01-16-2004, 10:23 PM | #1 |
Member#: 10389
Vehicle:2002 |
JDM HID need help
since my jdm hid's ballast doesn't come with harness as well, so anyone know what is the plug # to for the ballast??? also, anyone has the wiring diagram for jdm hid headlight?
01-17-2004, 12:23 AM | #2 |
Member#: 31373
Vehicle:2005 Legacy GT Satin White Pearl |
do a search, especially check over on Clubwrx.net in the exterior and appearance section. the thread is called "CC-B vs. Scoobymods wiring". there's a LOT of good info there. good luck.
01-19-2004, 01:18 AM | #3 |
Member#: 10389
Vehicle:2002 |
I round up some info, so from the stock headlight 9007 connector:
Driver side- common positive = red/light blue (center terminal on connector) low beam switched ground = yellow/red high beam switched ground = red Passenger side- common positive = light blue/white low beam switched ground = yellow/red high beam switched ground = red but i have a question about the info on scoobymods.com, how come the red/light blue wire and light blue/white wire on both side on scoobymods.com, it refer to shared negative, but on this info from here, it refer to positive. And other wires, here refer to grounds, but scoobymods refer to positive, what's the different? so does it mean i just need to make a 9005 plug for the hi beam with and common positive and a hi beam ground? then i need to make some wires to connect the low beam grounds and share positive to the ballast? (since i dun have the ballast harness as well) then tap wires from ballast to the lo beam? with what plug, anyone know? also anyone know what's the plug # that plug into the ballast? since i want to make harness not just taping them. May someone please help??? |
01-20-2004, 01:23 AM | #4 |
Member#: 10389
Vehicle:2002 |
Someone help please!
01-20-2004, 03:29 PM | #5 |
Member#: 31373
i'll answer what i can. from what i gather, the stock harness has 2 switched grounds, and one shared positive.
so yes, your 9005 harness (get from any auto parts store) will have one wire go to the high beam ground, and one wire to the positive. i believe the terminal on the 9005 harness that is near the outside of the car, when plugged in, is your posi. as far as harness for the ballast, i have no idea what the # or model is. sorry 'bout that. hope some of this helps. |
01-21-2004, 02:31 AM | #6 |
Member#: 10389
Vehicle:2002 |
Thx rexmobbin'.
how about the lo beam then? so there suppose to be a harness coming out from the ballast to connect witht the stock 9005 lo beam wire, right? then another wire harness from the ballast to connect to the lo beam? |
01-21-2004, 08:42 PM | #7 |
Member#: 10389
Vehicle:2002 |
May someone confirm the info for me please?
01-23-2004, 03:55 AM | #8 |
Member#: 10389
Vehicle:2002 |
TTT
01-23-2004, 03:32 PM | #9 |
Member#: 31373
just put mine in last night. it's like this, there were 2 wires coming from one part of my harness (power and ground) which both hook up to the stock 9007 harness. (buy an adapter from CC-B.com, weeellll worth the money) also, there's the thick harness that goes from the ballast to the HID light itself. the CC-B adapter also comes with a 9005 connector for the high beam right there.
hardest part for me after getting the harness adapter was mounting the ballasts. |
01-27-2004, 07:54 PM | #10 |
Member#: 10389
Vehicle:2002 |
OK, I come up with a diagram, can someone confirm with me please?
Link to enlarge it I have one more question, since I got no harness for the ballast, can someone check for me, which the orange(+) wire on the black connector on the ballast is inside or outside of the ballast? also the orange(+) that connect the hid light to the ballast? is that in or outside on the grey plug in the ballast? |
01-27-2004, 09:38 PM | #11 |
Member#: 31373
all of the wires that connect to the low HID beam are within the grey ballast plug. also, i believe the orange is the ground and the brown is the power.
01-27-2004, 10:41 PM | #12 |
Member#: 10389
Vehicle:2002 |
Thx rexmobbin' , i know all of the wires that connect to the low HID beam are within the grey ballast plug; however, since i don't have the harness, i would like to know the order of the wires, which orange is outside or inside in the ballast. Then for the ground and power wires label, I am pretty lose here, since some people here refer them as ground and power, but some call them + and - like the one on scoobymods.
02-01-2004, 03:09 AM | #13 |
Member#: 10389
Vehicle:2002 |
May someone with the jdm hid check for me? If the orange wire from the headlight to the ballast is outside of the ballast or inside? And the other orange wire that connect from ballast to the car harness, please?
02-01-2004, 10:59 PM | #14 |
Member#: 27167
VIC
Vehicle:2015 FXT DGM |
Mine probably is different as yours, coz I only have one connector on ballast, well, should be no problem if I show you the pictures...
Let me upload.... |
02-01-2004, 11:05 PM | #15 |
Member#: 27167
VIC
These pictures are taken from driver side.
so right one is connecting to orange harness (headlight) hope it helps |
02-13-2004, 11:24 AM | #16 |
Member#: 19674
TXIC
aawen - Where does the blue and the yeloow wires connect to? Are they wired directly to the low switched ground and the B+ wires of the stock 9007 wiring or do you have a relay installed?
02-13-2004, 01:09 PM | #17 |
Member#: 17751
SCIC
I have an extra black hid ballast harness. Lemme know if you need one. I had my sister in law source it and is bringing it in from Japan.
02-13-2004, 04:25 PM | #18 | |
Member#: 27167
VIC
02-13-2004, 04:26 PM | #19 |
Member#: 27167
VIC
so R.C.Y.K. , have you done your headlight yet? take some pictures
02-19-2004, 04:12 AM | #20 |
Member#: 10389
Vehicle:2002 |
i am installing it tmr,, but finding a place to install the ballast.
aawen, so where should i mount the ballast? |
02-19-2004, 04:45 AM | #21 |
Member#: 27167
VIC
well, on driver side you can install on the bottom, I bet you can see 1 or 2 holes that can bolt on. On passenger side, just try to find a place that can hold it here not easily to move itself when you drive on bumpy roads.
JDM HID Wiring Help needed 02/03 | SubyDuz | Electrical & Lighting | 2 | 02-12-2008 08:46 PM |
02-03 Pass side JDM HID---PLEASE HELP! | scca03wrx | Private 'Wanted' Classifieds | 0 | 03-01-2006 09:23 PM |
JDM HID projector help | Sharmin7 | Electrical & Lighting | 6 | 04-17-2005 12:10 AM |
Anyone with JDM HID please help | R.C.Y.K. | Vancouver Impreza Club Forum -- VIC | 8 | 02-01-2004 11:55 PM |
JDM HID install help | rexmobbin' | Electrical & Lighting | 28 | 01-26-2004 11:25 AM |
