Welcome to the North American Subaru Impreza Owners Club Sunday September 23, 2018
Old 07-18-2003, 10:50 PM   #1
Boost4U
Member#: 16459
1998 2.5RS
Default Bulkhead wiring harness?
This is the harness that plugs into the ecu and feeds through the firewall right???? This is the one that gets spliced??
Boost4U is offline   Reply With Quote
Old 07-19-2003, 01:54 PM   #2
Puckaveli
Member#: 1518
00 2.5RS
The bulk of the BWH is under the dash. It runs through the firewall twice. This is from a JDM Ver1 but it should give you an idea. It is the one that needs to be spliced for most swaps.
Puckaveli is offline   Reply With Quote
Old 07-20-2003, 12:04 AM   #3
Boost4U
Member#: 16459
1998 2.5RS
Do you know anyone who has one for a MY02 WRX???
Old 07-20-2003, 12:32 AM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I know someone (lemme get em for ya)
-Jon
Old 07-20-2003, 12:44 AM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
-Jon
Old 07-20-2003, 06:12 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
holy cow ...
that makes my head hurt
Old 07-21-2003, 01:07 AM   #7
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
omg
so if you wanted to do a harness swap for a motor transplant woudl you just splice the sectoin wher the ecu is or woudl you wire in all of the other stuff as well?
subiekid is offline   Reply With Quote
Old 07-21-2003, 09:44 AM   #8
Puckaveli
Member#: 1518
00 2.5RS
In a VERY plain description, basiclly you need everything from the engine side of the BWH and all the wires leading to the WRX ECU and splice those into your RS BHW because that is what your dash will remain as. So in a nutshell from the two BWH you need:
WRX-engine wires
RS - interior wires
I'm sure someone can chime in and give you a more elaborate description. Or call i-speed and ask why you pay them so much to do wiring service and they might explain it to you.
Old 07-21-2003, 02:58 PM   #9
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Like Puckaveli said, all you would need to do is splice the front BWH into your existing wiring inside the car as well as intercept all wires that must go to the ECU and route them appropriately. This is all heresay of course, since I haven't started on my wiring yet.
-Jon
Old 07-21-2003, 03:44 PM   #10
Puckaveli
Member#: 1518
00 2.5RS
Let's say you are dropping a WRX motor and tranny into a 2000 RS and nothing else. If you get a complete WRX BWH and a RS BWH, then just get the pinouts for the WRX ECU and go down the list one pin at a time and think "does this wire go to a system that is in the dash or in the engine". Engine systems will require the WRX portion of the BWH and the dash systems will require the RS BWH. For example from my swap:
Plug B44/terminal 17 is the radiator fan 1 control - that is in the engine bay and would be controlled through my JDM harness and would not need spliced.
Plug B44/terminal 19 is the malfunction indicator light - that is in my dash so it is controlled through my RS harness and would need spliced.
Plug B44/terminal is the pressure exchange soleniod valve - that is in the engine bay and is controlled by my JDM harness and would not need spliced.
When you look at the pinouts there really are not a lot of wires that need spliced.
Old 07-21-2003, 05:23 PM   #11
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I hadn't gotten to wiring methodoligies yet. Thanks for the incite Puck.
-Jon
WTB: 02-05 WRX bulkhead wiring harness or JDM V7/8 bulkhead legacy2003 Private 'Wanted' Classifieds 6 02-05-2008 03:46 PM
Bulkhead wiring harness - 2000 2.5RS Puckaveli Private 'For Sale' Classifieds 5 05-18-2004 09:13 AM
Needed: WRX bulkhead wiring harness vishnu Private 'Wanted' Classifieds 3 03-31-2004 06:32 PM
WTB: 02 WRX bulkhead wiring harness RedBrighton96 Private 'Wanted' Classifieds 2 02-03-2004 12:38 AM
Bulkhead wiring harness?? Boost4U Subaru Conversions 7 06-13-2003 05:29 PM
