Welcome to the North American Subaru Impreza Owners Club Tuesday February 25, 2020
Old 06-28-2004, 01:35 AM   #1
phenemwrx
Member#: 58197
2003 EVO 8 GSR
2.3L GT35r
Lightbulb How to make your clock RED!!!
Here is what the finished product looks like at night:
What i did:
1) Went to local craft store and got red stained glass paint.
2) Removed clock and took it apart from black plastic case and painted about 5 layers of the stained glass paint applying one layer at a time every 10-15 mins until i got the desired color. (I just kept on running back and forth from the car to my paint to check the color, best results are at night!)
3) Reinstall
Final pictures of complete Red conversion: (bad quality pictures, sorry!)
For the HVAC and Cruise/Auto button on window/Fog light button i used red bulb condoms from www.partsexpress.com
If you guys have any questions feel free to ask this took me about 2 hours to do everything. Now all i need is the STi gauge cluster!
Happy modding,
~Zach
phenemwrx is offline   Reply With Quote
Old 06-28-2004, 01:58 AM   #2
IllNastyImpreza
Member#: 36333
98 RS
GT30R, closed deck madnes
Thumbs up sweet!
that looks MINT ! I wonder if you could do blue??
IllNastyImpreza is offline   Reply With Quote
Old 06-28-2004, 02:12 AM   #3
phenemwrx
Member#: 58197
2003 EVO 8 GSR
2.3L GT35r
Blue would be much easier, i went from green to red! Green to blue would be real easy and probably look better too. Also i had to disable the clock to dim when you turned on your lights, so it stays bright all the time so you can see it. To do this all i did was take out the 3 wire down form the tope of the harness it says something like LIG beside it. This was all done on a 2004 WRX.
~Zach
Old 06-28-2004, 02:37 AM   #4
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
Zach
1: Where did you get that gauge cluster and who makes it?
2: I also used bulb condoms for all of my lights in the car but when I tried to use it for the fogs and cruise it is NO WHERE near the brightness of your picture... what did you do? My HVAC lights are nice and bright but other than that my cluster is sorta dim... I am actually looking for a completly new cluster, I like the v8 sti but I would prefer the cluster that you have there.
Thanks,
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 06-28-2004, 04:47 AM   #5
SubaruRules
Member#: 20267
|'02 GGA WRB|
|'03 BH6 PSM |
Originally posted by NewShockerGuy
Zach
Thanks,
-Nigel
That's an '04 WRX stock gauge cluster
SubaruRules is offline   Reply With Quote
Old 06-28-2004, 09:59 AM   #6
phenemwrx
Member#: 58197
2003 EVO 8 GSR
2.3L GT35r
Yeah its the stock '04 cluster, i did nothing to it, just turned the brightness control all the way up on the dial adjustment. For the brightness of my cruise and fog switch's i have no idea, i used 1 bulb condom for the switch's and two bulb condoms for the HVAC to get the red that you see there. Next for me is the USDM 2004 STi gauge cluster.
~Zach
Old 06-28-2004, 10:10 AM   #7
JIN
Member#: 27731
Here's how it looks like when you finally got the STI Gauge Cluster.
Jin
JIN is offline   Reply With Quote
Old 06-28-2004, 01:53 PM   #8
Rogue3000
Member#: 52343
2005 Impreza WRX
Crystal Grey Metallic
What are those blue displays at the top of the picture?
Rogue3000 is offline   Reply With Quote
Old 06-28-2004, 02:04 PM   #9
Axan
Member#: 17569
2011 Impreza WRX STI
Can you post a link or part # for the bulb condoms you used.
Axan is offline   Reply With Quote
Old 06-28-2004, 05:51 PM   #10
phenemwrx
Member#: 58197
2003 EVO 8 GSR
2.3L GT35r
Here is for the HVAC:
http://www.partsexpress.com/pe/showd...number=070-080
Here is for the dash/cruise/fog light switch:
http://www.partsexpress.com/pe/showd...number=070-090
Get 2 bags of each size(20 condoms in each size)
~Zach
Old 06-28-2004, 08:58 PM   #11
Tobey
Member#: 21400
2015 WRX Limited
ISM
can you read your clock in the daytime?
i really want to do this!
Tobey is offline   Reply With Quote
Old 06-28-2004, 09:31 PM   #12
phenemwrx
Member#: 58197
2003 EVO 8 GSR
2.3L GT35r
Thumbs up
I cannot read my clock very well, but i don't care because i wear a watch (haha) J/K but no i don't worry about that because i have a clock on my aftermarket stereo. But i can kinda see it, if you do a light coat of the glass stain you will be able to but if you want it to match everything you have to do a couple of layers to get the red that i have, and i cannot see it very well in the daytime. I just wanted everything to light up nicely at night was my concern.
~Zach
Old 06-28-2004, 10:51 PM   #13
VSGTS14
Member#: 60497
2018 WRX STI
CBS
very nice...i have everything red in mine and it looks soooooooo awesome...i need to take some pics.
VSGTS14 is offline   Reply With Quote
Old 06-28-2004, 11:03 PM   #14
gelgel
Member#: 50522
03 rs
Hey Zach~ Good JOB!! Mind telling me how do you make the fog and cruise red? I got the paint already~ Just having problem locating the bulbs of the fog and cruise control....
gelgel is offline   Reply With Quote
Old 06-29-2004, 02:11 AM   #15
nickster
Member#: 49836
03 VF43'd WRX
psm
Jin
Hey, what kind of gauges are those in the center pod? Did you change the colors on them or did they come like that. Thanks.
nickster is offline   Reply With Quote
Old 06-29-2004, 02:18 AM   #16
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
~Zach
Zach if you get the USDM sti cluster i will buy your stock 04' cluster from you. I hate the o3's because of the yellow and green, I would MUCH prefer red needles like the 04!
OR
Does anyone have a part number for the 04's gauge cluster? I assume that it's directly plug and play for the 03's..
Thanks,
-Nigel
Old 06-29-2004, 09:30 AM   #17
phenemwrx
Member#: 58197
2003 EVO 8 GSR
2.3L GT35r
Here is for the Cruise/Fog light/Intercooler button: (all the same)
http://forums.nasioc.com/forums/show...ight=glue+bulb
In the fog light the two little turn screw's are both lights so replace both with condoms and you will have the both the Fog words light up and the little light above it that tells you when the fogs are on. (once you read that post link above you will know what i mean)
~Zach
Old 06-29-2004, 09:32 AM   #18
phenemwrx
Member#: 58197
2003 EVO 8 GSR
2.3L GT35r
OR
Thanks,
-Nigel
How much would you offer for it? Email me your offer at: [email protected] and i will consider it.
~Zach
Old 06-30-2004, 04:12 AM   #19
gelgel
Member#: 50522
03 rs
~Zach
Thanks Zach! But things didn't work out successfully... they did turn red but cruise and fogs are not working anymore....
any ideas?
Old 06-30-2004, 09:40 AM   #20
phenemwrx
Member#: 58197
2003 EVO 8 GSR
2.3L GT35r
any ideas?
Not working? did you put them back together correctly, all you had to do was take out the bulb and but a red boot on it and put it back, then scratch off the green plastic. If you have anyone else that has a scooby get them to let you take apart one of their buttons and see how it goes together then do the same to yours, and make sure you plugged them in the right spot too.
~Zach
Old 07-02-2004, 08:11 PM   #21
TravisSTi
Member#: 51243
2004 Subaru WRX STi
WRB - GTX30r
Alot of the bulbs in the WRX are polerized so if it isnt working take it out and turn it around 180 then put it back in...it should work then if the bulb is still good.
TravisSTi is offline   Reply With Quote
Old 07-04-2004, 11:40 AM   #22
shadrool
Member#: 59775
09 forester
white
Originally posted by TravisSTi
Alot of the bulbs in the WRX are polerized.
yeah called LIGHT EMITTING DIODES
shadrool is offline   Reply With Quote
Old 07-07-2004, 10:00 AM   #23
sc00byr3x
Member#: 63330
2016 Crosstrek
Desert Khaki
Wonder if it is possible to turn everything CLEAR. I like the bright white looks of the stock 04 gauge cluster. I would like to make everything else white.
Is this possible and would it be too bright or what?
Let me rephrase this. Are all the bulbs clear to begin with? If they are, I can just remove the condoms and scrape the greens off and that's all.
sc00byr3x is offline   Reply With Quote
Old 07-07-2004, 10:00 AM   #24
sc00byr3x
Member#: 63330
2016 Crosstrek
Desert Khaki
Old 07-07-2004, 10:09 AM   #25
sc00byr3x
Member#: 63330
2016 Crosstrek
Desert Khaki
I'm pretty sure I can do the buttons for cruise, fog, and the stereo (I think), but I can't find any directions on the heater controls.
How to make your car faster and reduce the stress on your transmission Unabomber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 10-06-2016 08:57 PM
Tutorial: How to change your clock to blue, red or whatever color you want lennyTR Electrical & Lighting 45 09-03-2014 04:11 PM
How to make your car handle to your liking Eric SS General Community 4 11-10-2001 06:34 PM
How to make your subie stink...trust me. Rocket Newbies & FAQs 38 09-16-2001 12:48 PM
How to make your passenger pee in their pants 1.8L General Forum Archive 14 08-15-2000 11:23 PM
