Welcome to the North American Subaru Impreza Owners Club Saturday September 22, 2018
Old 02-16-2004, 09:15 PM   #1
Chim
Member#: 55131
GC8 Impreza RS
Default Brakes seem weak
I recently bought an impreza. The brakes seem to be kinda weak, probably worse than my dad's Camry or my old Plymouth Reliant. Is this to do with the Impreza having weaker brakes, or maybe because I'm just driving faster than usual?
Mechanical inspection report came out fine with regard to brakes, except that the brake pads are about 65% worn out (not sure if that has to do with it)
Thnx in advance for replies!
Chim is offline   Reply With Quote
Old 02-17-2004, 01:39 AM   #2
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
You need to share some car info so replies will come faster.
joubtt is offline   Reply With Quote
Old 02-17-2004, 02:15 PM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Have the brakes been bleed recently? What type of pads are on the brakes?
Oh yeah, what type of car.
mbiker97 is offline   Reply With Quote
Old 02-17-2004, 02:26 PM   #4
Chim
Member#: 55131
GC8 Impreza RS
98 impreza rs 2.5
sorry whats brakes been bleed mean? I'm not sure what kind of pads are there either but they are 85% worn down.
The brake pedal just isnt very stiff, and the car doesnt slow down very fast when braking
Old 02-17-2004, 03:03 PM   #5
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
I would suggest you take it to the local dealership for a brake check up. To bleed the brakes means to loosen the bleed valves to remove air that builds up inside them. Getting new pads also would be a good idea.
Old 02-17-2004, 11:18 PM   #6
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
65% worn out or 85%? If the brake fluid hasn't been changed for a while doing that may help. Also, Subaru brakes tend to feel a little mushy but stop just fine in tests.
Mike Wevrick is offline   Reply With Quote
Old 02-18-2004, 12:35 PM   #7
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Try new tires.
Stanley is offline   Reply With Quote
Old 02-18-2004, 01:49 PM   #8
tekfoc
Member#: 21392
2016 C63S AMG MB
Iridium /MB C300 4MATIC
get your brakes done.
tekfoc is offline   Reply With Quote
Old 02-18-2004, 01:57 PM   #9
Chim
Member#: 55131
GC8 Impreza RS
Either my tires or brakes are 85% worn, so if one is 85 then the otehr is 65. But that is probably the cause of the problem, cuz the brakes do feel mushy like mike said
Old 02-18-2004, 10:56 PM   #10
frostyTSM
Member#: 54361
2004 WRX Sedan
Java Black Pearl
If you need to replace the pads, I recommend shopping around and finding a place that, when the pads wear out they will give you new pads. It's probably not the best choice for high performance driving, but if you are driving on the streets and want to save cash in the long run, I recommend it (just make sure you buy it at a place that'll back it up and not run out of business).
Also, check your brake rotors. I've seen cars that were sold because the owner didn't know that squeeky brakes means that the pads need to be replaced, so they chewed through the rotor. Some people are clueless...
frostyTSM is offline   Reply With Quote
Rear brake seems to stick fastseven Brakes, Steering & Suspension 11 05-29-2007 10:38 AM
**help needed, cars battery seems weak in the morning. ultraspdWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-02-2006 08:12 PM
A/C seems really weak - compressor works ezatnova Service & Maintenance 5 06-08-2005 11:58 PM
Are the brkaes in the STi seem weak when new? it8ezbngrn North West Impreza Club Forum -- NWIC 12 10-20-2004 12:29 AM
My brakes seem to suck... drhyed STi Forum Archive 15 07-19-2003 07:22 PM
