gear, it's: vroom>1sec pause>then gear goes in.
on a side note though, 2 days ago my first gear popped out (again) while decelerating in first. 2nd time this happened. "bonk" sound and next thing i knew, i was in neutral. |
05-23-2003, 05:32 PM | #23 |
Member#: 35528
I think it's taking it longer for you to make the suck into first because you aren't reving high enough, but because you have reved close, the synchros have an easier job and so can make the shift after the wait. Try revving higher and it should be like the other shifts.
Dan |
05-23-2003, 07:24 PM | #24 | |
Member#: 33915
05-23-2003, 08:47 PM | #25 |
Top Scoob 002
Member#: 32771
BAIC
oooo it worked i just tried again without forcing it in and i can now do it perfectly. Going from 2nd gear around 25 mph i clutch in, go into nuetral, rev to like 4,000, cluth in, slide into first. It goes in so easly.
double clutching, rpm matching? | skeletorr | General Community | 20 | 02-10-2010 07:19 PM |
How to double clutch/ rev match? | J Kehl | Transmission (AT/MT) & Driveline | 2 | 03-18-2005 10:20 PM |
I rev match, but have reading about double-clutching...why double clutch? | jroberts | Transmission (AT/MT) & Driveline | 2 | 12-22-2003 10:28 PM |
Two stupid rev-match/double-clutch questions (this forum hasn't seen enough of them) | Butt Dyno | Newbies & FAQs | 8 | 05-24-2003 01:11 AM |
('93-'01) Double-Clutching, Rev-Matching, and Gas Mileage? | TimStevens | Impreza Forum | 4 | 05-11-2001 10:09 AM |
