Welcome to the North American Subaru Impreza Owners Club Monday January 16, 2017
Old 10-26-2003, 08:11 AM   #1
Dave G
Member#: 4738
2006 Baja Turbo
Default What are these wires in the console of my '97 Legacy?
I had my console panels up for a cleaning, and I found wires with blue and white connetors beneath the parking brake handle. What are those for?
The link below has a photo. As you can see there is nothing currently connected to these things.
My car is all stock, with the factory radio and speakers. Are these extra connectors for more speakers, or a subwoofer? Or something else?
http://img.ranchoweb.com/images/skinkmania/10250001.jpg
Dave G is offline   Reply With Quote
Old 10-26-2003, 11:22 AM   #2
etam
Member#: 439
www
let me guess..heated seat? I remember seeing Legacy OEM heated switch there..
etam is offline   Reply With Quote
Old 10-26-2003, 03:32 PM   #3
richeich
Member#: 1353
2001 Impreza 2.5RS
Yep, that'd be my guess too. My wife had an Outback, and that's where the seat switches were located.
richeich is offline   Reply With Quote
Old 10-26-2003, 05:34 PM   #4
Dave G
Member#: 4738
2006 Baja Turbo
Seat heaters??
I don't have seat heaters. My car is a 1997 Legacy GT with cloth seats. Outbacks with the $400 cold weather package had seat heaters in the late 1990's, but it was NOT an option on Legacy GT's in '97.
Could it be that there are seat heaters in the seats, but no switches for the heaters?
So, I'm still looking for a definitive answer on what that wiring is for.
Old 10-26-2003, 05:46 PM   #5
richeich
Member#: 1353
2001 Impreza 2.5RS
Yeah, my '98 definitely does not have those wires in that location. If it wasn't even an option for your model, I'm not sure why the wiring would be there. My wife's '96 Outback had heated cloth seats, so apparently it doesn't have to be leather to get that.
Rich
Old 10-27-2003, 09:30 AM   #6
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
But it was an option for some '97 Legacy models, inlcuding the OB wagon. My sister's 1997 OB wagon has the heated cloth seats, my '97 GT has unheated leather.
So, the wiring is there because the cars all share the same basic build components, even if certain options are left out during final assembly/optional equipment setup/dealer prep/etc.
-Brian
KD7000 is offline   Reply With Quote
Old 10-27-2003, 11:28 AM   #7
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
And it was an option on 97 GT's, but only as the cold weather package added to the Limited.
It's definitely the seat heaters.
sybir is offline   Reply With Quote
Old 10-27-2003, 01:22 PM   #8
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
Post
I have a similar wiring situation in my dash molding. I took it out and on the right side of the molding around the gauge pod there is a push-in button for my window defroster and an empty slot with a plug and there is a wire harness that plugs into that, and i've never had it serve a purpose does anyone have an idea?
pilfflip is offline   Reply With Quote
Old 10-27-2003, 01:41 PM   #9
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
I don't know the interior of the second gen leg's but cruise control or fog light switch maybe?
THAWA is offline   Reply With Quote
Old 10-27-2003, 02:27 PM   #10
Bussman61
Member#: 32612
1996 SVX
Laguna Blue
Wouldn't be cruise control or fog lights. My best guess would be heated seats.
- Charlie
Bussman61 is offline   Reply With Quote
Old 10-27-2003, 03:58 PM   #11
sovereignmk1
Member#: 11858
1998 Silver Legacy
If it's to the right of your defroster then it very well is probably for cruise control as that's where it goes. Fog lights go on the other side of the steering wheel
ie like this
Security/Alarm(iirc) : Fog lights ---- Defroster : CC
I hooked up a Limited side mirror switch which had the mirror defroster swtich too and my 98 L powered up side mirror defroster switch, just need some heated mirrors to see if they hook up as easy. Also, L's are wired for the stock tweeters. Nice upgrade.
//M
sovereignmk1 is offline   Reply With Quote
Old 10-27-2003, 03:59 PM   #12
sovereignmk1
Member#: 11858
1998 Silver Legacy
- Charlie
(assuming you respond to pilfflip)
Heated seat switchs are by the E-brake.
//M
Old 10-27-2003, 08:52 PM   #13
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
My guess would be for the optional security system.
IIRC the alarm control module is hidden in the center console behind the E-Brake.
BJamerican is offline   Reply With Quote
Old 10-27-2003, 08:57 PM   #14
subefriek
Member#: 11214
2001 legacy Gt
titanium
Default Wires
Those wires are definitely for the heated seat switchs, somebody else posted here that when they went to install aftermarket seat heaters when they took the covers off the seats to install them they found factory heaters already there they just were not wired.
Pat
subefriek is offline   Reply With Quote
Old 10-27-2003, 11:27 PM   #15
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Negative, the security system gets ziptied in under the dash by your right knee, with a starter kill inline switch and a couple of vampire taps.
What are these wires for? Jun and APS and wiring gremlins inside... hella_sti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-04-2008 01:52 AM
What are these bolts on the rear diff? LoLoHax Transmission (AT/MT) & Driveline 3 02-08-2008 07:06 PM
what are these inlets on the bottom of this radiator [27] Service & Maintenance 4 01-28-2008 12:30 AM
what are these tiny bead looking things on my crab legs? White 2.5rs Off-Topic 26 12-01-2005 09:58 PM
What are these hoses on the intercooler? (pics) ChristopherG Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-09-2005 01:02 AM
