Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Old 05-20-2003, 11:03 PM   #1
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
and bye bye Turtle :(
Default 2.2 to 2.5
how easy is this swap, and is most of it plug and play
Jiffy
SubaruWRC is offline   Reply With Quote
Old 05-21-2003, 11:47 PM   #2
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
anyone?
Jiffy
Old 05-22-2003, 12:40 AM   #3
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Pretty sure
I know the MY97 2.2 is plug and play with all DOHC 2.5 which can be found in cars up to MY99. I believe the MY96 is the same as the MY97 and therefore this same rule should apply. Any SOHC 2.5 will be a much more difficult project. I have a turbo 2.2 right now and I miss the torque of my old 2.5 Turbo in my RS so I'm going to do a 2.5 upgrade. I will probably go for a MY99 out of a legacy or outback so I can get a Phase II engine block.
Joshua
yebokmj is offline   Reply With Quote
Old 05-22-2003, 11:46 AM   #4
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Joshua, I am thinking about going to an EJ22-T in my RS. Is the torque falloff that bad with the 2.2L? I like the torque of the EJ25 but I am convinced it is not a good motor to build up for boost, and the EJ22-T is.
Is it really that noticeable?
Graham
Graham is offline   Reply With Quote
Old 05-22-2003, 11:52 AM   #5
yebokmj
Member#: 2213
Brilliant Red
Default My experiance
Graham,
I find the torque differance is really noticable and for me takes out alot of the enjoyment I had with my RS-T. I'm running a 2.2 NA block with stock compression ratio at 8lbs of boost. My 2.5 was only running 5lbs and was faster and a lot more fun to drive. My setup is a modified JC Sports GB kit. One of my things is I really like power on oversteer in my driving but the 2.2 just can't pull it off. Also there is the fact that to obtain the same HP levels on the 2.2 I have to run that much more boost since I already start ~30hp and torque less.
Joshua
Old 05-22-2003, 03:12 PM   #6
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Yup, not just less displacement but lower C/R on the EJ22 is killing ya! Now, go out and get an EJ22T bottom end and turn up the boost!
How's the car running, Josh?
- Trent
peepshow is offline   Reply With Quote
Old 05-22-2003, 04:07 PM   #7
yebokmj
Member#: 2213
Brilliant Red
Default Car
Trent,
The car is running great thanks, no check engine lights or any problems just to slow. Actually the compression ratio is the same on my 2.2 as the 2.5 I had both are 9.7. I think for my more modest hp goals the 2.5 will make me happiest with best reliablity. Plus it's just fun to rebuild and engine.
Joshua
Old 05-22-2003, 04:53 PM   #8
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Really? I thought the EJ25s were 10:1 or 10.5:1? Ah, well, not the first time I've been wrong.
Glad it's running well! So, you gonna bore out and rebuild your EJ22 block or get an EJ25 and rebuild that?
- Trent
Old 05-22-2003, 06:29 PM   #9
yebokmj
Member#: 2213
Brilliant Red
Default Engine
The DOHC 2.5 are 9.7 the MY99 SOHC is 9.7 all MY00 on are 10.
I will going with a complete engine swap because the 2.2 NA has nothing good, the Heads are SOHC and single port exhaust so they don't flow well at all. My plan is to go DOHC 2.5 out of an MY99 legacy or Outback so I get the Phase II block, if I get Phase I for the right price that's good too. I then will Oring the block and use a slightly thicker gasket to drop the compression a hair I still need to look into gaskets and compression.
Joshua
Old 06-15-2003, 07:27 PM   #10
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
bump
Old 06-15-2003, 09:24 PM   #11
yebokmj
Member#: 2213
Brilliant Red
Default time
I'm about two to three weeks away from doing the swap. Probably more like three. I will let you know how it goes.
Joshua
Old 06-20-2003, 10:54 PM   #12
AlbanianImpreza
Member#: 38506
2000 NEW hotness RSC
SRP SON!
Default hi
what and how can i put in a bigger engine like the wrx 02 into my 98 impreza L is it possible? and do u guys have some pictures or sumthin cuz im not too much of a mechanic
-thanks
-Messiah(yes its my real name)
AlbanianImpreza is offline   Reply With Quote
Old 06-21-2003, 11:34 AM   #13
EddyRS
Member#: 1257
2000 GC8 WRX
93 RS-W Wagon (White) RIP
Putting a WRX engine in any Impreza is no issue. Its the Wiring that is the kicker. All ECU related wires need to be spliced into the existing car harness.
Physically, everything bolts right up without modification.....you just need the proper crossmember. For more into....do a search, it has been documented and discussed in depth.
FYI, I have the WRX motor in my Y2K RS, and currently putting the 2.5L from the RS into my 93L wagon. (Engine compartment of all 93-01 Impreza's is the same) As for wiring I am using a complete Harness from a 01 RS sedan, and converting the whole interior to a 00 OBS sport. Heck the whole car is being converted to RS parts. (Engine, Tranny, Rear LSD, Suspension, basically everything mechanical will be from an RS in a wagon body). I guess i could start calling it a 2.5RSW.
Cheers
EddyL
EddyRS is offline   Reply With Quote
Old 06-23-2003, 11:17 PM   #14
AlbanianImpreza
Member#: 38506
SRP SON!
Default searching for the L and WRX engine swap
i was searching google for a good 2 hrs on google, came up with nothing useful, im really interested in doing it, have my L souped to a WRX, maybe someone kan help me out with searching thanks
-messiah
Old 06-24-2003, 09:47 PM   #15
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
this is the clearest answer i have seen, http://www.fakewrx.com/car4a.htm this also applies to 2.2 as well.
Jiffy
Old 06-25-2003, 12:36 AM   #16
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
Jiffy, mikey here.......i met u at a beaver springs auto x and at stpr briefly.......i could provide some major insite to this, as i did the swap in my fwd 95 l, then pulled the motor, sold it to a buddy, and we put it in his awd 97 L......next time we meet up, at a auto x or what not, i could help out with alot, one of the main problems i had, was, i had no idle air control, so as soon as u cranked it, you had to hit the throttle, i only had mine rigged for a week or so, but it was so fun
-mikey
Jiffy
mcu81 is offline   Reply With Quote
Old 06-26-2003, 09:07 PM   #17
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
-mikey
cool Mikey, any help will be greatly appriciated
Jiffy
Old 06-26-2003, 11:32 PM   #18
95urabus
Member#: 38418
1995 Impreza
Bright Green
Default What if. . . You have an automatic?
Is this still pretty easy? Can you use the tranny from the 2.2lx. Is the 2.5 Turbo or NA. Mine is the 2.2 SOHC. Its a 95. I'm sorry for my ignorance, but I'm new to subarus, or piston engines for that matter. Ive always had rotary cars until this year and I've never had an automatic.
95urabus is offline   Reply With Quote
Old 06-28-2003, 11:30 AM   #19
Levvy
Member#: 10700
1997 Impreza L Wagon
1974 Honda CB550 --rip--
yebokmj,
Emailed you about your swap.
Levvy is offline   Reply With Quote
Old 07-17-2003, 11:37 PM   #20
yebokmj
Member#: 2213
Brilliant Red
Default up
My swap is complete and the car runs no check engine lights and no wiring what so ever. While the engine was out I updated the headgasket and O-ringed the heads for my turbo. I have yet to really drive the car since I need to get the valves adjusted.
Joshua
Please help me!! 2.2 sohc to 2.5 dohc swap problems! lomaxmotorsports Normally Aspirated Powertrain 7 07-19-2008 01:29 PM
connecting 2.2 ecu to 2.5 harness?? farrell Engine Management & Tuning 0 08-04-2004 12:51 PM
Yet another 2.0 to 2.5 sti block ? serious Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 12-22-2003 04:24 PM
2.0 to 2.5 block swap, what's the ideal Compression ratio? 516_WRX_V2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-25-2003 01:44 AM
Forester 2.0 to 2.5 engine swap???help Breen Subaru Conversions 14 10-15-2003 11:01 PM
