Welcome to the North American Subaru Impreza Owners Club Wednesday November 21, 2018
Old 06-27-2003, 05:49 PM   #1
kunfuzion
Member#: 1094
'85 Levin Hatch
color of rust
Default WRX tranny--->EJ25rs Motor???
I'm hoping somebody will know what I'm asking for? Does a WRX tranny (02 up) w/ clutch/flywheel bolt onto a EJ25 rs motor (98-01)? My rs tranny needs to be rebuilt, and I will need a something stronger. Wondering if any techs have tried or know if it will work? Any other alternate solutions besides fix my current tranny? Thanks in advance.
Jeff
kunfuzion is offline   Reply With Quote
Old 06-27-2003, 07:16 PM   #2
stentorian
Member#: 12959
2017 Focus RS
I am pretty sure the tranny will bolt right up. The clutch and flywheel I think have to be your car specific (I think). Reason why I say that is because a friend here wants a WRX tranny, but has his own clutch and flywheel setup in his RS.
-Joe
ps- Not sure if you have to change any other parts like the rear diff???
stentorian is offline   Reply With Quote
Old 06-27-2003, 08:27 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Any of the 4EAT and 5MT transmissions will bolt right up to any EJ series motor. The only things you must watch out for are mating the proper rear diff to the transmission and making sure you have a pull type clutch/flywheel to go with a pull type tranmission and a push type to go with a push type transmission.
-Jon
Old 06-27-2003, 09:04 PM   #4
tbd
Member#: 15322
1995 gf wagon
Blue Green Metallic 340
Default what does repair cost?
just to get an idea for what alternatives are cost effective.
i'm not sure the wrx tranny is much stronger than what you have esp. if its from a usdm. if you do swap, to 02 wrx, be prepared to swap rear diff, and driveshaft or swap ring & pinion in rear diff to fit tranny as your driveshaft does'nt have the reduction ratio.
nice chart.
http://wac.addr.com/auto/obs/lsd/lsd.html
an 02 rs tranny would'nt be much stronger either, but with those you could keep the same diff, clutch, prop shaft in exchange for ratios that are taller?
tony
tbd is offline   Reply With Quote
Old 06-28-2003, 01:44 AM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Oh yeah, I forgot to mention that the strength argument for an upgrade is greatly discounted unless you go with a JDM tranny or an STi tranny.
To be the most cost effective, it would probably be best to get a moderate mileage transmission from someobody in the private classifieds or from a junkyard. Should be able to find one for about $750.
-Jon
2.5 liter STi motor w/wrx tranny? reach4theslvbullet Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 02-13-2006 06:04 PM
Build Tranny and Motor for 300WHP WRX??? Boxer112 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-27-2005 12:51 AM
'03 WRX part everything, motor, tranny, subframe, seats just look....everything SubyDuz Private 'For Sale' Classifieds 64 05-03-2005 11:21 PM
WRX and STI Motor and tranny wrxben Private 'For Sale' Classifieds 19 04-01-2005 03:00 AM
WTB: 02-04 WRX w/o motor or tranny Txsleeper Private 'Wanted' Classifieds 6 12-14-2003 03:12 AM
