Welcome to the North American Subaru Impreza Owners Club Monday August 21, 2017
Old 10-17-2003, 10:30 PM   #1
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Default Turbo timer help
I have 2 questions about my turbo timer install.
1. Is the RPM wire neccesary for the timer to work?
2. What is the second cable in these pics? One end has the same type of connector that is on the turbo timer, the other end has a 4 prong rectangular connector with 2 black wires coming out of it. As far as I can tell I don't need it, but I'm curious as to what its for.
lotusTT is offline   Reply With Quote
Old 10-18-2003, 11:17 AM   #2
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
any help?
Old 10-18-2003, 07:45 PM   #3
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
install is happening tomorrow, some help please?
Old 10-19-2003, 06:59 PM   #4
Silverevo8owner
Member#: 45474
2003 Silver Evo 8
04 Silver STI
Is that a type one?
If it is
the gray wire coming off the turbo timer goes to the e brake
THis is the only wire you need for it to work i think
im not sure if you do need the rpm sensor but if you do, that goes to the ecu where the Rpm signal comes from. I dont know which wire it is on the ecu but if you can find a diagram or something, it should work.
That second cable is a harness so you dont have to splice into the factory ignition harness.
Im going to stop here because im not sure how it works on subarus
I also need to install one of these on my STI
Silverevo8owner is offline   Reply With Quote
Old 10-19-2003, 07:41 PM   #5
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Well I did the install today. I got everything working. Still don't know what the second harness is for. Its definetly not for Subaru's, that's for sure. (The Subaru wiring harness is not pictured above.) And the RPM wire is not required for basic functionality. If you want the TT to automatically calculate how long to count down, then you need the RPM wire, otherwise you can just set it to a specific time.
I believe its a Type 0, but it could be a Type 1. I bought it with no box or instructions from a ghetto tuning shop.
Old 10-19-2003, 09:21 PM   #6
Silverevo8owner
Member#: 45474
2003 Silver Evo 8
04 Silver STI
yeah now that i remember there were 3 wires coming off my type 1
Razo RE40 Turbo Timer Help Needed! ginjaninja Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-12-2002 07:37 PM
hks turbo timer help Fast turbo 21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-14-2002 01:11 PM
Blitz turbo timer help Si2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-16-2002 09:03 PM
Erratic turbo timer, Help! linus011 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-25-2002 10:45 PM
Slight problem with my Turbo timer - help! djerickd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-26-2001 12:06 PM
