Welcome to the North American Subaru Impreza Owners Club Thursday September 21, 2017
Old 07-25-2003, 02:27 AM   #1
Avenger
Member#: 1234
Default Lower resistance plug wires?
My #3 spark plug wires went out a few days ago and I had a bad miss fire. But before I put the new set in I measured the resistance of the new one and they were about 1k ohm each wire but stock wires were about 7k ohm each except for #3 that was open. The specs from the subaru manual states that the wires should be about 7k ohm to about 16k ohm.
The car runs much smoother than before now. I'm just wondering is there any thing good or bad with running lower resistance wires.
Avenger is offline   Reply With Quote
Old 07-25-2003, 02:47 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
bad things: electrical interference
good things : hotter spark
Old 07-25-2003, 11:34 AM   #3
seven881
Member#: 8828
01 BRP 2.2T Hybrid
08 Tundra
What plug wires did you buy?
seven881 is offline   Reply With Quote
spark plug wires/ plugs reality1011 Normally Aspirated Powertrain 30 02-27-2010 10:09 AM
FS: STi spark plug wires for non-coil-on-plug turbo engines Necromancer VIC Private Classifieds 6 09-20-2009 12:35 PM
Can a check engine light be caused by bad spark plugs or bad plug wires? pico Newbies & FAQs 7 06-27-2002 04:57 PM
Ignitions, spark plugs & plug wires? scubaracer Normally Aspirated Powertrain 8 03-19-2002 04:17 AM
Sparg Plug wires and plug question sparco Normally Aspirated Powertrain 4 02-13-2002 01:41 PM
