Welcome to the North American Subaru Impreza Owners Club Monday January 22, 2018
Old 07-07-2003, 01:59 PM   #1
sasha143aid
Member#: 12016
2001 Impreza 2.5 RS
Default 2.5 turbo from Forester XT
I hope I'm posting the thread in the right forum. But in any case. I have a 2001 Impreza RS and am quite curious if the turbo kit fitted on the forester will fit perfectly into my engine bay. Checking out the specs on the forester I noticed that the engine is DOHC instead of SOHC which is what I have. Would that be a problem. Any suggestions or recommendations would be appreciated. I am aware of the turbo kits from companies like Ludespeed and so on but what I was really hoping on doing is drop in the stock setup that the forester is using, first because it will probably be cheaper and I'm assuming more reliable, not to call the other turbo kits unreliable but I hope you understand my drift. Plus the power that the forester produces would be perfect to what I'm looking for.
sasha143aid is offline   Reply With Quote
Old 07-07-2003, 02:04 PM   #2
ForesterPerformance
Member#: 5424
BRP STi Version 3
Type RA V-Ltd RHD
Remember this... the XT uses the same motor as the STi. Just smaller injectors, and a smaller turbo and intercooler. MUCH lower compression than your RS motor has, and running 12.5psi in your RS motor without lowering the compression and good engine management will be less than reliable.
I would say either do a complete motor swap or stick with a kit designed for the N/A RS motor. LudeSPEED kits are great. I have one on my car, and so do 2 of my friends. The Stage II kit should put your RS right at the power level of the XT anyway.
Good luck.
ForesterPerformance is offline   Reply With Quote
Old 07-07-2003, 07:39 PM   #3
rhdude
Member#: 6637
2009 Acura MDX Sport
so you are saying the forester turbo has the exact same block and heads and internals as the STi?
**goes to look for a wrecked forester turbo**
rhdude is offline   Reply With Quote
Old 07-07-2003, 07:58 PM   #4
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
The STI and Forester XT more then likely share the same shortblock as subaru is still a partsbin company. Then again, subaru has been known to do some crazy ass stuff for no apparient reason....
DoctorNick is offline   Reply With Quote
Old 07-07-2003, 11:08 PM   #5
Hondaslayer
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
Yep,
The shortblock makes a good stool too SUCKAS!!!!!
Now to go blow my motor up so I can install this damned thing!
Old 07-08-2003, 12:41 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
there is also a possibilty that they share the same heads too both have the avcs and sodium filled valves
Old 07-08-2003, 12:45 AM   #7
ForesterPerformance
Member#: 5424
BRP STi Version 3
Type RA V-Ltd RHD
there has been alot of talk about this on the Forester Forum of this site...
The only difference in the heads between the XT and the STi is the camshafts...
Old 07-08-2003, 11:10 AM   #8
rhdude
Member#: 6637
hum, get block from forester XT... port and polish my heads... buy link ECU and fuel rails/injectors.. run 12psi... sounds like a plan!
Old 07-09-2003, 11:08 AM   #9
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
It's a dream several of us share...
Chromer is offline   Reply With Quote
Subaru Forester 2.5 Turbo Ej257 Front Main Harness maestro Engine/Power/Exhaust 25 03-13-2011 06:03 PM
Forester 2.5 Turbo Motor 26k Miles Complete Tatmana Engine/Power/Exhaust 0 11-24-2009 12:06 AM
98 Forester 2.5 Turbo To Buy Or Not To Buy Co Taco Newbies & FAQs 2 02-20-2008 06:58 PM
FS: Forester XT 2.5 Turbo 2005 Limited mojoey Private Vehicle 'For Sale' Classifieds 2 08-30-2006 01:58 AM
Stepping up from Forester XT to STI tytek General Community 9 01-09-2005 12:31 PM
