Welcome to the North American Subaru Impreza Owners Club Sunday May 28, 2017
Old 05-31-2003, 02:00 PM   #1
marioej18
Member#: 31115
Default no A/C=more power?
some people have told me that if you take the belt off of the a/c that you will feel an increase in power. is this true? i doubt that it does anything, but im just curious.
marioej18 is offline   Reply With Quote
Old 05-31-2003, 02:56 PM   #2
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
For the most part...no
While the A/C is running, it takes no more than 5HP or so form your engine...and thats WHILE the A/C is on. If its not running, the belt is just going around on bearings...taking like .001 HP away.
Just keep the A/C off and you wont lose any power.
DDMan is offline   Reply With Quote
Old 05-31-2003, 03:35 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The only thing you will get from disconnecting the AC is a damaged AC system when you finally reconnect it.
Old 05-31-2003, 04:00 PM   #4
TheDonPerignon
Member#: 30299
of course if you take out your entire A/C youll lose some weight though. make that power you already have more useful
TheDonPerignon is offline   Reply With Quote
Old 05-31-2003, 04:20 PM   #5
Cujo31
Member#: 19843
2000 2.5 RS Sedan
2016 Base 5MT VRP
/unsolicited further advice.....
taking the belt off alone is pointless because if you look at the pulley, while the AC is off, the belt is just spinning freely on the hub of the AC pulley... its already almost like having the belt off anyway....
then when you actually push the AC button, a little clutch engages and the whole pulley spins and pumps the system.
Cujo31 is offline   Reply With Quote
Old 05-31-2003, 10:56 PM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
except that will net you about 15 lbs in weight savings, not worth it for comfort IMHO.
jeremy
Old 06-01-2003, 10:27 PM   #7
TheDonPerignon
Member#: 30299
very true...all depends on what you want
Old 06-02-2003, 04:58 PM   #8
kickin_81
Member#: 16679
2004 Forester XT
Look. It won't give you a lot of hp as what a lot of people are expecting it would and it won't allow you to use your AC/Defrost, but it will give you a bit better revving. If you look at it, you'd guess the pulley for the AC probably weighs 1-2 lbs (just the free turning side of the pulley), the supporting pulley is like .5-1 lb, and the belt is about .1 lb. I'd say it takes off around 2 lbs of rotating mass. It's worth a bit of free hp.
I have my AC belt off for almost 2 months now, and I am happy with it. I don't need AC or defrost right now... so I'm saying this 15 min. modification was worth the little power. When it gets hot, I won't mind spending another 15 min putting the AC belt back on. (It'll probably take about 30 min-1hr if you havn't taken off the belts before).
Take this as my 2 cents for you.
kickin_81 is offline   Reply With Quote
Old 06-02-2003, 07:21 PM   #9
DoinkMobb
Member#: 3787
2008 Gay
Car
Man, you haven't driven my car. I swear it feels like I loose about 50% of my power when I have the AC blasting.
DoinkMobb is offline   Reply With Quote
Old 06-03-2003, 11:56 AM   #10
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
ueah... 50% for us = 5 hp
moogoob is offline   Reply With Quote
Old 06-03-2003, 05:42 PM   #11
marioej18
Member#: 31115
its true! when i blast my a/c, it kills the car.... like instead of hitting the brakes, i could just leave it in gear and turn on the a/c to slow me down.... its really that bad! oh well, i guess you cant make a 1.8L any faster, time for a new car......
Old 06-03-2003, 06:10 PM   #12
ciper
Member#: 15543
90BJ Legacy LS ABS
kickin_81: You dont understand, the AC system needs to circulate once every once in a while to keep it in good shape. Removing the belt is only causing parts to be damaged. Why do you think some vehicles who have the AC basically permanently on still function many years later but the ones who sparingly used it have problems?
I would argue that the gains from removing the belt are so small you could NOT measure them, meaning I doubt you would ever feel them. The better alternative for all out speed would be to completely remove the system.
Old 06-04-2003, 10:59 AM   #13
NC2.5RS
Member#: 19313
2007 Scion tC
Black Sand Pearl
The power gains are pretty insignificant really.
NC2.5RS is offline   Reply With Quote
Old 06-04-2003, 02:08 PM   #14
kickin_81
Member#: 16679
2004 Forester XT
Hey, guys! Well, I know that removing the AC belt will not gain me as much hp as a lightened pulley, but it does help. If you were to test a 40-70mph run in third gear, I think the most it will net you is .1 of a second. It won't make you any slower. I've read before that it's better to run your AC year round to keep the AC from rusting (for lack of better word). I agree with that, but I've never heard of AC reliability issues related to taking off the belt. I still think this is a good, free mod worth doing to release a bit more hp. Like I said, I can always spend another 15 min. of my life to put the belt back on. This modification/removal will not put you or your passengers at risk of anything (besides the whinning about no AC ). You just roll the window down if you need to cool off. I will put my belt back on when it gets too warm. For some of us, getting every ounce of hp from the $$ you have is worth it. Thanks for your concerned inputs, fellas. Always happy to hear the pros and cons of things.
Old 06-04-2003, 09:03 PM   #15
joefocker20
Member#: 13745
2015 STI
Umm.. removing the AC belt will net more gains than a lw ac pulley since there is less parisitic drag. I doubt I noticed much of a difference when I did it, but like everything else, its cumulative. If you can find 5 small mods to net you 1-2 HP, thats 5-10 extra HP that you have on tap. Not alot, but we have to work with what we have!
joefocker20 is offline   Reply With Quote
Old 06-04-2003, 09:49 PM   #16
ciper
Member#: 15543
90BJ Legacy LS ABS
joefocker20: Actually, you are wrong.
Old 06-04-2003, 10:04 PM   #17
joefocker20
Member#: 13745
2015 STI
Humor me. How would a belt routed around another pulley produce more power, unless its a S/C pulley?
Old 06-04-2003, 10:24 PM   #18
ciper
Member#: 15543
90BJ Legacy LS ABS
The lightened pulley is removing aproximatly 3.5 pounds of rotating weight. The portion of the AC pulley that spins might be .4 pounds. This weight is more important than non moving weight on the vehicle because you are accelerating it from 500rpm to 6500rpm. 3.5 pound "mini flywheel" with that much change in speed adds up.
The lightweight pulley has small gains to begin with. Having 1/8.75 of the gain from removing the AC is a joke. More gain in acceleration would be had by removing the two heat exchangers and leaving the pump attached!
The AC pulley has so little friction its not even funny. The power loss (which is near unmeasurable) from the resistance of the belt and additional mass is what you are dealing with.
Actually, Id even say your vehicle would be faster by getting some 400 treadwear tires, less forward rolling resisistance. I guarantee your gas mileage would increase
edit: I coudlnt figure out what S/C meant for a while! That doesnt count.
Old 06-04-2003, 11:43 PM   #19
kickin_81
Member#: 16679
2004 Forester XT
Ciper, are you speaking your words from experience? If not, then what you are saying about this mod being a waste of time is just your opinion. If you have not weighed the thing yourself, then I don't believe you. I don't mean to point fingers, but you are saying it like you went through extensive research on this matter, but you aren't showing proof. There's no hard evidence on the overall weight of the 1) free-play side of the AC pulley, 2) the belt, and 3) the tensioner pulley. With the belt off, I can play with the AC pulley and it feels like it weighs clost to 2 lbs. The tensioner pulley feels like it's .5-1 lb. This is my opinion.
I agree that the AC belt rotates two pullies that has no friction associated with them. If the pullies did have friction from the factory, I would prefer to leave it alone since it was designed to power something useful. ...But, if the crank pulley is rotating about 2lbs of mass that are just mass... why not? Who would have believed that exchanging the 5lb stock crank pulley to a 1.19 lb pulley would feel so good? No one did... until a market was created for them. The public liked it, so it became a performance modification. It was just lighter, yet it gave/freed more power in all the gears... about 2.7hp per lb of rotational mass to be exact.
Let me make myself clear... this will not net you gains as much as a CAI or an exhaust. In my honest opinion, I feel I freed an extra 1-4 hp. The choice is up to whoever wants to do it to their car. Besides, there are no known side effects other than the loss of using the AC (until you put the belt back on). The gains I got were small... barely noticable, but why not for that hint in power?
ps- Joe, you took off your AC belt, too? I thought I was the only one?
Old 06-04-2003, 11:48 PM   #20
joefocker20
Member#: 13745
2015 STI
Well, I already have a lw crank pulley, and the AC pulley is now just sitting there still, along with the tensioner. I don't know how much it will help, but it will help. I may just be nervous, but I did all kind of stuff that's debateable to free up a few ponies before I go to the drag strip on Friday. I put Royal Purple Oil in, Mobil-1 gearoil when I changed my clutch and flywheel, bypassed my TB, ripped out my rear seat, and I'm going to see how I can reduce more weight tomorrow. I want to get a 15.* @ 6000 ft above sea level this week
GC SWAP: 05 WRX Motor, 04 STi Dash Swap, no more power mirrors! psyber_0ptix Subaru Conversions 2 04-20-2009 03:54 PM
New UTEC maps! No more knock, now for more power.... bpwatts UTEC 52 03-23-2007 01:05 PM
no more power??? subwrx03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-10-2006 10:35 PM
IL, CHICAGO: Feeler- Vibrant Cat-back Exhaust FULL 3" NO RESONATOR/FLEX = MORE POWER! RedLine55 MWSOC Private Classifieds 2 07-27-2006 01:49 AM
More Power using AP...More more more! waddamadda Engine Management & Tuning 4 05-31-2005 10:06 PM
