Welcome to the North American Subaru Impreza Owners Club Thursday September 21, 2017
Old 06-14-2000, 08:50 PM   #1
Sti Turbo
Member#: 1223
Question twin turbo
does any company make a twin turbo kit for the impreza because i want one
Sti Turbo is offline
Old 06-14-2000, 08:52 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
No, because it would require way too much work. New headers, finding a location for the driver's side turbo since the steering stuff is in the way, among a lot of other things.
8Complex is offline
Old 06-14-2000, 09:02 PM   #3
Sti Turbo
Member#: 1223
Post
no problem, thats the fun of it try figuring all this stuff your self in your garage w/freinds. fine then who makes the most powerful turbo for a 2.5 how h.p. increase
Old 06-14-2000, 09:47 PM   #4
mjos
Guest
Member#:
Post
Syms makes a twin turbo header. You could adapt it to the Impreza for twin turbos.
I hope you have a lot of $$ though. While you're at it..may as well buy the widebody fenders too
Mark
Subaru-less
Old 06-14-2000, 10:00 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Well the key to a turbo is picking the right one for the application... I'm sure if you're talking twin-turbo you'll want T28's or maybe even slightly less. T03/04 would be very much overkill and would probably result in heavy turbo lag and you not even hitting max boost before redline.
8Complex is offline
Old 06-14-2000, 11:26 PM   #6
IsraelGT
Member#: 1468
1999 Impreza GT
Talking
Try posting this in the U.K BBS where they have the B4 RSK and the GTB both have a 2.0 litre twin turbo 276 HP engine under the bonnet.
IsraelGT is offline
Old 06-15-2000, 12:55 AM   #7
PaulN
Member#: 566
1994 Legacy GTB
Green
Post
We don't officially get RSK or GTB in the UK,
I have a GTB and had to personally import it from Japan
Paul
www.nebbs.com
PaulN is offline
Old 06-15-2000, 06:32 AM   #8
HRE | giulio
Member#: 481
Post
I think a simgle turbo would be better.
If you have 2, each will be only getting 1/2 the volume of exhaust to spin them. You'll get low boost. Yeah i know- you only need 1/2 the boost for 1/2 the cylinders blah blah blah. But you have to factor in the loss of energy. Turbos are efficient, but 2 of them is doubling the efficientlessness (or some other smart sounding word).
HRE | giulio is offline
Old 06-15-2000, 07:07 AM   #9
PaulN
Member#: 566
1994 Legacy GTB
Green
Post
Giulio
With a sequential twin turbo setup, you don't always have the exhaust flowing through both turbos, on the legacy a valve closes off the second turbo until over 4500rpm, this means that a small turbo thatcan build boost from under 2000rpm gets all the exhaust flow, and that a larger turbo for high flow and revs can be brought in later.
If you use a single turbo that produces lots of boost at 7000rpm you won't get much boost below 4000rpm
Paul
PaulN is offline
Old 06-15-2000, 07:11 AM   #10
rally123
Member#: 753
Post
My RX7 originally had a sequential twin turbo (almost inline).. it was fairly compact and allowed the first "big" turbo to come in at around 3000 rpm and the second closer to 5200 (if I remember correctlt as it wasnt on there very long before I switched over to the single).. The sequential design was very nice as it delivered smooth power across the band and pulled srong all the way to red.. There was not quite as much lag on the stock unit as there was on the bigger single unit I replaced it with.. for all around driveability the hitachi sequential twin was a great piece.. you might be able to dig one up somewhere, but the fuel and ecu mapping would be a pain.
mike
rally123 is offline
HTML code is On
FS/FT 1997 VR4 Vacuum Leak $6,500 Twin Turbo Twin Intercooler Meat9834 Private Vehicle 'For Sale' Classifieds 14 01-04-2010 05:49 PM
Twin Turbo and Twin Supercharged Nissan GT-R bend_bugeye Non-Subaru News & Rumors 14 10-15-2009 07:36 PM
Twin Engine, Twin Turbo, 626WHP, 1997 Tiburon, 10.92 1/4 mile on STREET tires alien_sporez Private Vehicle 'For Sale' Classifieds 3 05-04-2008 12:49 AM
What company's offer twin scroll twin turbo kits for the sti? GT42r Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 09-12-2007 10:27 AM
Will the twin turbo EJ20 fit 91-94 Legacy turbo? jwooman Legacy Forum 5 05-02-2001 12:26 AM
