05-22-2003, 07:37 PM | #1 |
Member#: 3461
South East
Vehicle:1998 BMW M3 Coupe Estoril Bleau |
Greddy 52mm EGT Gauge Needle stuck at 1200 Celcius...
yes, I have searched and haven't found much on this. I just installed the Greddy EGT Gauge in my RS and when I turn the car off, the needle goes past the 12 mark on the right.
When I turn the car back on, after about 4 minutes, the gauge starts functioning again. Very weird. I don't think I have the wires connected wrong: 12v Constant: #4 Fuse Box (Cigarrete Lighter) 12v Switched: #? Washer Illumination: #? Illumination Location on the Fuse Box Ground: Bolt that holds the brake pedal assembly to the firewall of the car. I unplugged it and the gauge needle goes back to the bottom as normal soooo I don't know. Any ideas? Perhaps I do have the 12v Switched or one of them screwed up... Any help would be greatly appreciated. Thanks, Kevin
05-23-2003, 09:17 AM | #2 | |
Member#: 2817
Vehicle:2001 Impreza 2.5RS BRP |
You wrote:
12v Switched may be ok in that position. I used the cigarette lighter wire. Illumination has nothing to do with your problem. Ground seems to be ok. |
05-23-2003, 11:46 AM | #3 |
Member#: 3461
South East
I'll just go back and use a damn relay like had originally planned to power my 4 gauges and other things that need 12v constant and 12v switched....
I just wanted to use this as a temp solution while i get the other gauges... |
05-24-2003, 06:26 PM | #4 |
Member#: 35427
Vehicle:2003 WRX Sedan WRBP |
The cig wire for power is likely your problem. I know in the 02+ it is not constant voltage with the key off so when you kill power the gauge stops functioning.
Sounds like you are headed the right way with the relay though. |
Greddy 52mm EGT Gauge + Probe | caldweb | Engine/Power/Exhaust | 4 | 11-28-2006 11:17 PM |
Greddy 52mm EGT gauge | 92xturbo | Electrical & Lighting | 2 | 06-19-2006 10:08 PM |
GReddy 52mm EGT Gauge NIB FS! | a87supra | Private 'For Sale' Classifieds | 7 | 01-09-2006 06:33 PM |
Brand New Greddy 52mm Egt Gauge | DeBlueSoobaru | Private 'For Sale' Classifieds | 2 | 12-12-2004 10:50 PM |
Greddy 52mm EGT gauge help | Turbotegra | Normally Aspirated with bolt-on Forced Induction Powertrain | 1 | 01-26-2003 02:04 AM |
