Welcome to the North American Subaru Impreza Owners Club Monday April 24, 2017
Old 03-09-2004, 07:25 PM   #1
chrislehr
Member#: 24165
2003 WRX Sedan
World Rally Blue
Default intake silencer deletes?
KAstle's is like 55+ shipping, Dynamispeed is 40$ shipped.
Considering a likely $20 price difference... what's the difference?
I have been wanting to get one a while now - just curious of anyone's opinions?
chrislehr is offline   Reply With Quote
Old 03-09-2004, 07:50 PM   #2
KJR
Member#: 16879
pssst....go to Ebay, very cheap. just make sure the one you buy allows you to bolt it up where the stock resonator does. it may not hold tight without it.
KJR is offline   Reply With Quote
Old 03-09-2004, 08:09 PM   #3
YinUCSD
Member#: 44945
06 LGT wag
are there any real gains from doing this mod?
YinUCSD is offline   Reply With Quote
Old 03-09-2004, 08:10 PM   #4
chrislehr
Member#: 24165
2003 WRX Sedan
World Rally Blue
Essentially a Colder air charge that the airbox silencer removal.
Old 03-09-2004, 08:27 PM   #5
03WRXMA
Member#: 35081
2012 WRX
I think kastles is CF, but since its inside the fender it dosent matter.
I have the Dynamispeed one, fits like a glove.
PS: The CF one might be stonger...
03WRXMA is offline   Reply With Quote
Old 03-09-2004, 08:30 PM   #6
chrislehr
Member#: 24165
2003 WRX Sedan
World Rally Blue
So when people kick the passenger 1/4 panel it won't crack?
Old 03-09-2004, 08:40 PM   #7
03WRXMA
Member#: 35081
2012 WRX
Nope its an OT joke I thought you woulda seen it!
Old 03-09-2004, 08:45 PM   #8
chrislehr
Member#: 24165
2003 WRX Sedan
World Rally Blue
I dont hang out in the NASIOC OT.... I get burned anytime I post
Old 03-09-2004, 09:31 PM   #9
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Wink chrisler
If you get dissed on your threads, maybe you could show more respect on other threads, and not be so needy when you want a question answered.
Just that facts if you have any.
unkadave and q&a about vf34 vs PE & Greddy
unka d
btw got a U box bypass at Teague i think. no big diff / but i had an Injen CA Intake that needed replaced for my reflash
unkadave is offline   Reply With Quote
Old 03-09-2004, 10:58 PM   #10
Celly
Member#: 48724
Just installed my Kastle tonight... Very nice..
HP Gains? I'm sure somone with a sensitive Butt Dyno will say yes. Check the bottom picture for what was removed, and you can only assume that it helps the airbox breath more.
But, mostly, it really helps tone up the intake sound. Then again, I have only had it installed for 2 hours...
Celly is offline   Reply With Quote
Old 03-10-2004, 12:39 AM   #11
BrianH
Bing user
Member#: 44383
man you should have done a before and after dyno.
I did this, picked up a little bit on the ear dyno.
BrianH is offline   Reply With Quote
Old 03-10-2004, 01:02 AM   #12
Jon-RIWRX
Member#: 38789
2008 Jeep Liberty
Red
rather than do a delete i removed the ram air all together. the coldest air is in the fender plus the ram air can get heat soaked. i bought a velocity stack from summit racing and modded it to fit. since your fairly local if you wanna check it out lemme know. itll save you a few $$$ and i think it makes the engine bay look a bit cleaner.
- Jon
Jon-RIWRX is offline   Reply With Quote
Old 03-10-2004, 01:20 AM   #13
industrial
Member#: 7250
2017 WRX
- Jon
Yup, I did the same thing more or less. Removed the front scoop and replaced hole with fender plug (available from dealer). Bought a 2->4 inch rubber sanitation adaptor(home depot) and trimmed it a bit and stuck it in the stock box -> fender well. Works like a charm and really amplifies the intake noises.
industrial is offline   Reply With Quote
Old 03-10-2004, 04:03 AM   #14
SubNub
Member#: 53603
2004 EJ207 WRX
I am sure the Kastle one is nice however seems unnecessarily expensive. I just picked up the one from Ashley at Dynamispeed last night and installed it today. This is the one and only mod I have on the car right now (Brand new car...Too busy with family stuff to do much else). The one from Dynamispeed is made out of a heat resistant plastic material (Sean said it was resistant to some crazy number) that seems about three times thicker than the stock snorkus. It is made by GP Motto. I got to meet Sean from GP Motto last night and talk to him about it. He was a great guy. The inside of the GP one is very smooth like glass. As far as strength differences between a CF one and the GP Motto one I think it would be like taking one elephant to crush it vs. taking two elephants to crush it. Make sense? I also don't see how the fender air could be any colder than the air from the intake duct however heat transfer from the engine makes some sense. Along the same lines though there is probably equal heat transfer through the fender liner from the brakes/tires/asphalt etc. Makes you think huh? I believe the WRX intake design is one of the better on stock cars.
The fit and finish is very nice on the GP Motto one. I plan to "redo" the mod and take pictures so I can write a nice instruction thread for everyone on scoobymods with pictures even a noob could figure out (including how to remove the jack from the trunk ).
The GP Motto one has the screw just like the factory snorkus and they supply you with a new screw and attachment spacer (however I am going to mod the GP Motto one to use the stock rubber spacer and write this up too as the rubber one will probably produce more quiet results if there is any vibration issues....too soon to tell).
Bottom line is this: Is it going to sound different with the elbow? NO. You will hear a tiny tiny tiny bit more whistle from the turbo (If you asked a girlfriend to see if there was a difference I doubt she could tell...No offense ladies...not something most girls are into) but that is it. I hear no more bypass sounds than I did with stock. The unit is very thick which leads me to believe that it absorbs the sound pretty well to be honest.
Now, is it going to change the characteristics of the car? Butt Dyno says the car feels like it has a tad more torque and feels more responsive to throttle. Don't expect a miracle but I say expect a bit of a smoother power that feels like it starts earlier than before. You may also see better results with an ECU reset (although I believe it will "learn" given long enough. I don't think mine has learned the part yet) To me it is the knowledge that I am not running my air all the way down and then back up to the air filter.
NOTES:
1. Remember that there is a nut that needs to be removed that is right behind the fog light (MY04). You have the one you can see when you remove the Intake Duct and then there is one on the snorkus toward the front of the car down lower. You can't remove the snorkus until you remove this PITA nut...Ask me how I know. I jacked the car up with the factory jack and removed three black fender liner fasteners and the clip. I also removed the fog light surround (pops right off) and then I could view the nut I had to remove more easily.
2. Although I don't foresee water being an issue in the elbow at all you may take the factory approach and drill a hole in the bottom of the elbow to drain any liquid that accumulates in the elbow due to scuba diving in your Scooby or possible condensation. This is probably not "necessary" as I believe the air box also has a hole in it for the same reason but since the elbow dips down you could keep a puddle of water there. Just an idea since the snorkus has a hole at the bottom.
3. You just removed ~1 pound from the car. The Motto one is lighter than the stock unit.
4. An aftermarket filter (K&N drop-in) may make the sound louder and improve the velocity of the air
5. I did not get a check engine light from installing this part (some say they do)
Jeez I have now written instructions and a review. I just get carried away. Let me know if you guys need more help and when life gets less hectic and I actually have a place to dump my photos off my camera I will do a "real" write-up on the GP Motto install. Ashley, maybe you can include it as instructions for the part as it did not come with any.
SubNub is offline   Reply With Quote
Old 03-10-2004, 08:45 AM   #15
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
- Jon
Another happy velocity stack owner. It does make more noise, but I like it.
dbrier is offline   Reply With Quote
Old 03-10-2004, 11:36 AM   #16
YinUCSD
Member#: 44945
06 LGT wag
dont want to thread jack, but this may help most who are donig intake silencer mod.
im thinking about doing that velocity stack mod, what do you guys think about leaving the ram air scoop in place along with using the velocity stack (taking out the silencer snorkus of course). i figure this, leaving the ram air scoop in the engine bay, you still get air from the front of the car to the fender, creating more positive pressure along with just having more air in the fender. or is there enough air in the fender that plugging up the hole would be better than having heat soaked air coming into the fender?
Old 03-10-2004, 02:49 PM   #17
SubNub
Member#: 53603
2004 EJ207 WRX
I feel like the "deletes" is what this thread is about so I feel sticking to that would be good lol.
I don't understand why people leave the intake breathing from the fender when the Elbows are cheap and you don't have to spend so much of your own time R&D. I know trips to home depot and making your own ghetto mod can be fun but the elbow for about 40 dollars is really worth it in terms of your own time to make something (Hours vs. Minutes). I know some of you guys want sound over performnance but I think the "delete elbows" are unmatched in performance as they give the air a fast travel path that keeps much of the stock design. A velocity stack sounds cool in theory but I doubt how much real world velocity you can actually add grabbing air from the fender like that. I think you have a better chance of grabbing nice cold air at the front of the car as the factory intended. CAIs (talking aftermarket) sound cool, they do, but for *most* cars the factory intake is more than plenty. In fact if you read most tuners recommendations they usually tune the best and most smooth results with the stock box and only even map for CAI because people are stupid enough to use them.
If your engine can't breath with the stock box because you have added so much modification that is one thing and may warrent a properly tuned CAI. Anyway that is just my .02
Let's get back to helping Chris decide about a "silencer delete elbow" as this was the original question.
Old 03-10-2004, 03:50 PM   #18
industrial
Member#: 7250
2017 WRX
There is so little to talk about...Get whatever one you want, like it makes a rats a$$ of difference when it comes to performance. I'm willing to bet the HP difference between a hacked snorkle, stock air box, velocity stack/ghetto mod and bling bling CF elbow is + or - 1.48271 HP.
Old 03-10-2004, 05:59 PM   #19
slvwagon
Member#: 37226
2003 wrx wagon
What size velocity stack did you use?
Summit has only one with a 3in opening, but the diameter of the rounded opening is 7".
slvwagon is offline   Reply With Quote
Old 03-10-2004, 09:38 PM   #20
Celly
Member#: 48724
Originally posted by industrial
between a hacked snorkle, stock air box, velocity stack/ghetto mod and bling bling CF elbow is + or - 1.48271 HP. [/b]
In the future, can you please refer to my elbow as "Uber Sudo JDM Bling CF Elbow..."
I did some real listening on my way home from the office tonight, and the Silencer delete does make an audible difference... Nothing major, but you can hear the turbo suck a bit better...
Old 03-10-2004, 11:22 PM   #21
Family Truckster
Member#: 14201
2002 WRX Wagon
Default Yes, I can hear it.
I installed the GPMotto elbow a few months ago. Here in the north with the cold weather you can hear the turbo and re-circ valve, don't know about the warmer weather.
Family Truckster is offline   Reply With Quote
APS 65mm Intake TD04 wrx stock tmic GP MOTO intake silencer delete 02rex62 Engine/Power/Exhaust 18 03-04-2010 06:30 PM
Intake Silencer delete elbow SupraScooby Newbies & FAQs 20 08-25-2004 02:33 PM
FS: Intake Silencer Delete Elbow SupraScooby Private 'For Sale' Classifieds 9 05-26-2004 02:28 AM
Intake silencer delete fluttering noise heffergm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-27-2004 05:18 PM
gpmoto Intake Silencer delete elbow Benjamin Tang Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-04-2003 04:10 AM
