Welcome to the North American Subaru Impreza Owners Club Tuesday May 11, 2021
Old 03-31-2004, 09:06 AM   #1
jacobsen1_
Member#: 34474
2oo4 WRX PSM Sedan
2oo3 MINI cooper RED/WHT
Default 04 Side Splitter Install!
OK, I was asked to post in another thread how to install the side splitters, so I figured I would start a new thread to make it easier to find for everyone.
Here goes...
For the side splitters to go onto my wrx, I cut 3 holes per side for the tabs to go into. Here is a picture of the 3 holes:
To cut these holes I carefully lined up the side splitters with the car to determine where the hole should go, and then used a sharp knife to cut the holes. It's more than a slit. The is actually a little bit of plastic missing...
I then "adjusted" the splitters to be used on a WRX instead of an STi. In this picture you can see the 2 splitters. The top one has had the white tabs removed, as well as the black plastic pieces that held them in place. To do this I used the same sharp knife. (Actually a steak knife):
You then pop the 3 tabs on each side into the hole you cut in your bumper, and use the metal tabs and bolts that came with the splitter to bolt the rest up under the car. That is the easy part. The only tricky or hard part of the whole thing is cutting the whole and more becasue you have to cut a whole in your nice car...
Here are some finished pictures:
Good Luck, and feel free to post any questions, or additional help in this thread.
Ben
jacobsen1_ is offline   Reply With Quote
Old 03-31-2004, 11:46 AM   #2
Wagon Joe
Member#: 34436
2018 Jeep Wrangler
good writeup... should be posted on scoobymods
Wagon Joe is offline   Reply With Quote
Old 03-31-2004, 12:41 PM   #3
jacobsen1_
Member#: 34474
2oo4 WRX PSM Sedan
Not a memeber over there, but someone who is can feel free to borrow any of this. Just post a link to this write too... I should go there and join and add it.
Ben
(EDIT: It's over on scoobymods now too. I will post a link when they moe it to a forum.)
Old 03-31-2004, 02:14 PM   #4
shogun90
Member#: 54858
2004 WRX Premium
Platinum Silver
Nice work, I live in RI and I will being doing the same mod to my silver 04. Glad so see this thread, it will make it much easier for my install.
shogun90 is offline   Reply With Quote
Old 03-31-2004, 02:58 PM   #5
darknightohio
Member#: 50523
2010 GTI
how much did those side splitters cost you?
darknightohio is offline   Reply With Quote
Old 03-31-2004, 07:45 PM   #6
jacobsen1_
Member#: 34474
2oo4 WRX PSM Sedan
Old 04-15-2004, 12:33 AM   #7
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
Those are really nice! Wish that stuff was availbe for the 03' but just not as expensive... who is gonna pay $400 for the stock front lip/strake on each side of the front of the bumper... that's outragous!
Yours looks really nice! Should come from the factory like that other than the STI :-)
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 04-15-2004, 12:34 AM   #8
b_tapper
Member#: 5291
'08 Scion xB
Nautical Blue Metallic
wish they fit the wagon
b_tapper is offline   Reply With Quote
Old 04-15-2004, 08:41 AM   #9
jacobsen1_
Member#: 34474
2oo4 WRX PSM Sedan
Can you take a closeup profile shot of your wagon for me... I know yours isn't as wide in the wheel well arches, but I wouldn't doubt that you could get them to work...
Ben
Old 05-28-2004, 09:46 AM   #10
XrW_eTiHw87
Member#: 62863
2004 WRX
aspen white
where'd u get the splitter from?
XrW_eTiHw87 is offline   Reply With Quote
Old 05-28-2004, 09:50 AM   #11
wrpmission
Member#: 40540
2004 Impreza WRX
WR Blue
how long did it take you to do this whole process? it seems like it should only take 30 minutes to an hour IMO
wrpmission is offline   Reply With Quote
Old 05-28-2004, 12:30 PM   #12
bezerk
Member#: 44809
2008 BMW M3
SATURDAY!!!!!!!!!!!!!!!
VERY nice job indeed!
bezerk is offline   Reply With Quote
Old 05-28-2004, 01:18 PM   #13
vile
Member#: 32371
'02 t-rex wagon
platinum
is it really functional or mainly for looks?
vile is offline   Reply With Quote
Old 05-28-2004, 01:24 PM   #14
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
bit o both i would think.
looks good and cant hurt aerodynamics now can it?
Jamie
www.subiegal.com
Old 05-29-2004, 01:34 AM   #15
aznatama
Member#: 60316
2004 STi
like most small subtle aerodynamic parts... it'll probably work, but only noticeable at about 2x the speed limit. =)
aznatama is offline   Reply With Quote
Old 01-04-2005, 06:54 PM   #16
Snow Drift
Member#: 75071
'19 xvPHEV,Tesla MY
05 08 11 WRX 18 STI 18TM3
back from the dead.
they are supposed to increase the air flowing over the brakes, dunno tho.
Question: did they come w/ the mounting brackets, cus i just got a pair and they didnt???
EDIT: i see the brackets are an option. i think im gonna do the 3M mod anyway.
Snow Drift is online now   Reply With Quote
Old 04-26-2005, 05:08 PM   #17
EZ Rider
Member#: 38224
I miss
my Subie.
Bump for some uber-n00b notes that might help others like me.
I just did this install last night and I've got a few tips that may help other complete mod newbies. These are not in any particular order!
1. After doing one side, I found it was easier to remove the 3 black plastic anchors before starting. I haven't seen anyone else talk about removing and reinstalling these during the install, but I think they're intended to be used with the splitter. So in the end, you have the splitter attached by the 3 tabs on top, the 3 black plastic anchors, and the 3 bolts/clips included with the splitters.
1a. Make sure you know how to work those plastic anchors. They're made up of two parts: a center nail-like thing, and a outer molly-like anchor piece. It's easiest if you take out the center portion first, then pull out the molly-like anchor portion.
2. I found 8 places (4 on each side) that could use a bolt and clip, even though only 6 are included in the kit. It's fine though, 3 each side is enough. I put two in the two forward-most positions on the underneath and one at the top position in the wheel well. Considering the locations of the other anchors, I found this to be a good balance.
3. I used a small drill bit to get a start on the cuts in the bumper. I just had to be careful not to let the drill get away from me and chew up too much bumper... cause it kind of wanted to.
4. It would be easier if you had ramps or something, just a little more space to work with. But I did it just fine with the car on the ground.
Hopefully this helps someone, I imagine most people won't need these.
EZ Rider is offline   Reply With Quote
Old 04-26-2005, 06:28 PM   #18
thebing
Member#: 61109
2004 WRX
Platinum Silver
i tried the knife way when i did mine. it didnt work. unless you have like a samurai sword. so my addition is that a dremel + router tool + your steady hand is your friend.
thebing is offline   Reply With Quote
Old 04-27-2005, 07:07 PM   #19
Weber
Member#: 84718
2005 Impreza
Crystal Gray
Default fitting spliiters
Hopefully this helps someone, I imagine most people won't need these. [/quote]
car still a month away from delivery and spliters should be here next week.
Definete it will help more when i fit them. Thanks for the extra tips
Weber is offline   Reply With Quote
Old 09-13-2005, 12:26 AM   #20
rally_on
Member#: 86849
2005 GMC Savana
white
i'm about to buy some of these, but first... sleep...
rally_on is offline   Reply With Quote
Old 09-13-2005, 12:49 AM   #21
neushane
Member#: 61105
2009 Legacy Spec.B
brought back from the dead. Have fun with the install. Real easy to do. I was indecisive on cutting the tabs off or cutting the bumper. I went with the tabs coming off. Easy to do just make sure you get the right 3M tape. I went to like 7 places before finding the right stuff at a true value. Been on for 7 months with speeds upto 110 and no problems at all.
Shane
neushane is offline   Reply With Quote
Old 11-28-2005, 07:35 AM   #22
darylWrX
Member#: 83351
Shane
brought back from the dead... again........ how thick is the 3m tape that you use? im going to install mine this week.
Dan
darylWrX is offline   Reply With Quote
Old 01-04-2006, 09:25 PM   #23
scooby_wooby
Member#: 79653
2005 LGT
I'm about to install the front splittter, I'm just wondering if having the white tab mounting removed looks different with it in???
scooby_wooby is offline   Reply With Quote
Old 01-04-2006, 09:50 PM   #24
cefoskey
Member#: 83961
2012 Cayenne 6MT
'16 Volvo XC90 R-Design
no it would look the same, but youd have to drill holes in your bumper for those snap fasteners. Since they are an OEM replacement for the STI tabs, I would assume the sti bumper has those holes underneath in stock form.
cefoskey is offline   Reply With Quote
Old 01-04-2006, 11:40 PM   #25
scooby_wooby
Member#: 79653
2005 LGT
instead of removing the mounting, i'm just going to remove the white tab and put double sided tape in it...
STI Side splitter install jonthesloth Interior & Exterior Modification 18 05-03-2009 03:14 PM
STi side splitters install Cannonbolt Interior & Exterior Modification 9 07-23-2008 04:14 PM
STi Side Splitter Install Question Godfather Inc 03 Interior & Exterior Modification 21 08-15-2006 12:44 PM
Side splitter install aid Thumper23 Interior & Exterior Modification 2 04-28-2004 07:09 PM
Side splitters install on WRX blackout Interior & Exterior Modification 12 03-31-2004 09:07 AM
