09-17-2003, 10:31 AM | #1 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
User-tune EcuTek ECUs with 'dual maps'
So, I started realizing something after finally getting some time to play more with the user-tune features of my Vishnu stage 1 ECU reflash.
I want to make sure it is perfectly clear to other people how this works, because I feel it's currently clear as mud. The dual map feature has absolutely nothing to do with user-tune capabilities. You cannot configure your own parameters in the user-tune screen and apply them to map A or map B. Every user-tune adjustment on the user-tune screen is a global change that will affect both map A and map B alike. So much for making my own version of the valet map for map 'A' (Sorry, Shiv, 200WHP does not cut it for a valet mode IMO) I'm disappointed with myself to realize this now. How many of you were aware of this when you bought your EcuTek user-tune ECU?
09-17-2003, 10:44 AM | #2 |
Member#: 24890
SCIC
Vehicle:2002 Jackwagon WRB GG |
I asked them specifically about it when I ordered the reflash and they explained that the "B map" only controlled boost
09-17-2003, 10:49 AM | #3 |
Member#: 8512
South East
If you adjust boost while currently set to either map, then switch maps, you will see the boost setting remain as you had previously set it.
Now, whether or not map 'A' does some special thing where it ignores what you put in the boost adjustment, I don't know. That sounds like what they told you. |
09-17-2003, 12:12 PM | #4 |
Member#: 23676
NESIC
Vehicle:. |
WOW what an incredibly usefull management solution
09-17-2003, 10:49 PM | #5 |
Member#: 33410
Vehicle:08 wrx dgm |
i think too people think DD is like the utec. it's not. if you dump 112 octaine gas in and go to the track you can adjust your ignition, fueling etc across the board.
I actually didn't know this when i bought my DD, but then again that feature wasn't released yet. I will have to play with the boost map like you describe, i'll post results. |
09-18-2003, 11:00 PM | #6 |
Member#: 39415
TXIC
Vehicle:STI 444/452@26psi 479/492 @ 30psi GT30R .82 |
This is true. I didn't know it when i bought the dd. However i don't care. As far as i'm concerned i bought the car for ME and to drive hard. So the last feature i'm looking for is vallet mode. I wanna go fast.
So far i like DD. I put race gas in at the track and turned up the boost a litle and timing. My times didn't change. Then again i'm not tuner. |
09-19-2003, 11:29 AM | #7 | |
Member#: 8512
South East
I just got the very strong impression that there were 2 tweakable maps that could have user-tune settings each. Laaaame. |
09-19-2003, 08:52 PM | #8 |
Member#: 33979
South East
Vehicle:2006 STi WRB |
I got similar impressions based on the wording of the advertising at EcuTek. I realized the possible dual interpretation after being smacked down thinking "user tuning" was more than it really was.
09-30-2003, 04:32 PM | #9 |
Member#: 29874
Vehicle:2002 wrx mblackp |
is it possible to have seperate a 93 octane map in the normal mode, and a 100 octane map for the 'valet' map?
09-30-2003, 04:35 PM | #10 |
Member#: 8512
South East
Not via user-tune settings on an off-the-shelf setup.
You would need to have it flashed that way by your tuner. |
What the H3ll happend to user tuneing for 04/05 wrx and Ecutek? | nicholam | Commercial ECU Reflashes | 12 | 05-27-2007 11:02 AM |
Advanced users and ECUTEK/UTEC users, read.. | RiftsWRX | Engine Management & Tuning | 28 | 01-08-2005 12:46 AM |
Part 2: An EcuTek DeltaDash User-Tune Primer | jblaine | Engine Management & Tuning | 6 | 08-31-2004 05:32 PM |
any recommendations to get tuned in socal with ecutek? | petawabit | Southern California Impreza Club Forum -- SCIC | 84 | 08-23-2004 07:53 PM |
Part 1 - EcuTek User Tune Primer | jblaine | Engine Management & Tuning | 8 | 06-29-2004 12:45 PM |
