Welcome to the North American Subaru Impreza Owners Club Sunday July 15, 2018
Old 01-30-2004, 12:31 AM   #1
Spoolin16PSI
Member#: 51463
2013 Impreza
SWP Gas Sipper
Default Does anyone elses rear window rattle???
I dont know if it has happened to anyone else, but the rear window on my 03 rex has a rattle on bumpy roads, potholes, etc. Anyone else had this problem? Any ideas of a fix?
Spoolin16PSI is offline   Reply With Quote
Old 01-30-2004, 01:59 PM   #2
Spoolin16PSI
Member#: 51463
2013 Impreza
SWP Gas Sipper
anyone?
Old 01-30-2004, 02:50 PM   #3
cboggess
Member#: 30804
87 Yugo
Red
Mine does. From what I've read it's normal.
cboggess is offline   Reply With Quote
Old 02-01-2004, 08:42 AM   #4
XRW URABUS
Member#: 21974
If you have a sedan, it could be a loose window moulding or something loose in the trunk under the deck lid.
When I got my spoiler installed The center brake light housiing was removed. The dealer put it back on and didn't screw the bolt tight enough.
Let us know what you find.
XRW URABUS is offline   Reply With Quote
Old 02-01-2004, 10:33 AM   #5
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
No problems with mine.
Need4Boost is offline   Reply With Quote
Old 02-02-2004, 12:08 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
My rear window is most definitely loose...It has started leaking a bit recently, and I'm waiting for that one bad bump and *poof*...broken window...
At least I cured it from rattling/squeaking all the time by riding in the back seat while a friend drove the car over a stretch of road where it always rattled and I just pushed, gently, around on it until it finally reseated a bit and stopped making noises. Now it just makes noises over bad bumps.
Old 02-14-2004, 03:58 PM   #7
AaronMG
Member#: 52504
2004 Impreza WRX
WR Blue
i've had the rear window rattle/creak since day 1 (04 wrx).
but im not entirely convinced its the window...
AaronMG is offline   Reply With Quote
Old 02-15-2004, 08:55 PM   #8
sgilbert
Member#: 40179
2002 2.5 RS
I have rear window rattle with my RS when there's ice at the bottom of the window. Snow gets jammed there when I open and close the trunk.
sgilbert is offline   Reply With Quote
Old 02-16-2004, 01:28 AM   #9
bgwrx
Member#: 34637
02 wrx
white and fast
it is quite posibly the 3rd brake lite on the rear deck lid mine rattled allot until i removed it and used double sided tape around the edge of the housing you cant see the tape and the window doesnt rattle now...might want to try it hopefully this helps...
bgwrx is offline   Reply With Quote
Old 02-16-2004, 08:07 PM   #10
tekfoc
Member#: 21392
2016 C63S AMG MB
Iridium /MB C300 4MATIC
the windows can be adjusted to correct the problem.remove door panal ,go to window track area and you will see the adjustment bolts for the window,for forward pitch or back pitch. every body part on are cars is adjustable.
tekfoc is offline   Reply With Quote
Old 02-16-2004, 11:52 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
I'm not talking about the windows in the doors....I'm talking about the BACK window....the big one...in the back...with the defroster on it.....
Old 02-22-2004, 10:34 PM   #12
RRRR1
Member#: 51329
2002 WRX SEDAN
WHITE
Ive had no prob's but windows should not rattle.(period) if it has a rattle that means the sealnt is loose and you should or will have a leak.
Once a frt or back window are sealed into place thats it.
May be something else,check the jack-I did have a prob with that. i cut up an old tire innertube and a couple of well placed peices took care of it. Also the board on the that covers the spare may rattle. i put a couple of small peices of foam fubber(one side adhesive) on the board at the mating point on the rear floor to avoid the prob. Hope it helps !
RRRR1 is offline   Reply With Quote
Old 02-23-2004, 03:36 PM   #13
Dueysan
Member#: 50292
2004 Impreza WRX
Red
I've had my rear window rattle once. It was from little bits of ice that had gotten at the bottom of it. My car is almost always garaged so this has only happened once. Once the ice melted the rattle went away. Might be the same problem??
Dueysan is offline   Reply With Quote
Old 02-23-2004, 10:57 PM   #14
Andrew Bacon
Member#: 2267
00RS
rutherforddesign.com
My windshield rattles if the revs get too low and the car bucks(traffic) Really anoying, bucking the engine AND the rattle. Havn't had a problem with the rear though.
Andrew Bacon is offline   Reply With Quote
Old 02-24-2004, 08:16 PM   #15
dugrant153
Member#: 22505
1985 Old
Rusty
this seems to be a prominent issue with Imprezas?
dugrant153 is offline   Reply With Quote
Old 02-24-2004, 09:45 PM   #16
AaronMG
Member#: 52504
2004 Impreza WRX
WR Blue
just had mine into the dealer to check on this. service tech said its the seat belt assembly and its normal.
unfortunately thats what i expected - any answer to avoid trying to fix the problem.
i'll try and solve it myself - but after my own tinkering, i really think its something other than the belt.
Old 02-28-2004, 08:47 PM   #17
file_id
Member#: 28197
2003 WRX w/ VF34
I can't pinpoint it but i know you guys are talking about. sigh. its really annoying on the crappy california roads.
file_id is offline   Reply With Quote
Old 03-19-2004, 02:58 PM   #18
sti101
Member#: 23220
2001 Impreza RS
I'm just wondering when there's a rattle? My car have a rattle when its reach 65+ mph...& whenever there's bad bumpy road...so anyone have the same problem?
sti101 is offline   Reply With Quote
Old 03-20-2004, 03:46 PM   #19
elanSTI
Member#: 57710
Unhappy Yup, the window rattles!
I just picked up my STI 2 days ago, I have about 300 miles on it, been doing plenty of BS driving just to put the miles on. My window has more of a squeak than a rattle, I think I may try some white lithium grease and see if that quiets it down.
elanSTI is offline   Reply With Quote
Old 03-23-2004, 08:01 PM   #20
catass
Member#: 31976
2004 WRX STi
World Rally Blue
My car doesn't have any rattles or squeaks, but its an 04 with only 4200 miles on it. Although when there's a layer of ice on the roof and the trunk and the wink, then I hear creaky noises!
catass is offline   Reply With Quote
Does anyone else's eyes sting early in the morning? cwb124 Off-Topic 7 10-10-2006 10:35 AM
Anyone else's power window break? 1984 Service & Maintenance 11 09-04-2005 10:15 PM
Does anyone else's (Windows-based) PC -NOT- crash? perret318 Off-Topic 47 01-11-2005 08:29 PM
Does anyone else's car do this??? EA82TRally 'Old School' Subaru Forum 2 12-30-2004 09:45 PM
Does anyone else get a rattle from the rear deck? Jesperss Car Audio, Video & Security 7 10-30-2004 09:55 PM
