Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 07-17-2003, 02:27 PM   #1
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
Default 2.5rs with complete JDM WRX swap done!
I finally finished it! Everything is ok few minor things with alternator and stuff but all is well now. I have 99 2.5RS with EJ20 JDM WRX swap which includes: engine, tranny, rear diff, driveshaft, ECU, cluster, smog canister (ahah), radiator, and turbo pressure regulator stuff. Will have pistures and video up soon! If you haev any questions about this swap or wiring let me know. Peace out for now off for a drive to temecula!
AWJunkies is offline   Reply With Quote
Old 07-17-2003, 02:42 PM   #2
CRS9
Member#: 7175
1999 Impreza 2.5RS
Default Pros and Cons
Besides HP (would also like to know that), why did you decide to do JDM WRX vs USDM WRX?
CRS9 is offline   Reply With Quote
Old 07-17-2003, 02:58 PM   #3
Puckaveli
Member#: 1518
00 2.5RS
Do you still have your 99 instrument cluster? Wanna sell it?
Puckaveli is offline   Reply With Quote
Old 07-17-2003, 03:10 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
what motor did you swap in a g,k,5,7?
Old 07-17-2003, 03:18 PM   #5
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
yes i have the cluster and milage is 59000. I will sell it! I was going to put it in friends car that I put my old engine into but he owes me so much money and I am over it. Slap a price down and location. To the other guys HP not sure yet. Will dyno it soon! As for g,k,5,7 not sure it was out of a 95 WRX air to air intercooler black. Forgot what it was, mike shields told me but forgot the second after (i think G or K). If you give me description of all those I will tell you which one. It is not STI, I wanted more low end and turbo to kick in earlier. One thing I hate is it tops out at 120 (ECU shut off). I will fix that though eheheh!
Old 07-17-2003, 04:03 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
cool 95= G
if its from a sedan 250ps (comes with a td05)
wagon 220ps (comes witha td04)
Old 07-17-2003, 10:27 PM   #7
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
sedan 250ps with tdo5 yes that is correct
Old 07-18-2003, 06:42 PM   #8
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
well that TD05 spools much slower then the turbos on some STi's. The vf28 in my ver 6 spools very fast but flows less then the tdo5. The td05 is more a big power top end turbo. I got my speed delimiter from Taichih in a group buy for a very good deal. maybe drop him an email. Did you do the swap yourself?
Scoobie Steve is offline   Reply With Quote
Old 07-19-2003, 07:32 AM   #9
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
YES! I did.
Old 07-19-2003, 05:44 PM   #10
serious
Member#: 22879
I just guessing since you have your st rs guages you used the wrx guage pod right? I would like to know how you wired it all in. If you completely removed the rs and installed the wrx harness or just cut and spliced?
I will be doing this to my legacy as soon as i get the wirriering delima figured out!
Thanks
brent
serious is offline   Reply With Quote
Old 07-20-2003, 02:19 AM   #11
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
well for JDM to work you just need to splice in power continous and power ON. also ground it that is it. And I have both clusters right now trying to get US diagnostics to work. One problem you may encounter is alternator. I will explain if you would like just let me know.
Old 07-20-2003, 03:20 PM   #12
serious
Member#: 22879
Fire away.....
Brent
Old 07-20-2003, 03:35 PM   #13
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
The alternator gets a signal from your cluster to turn on. Very low signal. And if you change clusters you have to wire that in which is hard cause to make it work you have to have every circut active on cluster. I spliced in a different wire to alternator which could shorten the life of it but it is all I can do at this time. I used AC ON wire it is located right nere the AC. It is the middle wire of the three. I don't have AC so I am able to do this others have to find another wire or trace the cluster wire and build some kind or fuse or resister for it. If you give it to high of a signal it just will put your alternator on high charge mode all the time and could burn it out earlier. No biggy if you find a place that will replace burnt out ones for free up to 4 times within a year like me. If you need any more info let me know this is small bit of it.
Old 07-20-2003, 04:23 PM   #14
serious
Member#: 22879
Dang, you're making me not want to do this swap all of a sudden! Didn't even know there was such a thing as a wire from the tach to the alternator.
Oh well, guess i'll just install the complete wrx harness.
Brent
Old 07-20-2003, 05:39 PM   #15
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
OH HELL!! so many more problems then what I just said. I thought I had it figured out. Man oh man where to start. I told you I spliced AC wire right well ****. It made a HUGE short and made my fuel pump click off and on and pressure regulator go funky. It was messing with my electrical BIG time. Basically I have to ground the alternator and give it power ON. Stay tuned on how I do this. Peace for now.
Old 07-20-2003, 10:35 PM   #16
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
OK best advice ever just keep stock cluster and splice in necesary wires for tach and so on. Thanks peace out looks all good. Will drive it tonight and see if check engine light comes on! Lets hope it doesn't.
Old 07-22-2003, 06:30 PM   #17
eclip5e
Member#: 14686
2002 RASpec Impreza
Dent Sport/visual assault
Do you have a rough estimate of how much Time + money it took to do the swap?
eclip5e is offline   Reply With Quote
Old 07-22-2003, 06:38 PM   #18
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
ahah time wow a lot. If you have someone like me who has done it before it will be piece of cake. But first time long time! Money all depends on your connections and how much of the work you do yourself.
Old 07-22-2003, 06:39 PM   #19
eclip5e
Member#: 14686
2002 RASpec Impreza
how much did it cost you personally?
2000 2.5RS with 02-03 WRX engine swap overheating Xcasinonightzone Subaru Conversions 12 01-22-2009 12:17 AM
FS: 2000 2.5RS Coupe W/ USDM Motor swap done by PDXTuning I3izzy NWIC Private Classifieds 2 10-03-2008 09:42 PM
2000 2.5RS with 2004 USDM STi Swap Brood Private Vehicle 'For Sale' Classifieds 36 02-25-2008 06:15 PM
Testing Water: 1999 2.5RS with Extra JDM V4 STI Motor. XyKo NESIC Private Classifieds 5 11-15-2006 06:40 PM
FS:2000 Impreza 2.5RS with USDM STI Engine Swap latinskllz Private Vehicle 'For Sale' Classifieds 114 06-16-2006 05:43 PM
